Question about Garden
Just bought a used husky gcv 190 from home depot rentals yesterday...guy demo's it worked fine( so the boss says i wasn't there) hooked it up this morning, i have water pressure all the way to the wand and nothin
SOURCE: pressure washer - can't figure out soap
Use your mouth to get the siphon started. That's what I did and mine worked great!
Posted on May 23, 2009
SOURCE: pressure washer not working
OK here is the solution. There are six plastic vaules inside the pump if you have any mechanical skills you can fix this.
These plastic valves melt when you leave your pressure washer running for a short period when you are not pressure washing. once this happens the pump becomes cloged and does not function. I spent alot of time and research on finding the parts for replacement. I called the main company of this washer pump and here is the toll free number
800-999-2245 and the web sight www.pressureparts.com but to save time just call and talk to the service tech tell him you model number and he will give you the part number.
I only paid $13.75 plus shipping around $5.50 I do not work or have any intrest in this comapny but I tell you after all the frustration and run around I had trying to fix this Home depot power washer I deesided to help eveyone else out
I can be reached at atidavid@aol.com if you have any other questions
Posted on Oct 02, 2009
wireguy212
  • 1627 Answers
SOURCE: I have a Husky 2600 PSI power washer with the
You can eliminate the motor by unbolting the pump from it and then if it will start the problem is with the pump or the unloading valve.If it does not start with the pump removed then you check for spark and get the carb cleaned or have a kit put in it.If it does start then check to see if the pump turns freely,if so disassemble the unloader valve and clean and lube it so that the pump and motor can relieve the pressure it needs to when the trigger is not engaged,if the pump can't be easily turned by hand then then pump needs to come apart,dealership should do this.
Posted on Apr 13, 2010
SOURCE: My Husky pressure washer 2600 psi powered by a gcv
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Posted on Aug 09, 2010
puertobori
  • 7733 Answers
SOURCE: Have a Husky Pressure Washer 2200 psi, HU80931. I
Look at eReplacementParts.com and the parts diagrams
Posted on Nov 02, 2010
Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
JUNK Home Depot
Nov 23, 2011 | Garden
Where can you purchase replacement parts for Husky HU80709A power washer purchased from Home Depot? Called Husky, who said they do not manufacture this pump and given 800 number for Ryobi. However, Home...
You use www.homelite.com part lookup for the HU80709. Homelite site doesn't list the a version but parts should be the same. www.jackssmallengine.com is excellent source for parts and is very reasonable on the parts.
Dec 21, 2010 | Garden
I bought a Ryobi RY34420 yesterday from home depot
Sounds as tho it needs a minor carburetor adjustment. It's not getting enough fuel when you pull the throttle. Don't know if the owners manual addresses this issue or not, may want to check.
Dec 23, 2009 | Ryobi Garden
I have a brand new husky 1/2'' air ratchet. It was working fine yesterday and today I went to use it, no go. When I hit the trigger, air just shoots out of the release port. The ratchet does not turn. ...
There could be a couple of things wrong with it. First and foremost make sure your compressor has the correct cfm's to operate the tool. Psi is only half the battle when it comes to air tools. Second, make sure that your reversing switch on the ratchet is properly engaged. Sometimes it will get stuck in the middle. You may have a crimped hose so check the hose. There may have been debris in the line that got into the motor. If this is the case, then you are going to need to have to take it apart to see what is wrong. If you just bought it though you should take it back to Home Depot. I had a customer who basically had the same thing happen. He used the ratchet twice and the valve pin cap just popped off. It is plastic and just broke in two. I tried to look up the part and it is unavailable. Husky is made by Campbell Hausfeld for Home Depot. Sometimes it is not that easy to get parts for certain models. I believe they make a run of tools and then discontinue the line they just made, and do not make parts available. You could try taking it back to Home Depot and swapping it out for a new one. Or my suggestion would be get your money back and by a better brand ratchet like IR or CP.
Sep 22, 2009 | Air Tools & Compressors
HOME DEPOT GENERATOR HUSKY 5000 NEED PARTS LOCATED FOR GENERATO
bring the entire thing back... ask to speak with the manager and demand a brand new unit... (husky is exclusive to home depot..fyi)
if they give you push back ask for the district managers phone number (they have to provide or they can be fired) but they will replace it before he gets envolved..
if that fails try posting this in the correct category (this is motorcycles)
Sep 15, 2009 | 2000 Husqvarna TE 610
Wiring a Husky brand compressor from Home Depot.
hi! there,
you can use terminal connector like on figures83ba8af.jpg joint connector or lug connector
this are more convenient to use
easy to install and has insulated for connection.
insulated ring terminal connector
this is also good for connector more safe for circuit breaker suipply.
go to the nearest hardware or mall
Apr 20, 2009 | Air Tools & Compressors
This is our 2nd new Maytag Performance Series 5000 gas dryer. Bought at Home Depot. Originally bought w/d and they just dumped the pair off. Had to hire a plumber to come and hook the gas up. Washer works...
No solution. In fact we just bought a new 5000 dryer and it did 4 loads before DYING. Will not dry at all and machine definitely is turned on. Currently struggling to get it replaced.
Apr 10, 2009 | Maytag MGDE500V Dryer
Won't install pics
Go into Windows Media Player and click on the goGear icon to delete the demo pics.
Dec 13, 2007 | Philips GoGear HDD6330 MP3 Player
Can't get it out of Demo mode
hi sir,
if all the buttons dont work when pressing it, maybe there is a lost connection of the buttons or buttons are shorted. try to check it out...
hope it can help...
Oct 13, 2007 | Sony STR-DE845 Receiver
Garden Logo
721 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
