Question about Dell 1720dn Laser Printer
Poor quality of printing, paper has lines on the right margin
5 Suggested Answers
SOURCE: problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Posted on Feb 10, 2009
  • 135 Answers
SOURCE: hoirizontal white lines and poor quality in black
If you are sure your ink cartridge is not empty, it may be worth running the head cleaner a few times then print a test page.
Worth a try for nothing.
Good luck.
Posted on Feb 23, 2009
SOURCE: My DELL 3010CN is printing a thick black line on
Often Toner sticks to fuser. When the fuser heats the toner comes off onto the paper. Should reduce over time unless toner is spilling onto the fuser in the same place.
Change fuser and toner
thanks
Posted on Apr 29, 2009
tbirdfan1
  • 3051 Answers
SOURCE: poor print quality
Hello there:
this is normally due to a dirty print head or the nozzles is clogging up
If you have ran your maintenance for the print heads and cartridges several times at least 4 in a row and this still does not clear up and you have tried to get new ink cartridges.
Go to your local printer supply center like office depot or staples and get the print head flush kit this is a specially formulated liquid that you install and it flushes out the print heads and gets all of the ink that has built up in the system out and gets the print heads cleaned it cost about 6 bucks but well worth it
Hope this is very helpful for you
Best regards Mike
Posted on Jan 19, 2010
Small black lines print at the right side margin
Good day!You can clean the drum of the cartridge by wiping a clean cotton in it..mybe its dirty on that part..
regards,
mastergani
Mar 21, 2010 | Office Equipment & Supplies
Poor print quality
hi you can go to the printer icon in printers&scanners right click the printer, then go to properties, in that you will find the settings for print quality depending on how good you want them you have 3 or 4 options, obviusly to have the best print you need to change it to the photo quality, also change the paper quality to, do not have just plain paper, change it to high quality inkjet paper, this way you can get a realy good quality print....hope this helps
Feb 22, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Poor photo printing quality with new color cartridge
Shaking these cartridges does nothing except give you a little exercise. If this is a brand new HP cartridge you are having problems with I would return it to the store you purchased it from. HP brand cartridges should not give you these problems right out of the box. The print defects you are seeing are due to a dried up or clogged print head. If you like you can try hydrating the print head on a water soaked paper towel until the ink starts flowing, but there's a risk you will cross contaminate the colors.
Oct 08, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Print wedding announcements and the print is not straight
Card stock on an HP can be a nuisance, due to the paper feed path. The stock has to curl around the platen.
Some things to check: Make sure you are telling the print driver you are using card stock. It should be in the printing preferences as paper type. The printer will respond differently, knowing it has the heavier paper. Also make sure that your paper guides are adjusted to fit the smaller stock. Just putting in 5.5 x 8.5 paper into an 8.5 x 11 tray may cause it to skew.
I am assuming that you are already telling it to print high quality, as it is for a wedding announcement, but make sure that you are. Slowing down the paper feed speed by putting it into high quality mode can help.
Your printer is an older model, so it could be that the rollers are wearing down, and it just can't feed the last bit as well. You could try to print it in "landscape" mode. Turn the paper 90 degrees in the paper tray, so that the 8.5" is the feed side. This will allow the printer to have a better grip on the paper as it goes through. A word of caution with this method, though. HP's have a 1/2 inch margin at the bottom of the paper where it can't print. Turning the paper 90 degrees will force you to have a side margin of 1/2 inch. Currently, your bottom margin has to be 1/2 inch. I don't know what your layout looks like, so I don't know if you can turn the paper.
If you are the one getting married, the congratulations, good luck, and mazel tov! (Have to cover all the basis).
Jul 17, 2009 | HP DeskJet 5550 InkJet Printer
Poor, faded print quality on left and right sides of paper
Have you check the teflon at the heater? have you clean the reflector of laser? Try that.
May 30, 2009 | HP LaserJet 8550 Printer
Poor print quality .... Canon Pixma MP140 ...
Paper quality does make a difference in the quality of print, but it's usually in the areas of blurriness and vibrance. If your prints are coming out faded, the quality for your prints might be set to 'economy', which doesn't use very much ink. If you have it set for 'quality' prints, I would try replacing the ink cartridges.
May 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
WHILE TRYING TO FIGURE OUT WHY MY PRINT QUALITY IS SO POOR. AFTER CLEANING THE HEADS A FEW TIMES I WENT TO PRING A "QUALITY TEST PAGE". The MFC said i was out of paper. i refilled the paper (with the...
the messages you get for cartridges other than the original are not trustful. You will get the right reading for original(from Brother) cartridges. Some ink is poor for printing photo quality.
not any refillable ink is right for printing photos, sometimes too dark, sometimes you don't get the right mix of colors.
Mar 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
Print is not centered on paper
There are two possible culprits for this problem.
1. The wrong driver is being used for your printer.
2. The paper thinks it is printing to different sized paper than it actually is.
To solve the first case:
Verify that the correct driver is being used. Go to the Control Panel (Start, Settings, Control Panel) and open up the Printers and Faxes component by double-clicking on it.
Right-click on your printer and go to Properties.
A new window will pop-up. Go to the Advanced tab and verify next to where it says 'Driver' that it lists your model of printer.
To solve the second case:
Exactly as you did above, under the Advanced tab, click on the 'Printing Defaults' button.
Then click on the Paper/Quality tab on the new window.
Under the Paper/Quality tab click on the 'Advanced' button.
A new window will pop-up. Where it says Paper/output, expand it (click the plus) to list Paper size. Change Paper size to match the size of the paper you are printing (Letter is the default 8.5" x 11").
Nov 22, 2008 | HP Photosmart C3180 All-In-One InkJet...
Margins not recognised
Hi lerona - I have a 5600C series HP printer. You might try these tips:
Do a Print Preview to be sure the document looks right on your screen, then in Print Setup, down in the Zoom box check the Scale to Paper Size to be sure it isn't set for the wrong paper size. There's an arrow to scroll to the size you're printing on.
Then click Properties, then the Paper Quality tab. There's an item that says "minimize margins". You could try printing with the box checked (if it's not now), or unchecked (if it IS now) and see the difference. Click the Effects tab and be sure the "normal size" box says 100%, and that there's no check mark in the "borderless printing" box.
I print documents all the time, as well as photos, smaller sized items, cards, etc., and have had no trouble with the margins printing differently than my Print Preview shows on my screen. I hope these tips help you. Good luck, and feel free to email me if you have any success with my suggestions.
Jo
JokerGirl524@aol.com
Oct 28, 2007 | HP DeskJet 5150 InkJet Printer
Dell 1720dn Laser Printer Logo
52 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
