Question about Kenmore Dryers
Kenmore dryer model 110.74902200 stops heating after 10 minutes.
  • 156 Answers
SOURCE: Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Posted on Feb 28, 2008
  • 958 Answers
SOURCE: Dryer not heating
normally, it is the thermal cutoff switch. test this part for continuity and if there is non, then that is your problem.
tnx 4 using fixya,
drcool
Posted on Sep 29, 2008
SearsTechToo
  • 261 Answers
SOURCE: No Heat
Hi, I worked on one of these yesterday and have found that the thermal fuse blows first. If your dryer has the lint filter on top then the thermal fuse is behind the back panel and is located on the same duct as the lint filter.It will usually have blue wires on it instead of black or red.
Posted on Oct 17, 2008
SOURCE: kenmore gas dryer after 5 to 10 min. later no more heat
Yup, shortly after I posted this question I was able to find that it was indeed the valve coils. Very easy to get to and replace. Cheap too! Got both of them for about $20 thru www.appliancepartspros.com. Same parts would have cost about $70 thru Sears direct.
Patrick, they are located on the burner unit under the drum in the front left. You can get a diagram of the burner unit by looking up Parts for your model # at Sears.com.
Only tricky thing is you may need to have someone help hold the tumbler in place when you put the belt back on the motor. Personally I found it easier to use two hands to manipulate the belt around the motor and tension bracket and have my wife hold the drum in place rather than to try and balance it myself.
Posted on Oct 27, 2008
  • 3 Answers
SOURCE: Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
Posted on Nov 02, 2008
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
Sears Kenmore 08980800 Stops after 10 minutes of operation.
Sounds like the motor may be getting hot and kicking out on the motor overload switch. When it cools down it will reset.
Jun 10, 2009 | Dryers
Dryer stops working after 10 minutes
Motor may be over heating.may need new motor.
Mar 01, 2009 | Kenmore 73952 Gas Dryer
Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Feb 08, 2009 | Kenmore 62602 Electric Dryer
Dryer runs for 15 minutes and stops
check the in-line limiters on the heating coil tube.
Jan 15, 2009 | Kenmore 62882 Electric Dryer
Kenmore 70 series dryer cuts off after 10 minutes
You first shoul check the belt to see if it is not broke or twisted. If not then your motor is heating up and thios causes it to stop. a new motor would be your problem.
Dec 02, 2008 | Kenmore 63942 Dryer
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Dryers Logo
167 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
