I have a old 52 inch rca projection tv ,model p52151wk,it has been a great tv, it made a popping sound and a burnt smell while i had the wii game playing and now the power lite will only blink and go right back off when you try to turn it on, what could be wrong
  • 647 Answers
The HV block is a common problem with these sets Part# 205064. Caution is required working in this area since high voltage is present.
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour.
Posted on Oct 02, 2009
Testimonial: "thanks for the info, sounds like i may need to take it to a repairman, do you think this will cost a lot to fix it,thanks tim"
  • johnnydiode
    johnnydiode Oct 02, 2009
    If the picture was good b4 it went dead it's likely worth repair - Most shops should charge between $200-$350 and if you've never had the HV block replaced b4 it's definetly due (I've replaced 100's).
I have a 52 inch RCA. I was watching it and
Sounds like a high voltage transformer failed.
You will need to call a serviceman to repair if your not technically handy and can solder.
Dec 14, 2009 | RCA P52926 52" Rear Projection Television
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
Rca p52770eb wont come on sparks in the back about 2 inches from the power cord inside the tv
On some of the RCA televisions, the Hi Volt transformer will go bad and make a sizzling or popping sound. Most often, it will smell burnt when this happens.
Jul 17, 2009 | RCA P52926 52" Rear Projection Television
52 inch rca 52w20 powers up with three high pitched noises then nothing
sounds like the flyback which is the number one component that fails on that model. You need flyback 259296 and you can get a replacement flyback at the following with step by step instructions on how to replace it. heres the link.
http://servicemanuals.vstore.ca/
Sep 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch
your convergence board may be going out its about a 100.00 part but about 300 to have it installed
Jun 23, 2008 | RCA P52926 52" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA 52 PROJECTION TV MODEL P52151WK
No , if fuse was blown you would not get the popping. How old is unit ? It sounds like your high volt splitter. common problem with rca. repair should not cost more than 250.00. you will want to have chassis number  and manu date for help
www.classtorations.com
Jun 04, 2008 | RCA P52937 52" Rear Projection Television
P52151WK 52" projection TV, no video
Is the audio coming from the TV's internal speakers, or from an external sound system? In the 169 series chassis, if the power supply caps or secondary rectifier are bad, or if the high voltage splitter has shorted inside, the set will not run and there will be no picture or sound from the TV. If the picture is completely black but the TV still has audio, press the menu button and see if the menu comes up on the screen. If the menu is there, check your cables on the back of the TV. If you are using a cable or satellite box, the box could be bad or the video wire could be bad or loose. If you do not get the on-screen menu, then I would guess that the solder joint next to the flyback transformer that sends filament (heater) voltage up to the picture tubes has cracked, or the low value resistor in the heater circuit has opened up. If that is the case, have the set serviced by a qualified tech familiar with the 169 series chassis.
Aug 26, 2007 | Televison & Video
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Electro Med Services...
