Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
D52W20 won't turn on.
Green Light on power switch comes on for ~10 secs and turns off. Visually checked cp150, cp114 and cp120. All look okay. None are popped, bloated or leaking. Checked VDC on dp110 during power up. Voltage steady at 145 until TV turns off, then to 0 Volts. I used the anode of dp135 as return due to a lack of obvious marked dc grounds. Scanned deflection board and other pcb's for obvious signs and symptoms, but all components look good. My understanding is that the flyback xfmr, horiz osc and horiz out xfmr are good if dp110 voltage is 110/128 vdc. Is the 145 vdc good or does it point to another circuit?
  • 647 Answers
Do you get the high voltage coming up? You can check for this by measuring if there's any voltage at DL231 or/and DL221 (diodes off secondary of flyback). If there is voltage momentarily then the hv is trying to come on and the Flyback is likely at fault (excessive highvoltage detected) if not then usually power supply problem is indicated - Start there - tip-use the tuner shield as ground/return
Posted on Oct 02, 2009
I have a rca d52w20 i unpluged it moved it across room about 20ft will not come on light on power button lights up only for a sec.when i plug it up will not come on at all it use to work like new before i...
Sounds like bad capacitors on the deflection board CP150, CP120 and CP114 specifically as they are famous for failing when you unplug the power cord because they drain and then when the power is plugged back in they cant recharge and the set will not turn off. You can get the repair kit called the CP150 , CP120 Cp114 repair kit at the folloeing link kust scroll down the page it contains instructions its very inexpensive http://tvrepairworld.com/rca_repair_kits
Feb 10, 2013 | Televison & Video
Our 52 inch RCA tv Model #D52W20 will not come on when we power it on. If we keep hitting the on button it will eventually come on. When it first started it would come on in about 10 min now it takes...
Replace the CP150, CP120 and CP114 Capacitors. You can get the RCA repair kit called the ATC221 CP150, CP114 and CP120 repair kit from www.tvrepairworld.com which contains the caps for the ATC221 and ITC222 versions of your model along with the CD with repair instructions.
Apr 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv will not turn on the green light comes on then turns off,it will do this three times ,on and off .then i have to manually push it the button for about 15 minutes untill i can hear it kind of ignite...
Thats usually caused by faiked caps CP150, CP120 and CP114. You can get the RCA repair kit called CP150, CP120 and Cp114 repair kit from www.tvrepairworld.com which has the caps and the CD with instructions.
Jul 29, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca d52w20 it is showing the 19 code. the light is coming on and off 3 times. After severar intents it turn on. Help, please
Very common problem usually caused by CP150, CP120 and CP114 capacitors on the deflection board. You can get the CP150, CP120 and CP114 repair kit from www.tvrepairworld.com which also includes the instructions for the repair.
May 20, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
52"rca hdtv lights blink will not turn on
Thats the classic sign of the CP150, CP120 and CP114 capacitors having failed. By trying to power it up over and over the caps will eventually charge and the set will function untill you power it down. You can get the CP150, CP120 and the CP114 repair kit at www.tvrepairworld.com and the kit contains the CD with repair instructions.
Dec 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a D52W20 green light comes on 3 times but has no power.
Replace capacitors in power supply area
Replace capacitor cp150 (2200mf 16v ) capacitor CP120 and capacitor cp112
Replace this capacitor too: CP114 (330uf @ 35V )
Thank you
Aug 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Television will not turn on
ON the Deflection board look at cp150 (2200uf 16v)- if it is puffed up on top it is bad replace it and 2 more cp114 & cp120- 220uf 35v. Radio Shack should have capacitors. they are green with gold writing on them.
HAPPY NEW YEAR!
Dec 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 inch D52W20 hdtv ready television
Replace 3 capacitors cp150- 2200uf 16v ////cp114 and cp120---- 220uf 35v. buy caps at Radio Shack.
Dec 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
142 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
