Question about Garden
EXCELL 2500 HAS VERY LITTLE PRESSURE WATER SUPPLY FILTER NOT CLOGGED AND CARB JUST REPLACED CANNOT LOCATE PRESSURE SWITCH TO INCREASE
5 Suggested Answers
  • 104 Answers
SOURCE: no pump pressure
Sounds like the diaphragm in the pump unit has failed, the engine and the pump are two seperate things the engine only operates the pump but if the diaphragm is leaking or broken you wont get any pressure
Posted on May 23, 2009
  • 583 Answers
SOURCE: Gas leaking from carb on Briggs and Stratton engine
`v already answerd this,are you slow? with oil in the sump you can do no damage by running the engine with abit of smoke,it will clear up very quickly. i find it hard to believe youhave done the things you claim if you dont know what a carby bowl is!! it is the receptical under the carby,take brigg`s advice and replace the gasket it is needle and seat or flappervalve
Posted on Jul 25, 2009
  • 623 Answers
SOURCE: excell pressure washer honda motor---have fuel
Sounds like the carb is badly clogged internally. If you can remove it yourself, you can soak it overnight in a can of carb cleaner. But keep in mind some of the internal passageways in the carb are as fine a human hair and soaking may not work, it which case go to plan B, new carb. Last resort you could try to find cleaners small enough to get in the passageways of the carb, I've heard of people using wire brush bristles for example. Today's gas is terrible, it does not take long to gum up the carb, if it sits for any time.
Posted on May 03, 2010
Testimonial: "you nailed it..........shitty fuel and clogged main jet..........lets see if it still runs today..Thanks"
  • 13 Answers
SOURCE: Have an excell 2500 honda
the carborater may need a dighafram or carborater cleaning of the bowl
Posted on Jan 19, 2011
Replaced water dispenser still not moving or getting water
sad but we can not look it up as were not given make or model
Mar 26, 2015 | Refrigerators
My water dispenser in my GE Adora stainless side by side refrigerator is not working
Water dispenser doesn't work
  1. Dispenser control board
If the water dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the water dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The water dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the water dispenser is functioning.
  1. Water tube in door is frozen
If the water dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator water dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Water filter
If your water dispenser's flow is running slow check to ensure that your water filter is not clogged. If after checking you determine that the filter is clogged, simply replace the filter. Filters should be replaced every six months to ensure clean drinking water.
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
Feb 22, 2015 | GE Adora DSS25KSTSS Stainless Steel Side...
Why is my Water dispenser not working?
  1. Dispenser switch
  1. Water filter
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Refrigerator Repair Help Troubleshooting and Parts
Aug 17, 2014 | GE Refrigerators
Devilbis Excell pressure washer with Honda engine runs smoothly without wand, but stalls when wand is attached.
If the pressure unloader is not working correctly and/or the nozzle is partially clogged with debris, the engine will be overtasked. Try lowering the pressure by turning the pressure knob to lowest setting and test. If the engine continues to run, gradually increase the pressure. Try using the washer set to about 75% of rated capacity and use max pressure for stubborn stains. Using any machine at max will shorten the life of components. If lowering pressure does not help, then unloader is faulty or stuck. Try storing the unit with oil in the pump. Remove both hoses and infuse oil into water inlet intill all the water is displaced (let set for day or two). Good luck
Sep 27, 2011 | Karcher 2500 PSI Pressure Washer
Excell pressure washer honda motor---have fuel flow---fresh---only runs when carb cleaner sprayed--then dies..........
May 01, 2010 | Karcher 2500 PSI Pressure Washer
Excell 2500 will not start. It cranks up but stalls every time choke is pushed in. Any suggestions? Has oil , gas, and water line was purged of air.
Hi there
It looks like that you have a carb problem .
Try to remove the carb and clean it with carb cleaner . If that does not help the best choice is replace the carb.
Hope this help
Aug 29, 2009 | Garden
I have a problem with my karcher 2500 pressure washer with honda engine it will not start or stay running. I have used starting fluid to start it it starts but won't stay running.
Carb is mostly likely gummed up and should be cleaned. Best option is to dismantle the carb and soak in solvent or equivelant for a couple hours and replace it. Our use Gum Out. Do make sure you have a good spark plug and a strong spark. If you have a fuel filter, then replace it. Check intake filter as well
Aug 05, 2009 | Karcher 2500 PSI Pressure Washer
Jul 25, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Stalling
likely you air to fuel ratio is too lean, runs mean and hot but under load dies. then floods the carb.
when it happens pull the plug ,
kill engine :
is there a lot of gas or none.
remove the filter and watch the action of the carb does it open and close easily is the filter clean.
try supplying it more gas turn the gas supply screw 1/2 CCW and see if it will stay running, if not add more.
( NOT the idle screw on the carb side w/spring )
By the way did a bit of water come out if not the clutch/pump may be binding or stuck with soap goop.back flush with hot water.
Apr 13, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
184 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
