Question about Black & Decker Hedge Hog 22-Inch 2.8-AMP Dual-Action Hedge Trimmer #HS1012
Trimmer locked up. it will work with some jiggling around but will lock again if it stops
Gas hedge trimmer blade locked up motor runs find
look for a bad nick in the teeth and file or grind it off smooth
Sep 16, 2014 | Poulan Pro PP2822 22-Inch 28cc 2 Cycle Gas...
Ford laser 2001 door lock
You will need to replace the power door lock actuator, it is defective.
Nov 12, 2013 | Ford Laser Cars & Trucks
Gt250r rear seat lock jammed
Try spraying PB Blaster in the lock to free up corroded tumblers. These locks require periodic lubrication
Jun 04, 2017 | Cars & Trucks
My 1999 chevy malibu key will not turn in the ignition
you need a new ignition switch, or the key is slightly bent or to worn down to hit tumblers
Mar 14, 2012 | 1999 Chevrolet Malibu
Have a 2002 dodge neon and the ignition locked up i had it towed and the tow truck driver told me it was my ignition switch... this isint the first time this has happened so after i got it home i just...
Inside the steering column the ignition switch ties in with the steering and shifter lock. The lock plate will sometimes get off center/ out of alignment especially if the wheels aren't straight. This can make everything lockup. If more jiggling doesn't help, you may have to remove the steering wheel and ignition lock, align or replace the lock plate (if damaged) It could also be that the casing on the ignition lock cracked or broke and part of it has jammed in there.
Jan 08, 2011 | 2002 Dodge Neon
String won't stop advancing and tangles around the unit
Hi
I would guess that your spring has got lost when you reloaded the string .
check and see if it exists if not put in new one .
Jul 19, 2009 | Homelite Mighty Lite Lawn Trimmer
Black & Decker Hedge Hog 22-Inch 2.8-AMP Dual-Action Hedge Trimmer #HS1012 Logo
327 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
