Question about Caterpillar Cat Pump Pressure Washer Pump 2.5 Gpm, 2750 Psi, 5 Hp To 6.5 Hp Required, ModelNo. 3DX25GSI
What type of oil does the pump use? how much?
  • 4 Answers
8.5 oz. to the red dot on the site glass.
SAE 30 / 30 wt Non Detergent Oil from your local auto parts house.
Posted on Jan 03, 2011
Where is the oil pump relay on a 1998 Chevy S-10
Your kidding right ? The oil pump is mechanical not electric , no relay .
Full pressure lubrication, through a full-flow oil filter is supplied by a gear-type oil pump. Oil is drawn up through the oil pump screen and passes through the pump to the oil filter.
Jun 25, 2015 | Cars & Trucks
What type of oil for XL honda motor with Cat pump
the motor 30wt oil or 10- 30wt, the pump takes pump oil or 30wt
non-detergent, so the answer is no they don't take the same
Sep 14, 2014 | Honda Garden
Oil pump does not work
Checlk the oil worm gear is driving the pump. If this isnt the problem then try the following:-
The type of oil pump fitted to these models is prone to getting blocked.
Remove the oil pump. The gear on top should turn freely, give the pump a clean and clean the oil pipe to the tank by removing the oil cap and blowing through with an air line. If the oil in the tank contains alot of dirt, empty/clean and replace. The filter on the oil is an open plastic cage type and often will draw large sawdust particles through it. Easily rectified tho.
Aug 24, 2012 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Dont get correct pressure. What type of oil do i
A loss of pressure on this type of washer is normally caused by failing water seals and check valves in the pump. You will need to replace both of these using a pump rebuild kit that will be available by contacting the manufacturer of your machine. The pump oil used will be 30W non-detergent.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Feb 28, 2011 | Black & Decker 1700 PSI Electric Pressure...
What type of oil is used to fill the a FAIP PV93501 pump and what quanity.
I don't know about that brand of power washer.
We used several types of power washers over the years, and they each called for 20 or 30 weight non-detergent oil in the pump. SAE 20 or SAE 30
The pump oil comes about half way up inside the pump.
The engine oil is 10W30
Do not turn a power washer on its side or upside down or oil will run into carburetor.
Oct 14, 2010 | FAIP 2100psi 2gpm Faip Power Pressure...
My oil light is on and oil sensor has been replaced possible oil pump failure?
If the oil is at the proper level and has the proper type of oil in it then it could be a bad pump or a clogged filter. Replace the oil filter and make sure you have the proper oil type in the vehicle. If this doesn't resolve the issue then look at replacing the pump.
Jul 08, 2010 | 1999 Chrysler 300M
Oil type
these pumps are supposed to be sealed and not to be able to oil,,
Jun 28, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Do you have to use oil in the pump and if so type,how often.
water pumps doesn't require oil in the pump; but your engine does require. if the water pump is of "self priming" type, fill the pump casing with water before starting the machine to avoid damage to the water seals.
May 22, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Vacuum pump oil
If you are using 6CFM vacuum pump then it's need 16 OZ.of oil & you should change every 10 Hrs of vacuuming.You can use Yello jacket vacuum pump oil also.
Feb 02, 2009 | Robinair 13204 Premium High Vacuum Pump...
Caterpillar Cat Pump Pressure Washer Pump 2.5 Gpm, 2750 Psi, 5 Hp To 6.5 Hp Required, ModelNo. 3DX25GSI Logo
433 people viewed this question
Top Caterpillar Garden Experts
J.D. Browning
J.D. Browning
downhille
Bill Boyd
Are you a Caterpillar Garden Expert? Answer questions, earn points and help others
