I have a Xerox docuclor 12 printer. I am getting a fault/ error code of 10-300. Lower right door open. But, it is closed. How can I clear the error code?
    Guru:
  • 389 Answers
Include device, open lid, press [MENU], [6], [4], [CLEAR], [ENTER]
Posted on Oct 03, 2009
Code:08-100,what this code means?
Error means the leading edge of the sheet of paper did not arrive at the preregistration sensor in time, causing a jam.
To fix - Open the inverter door and clear area 14. Open the printer right front door and clear area 2. Retry printing.
Nov 06, 2014 | Xerox WC 4150 NETWORK ACCOUNTING...
Xerox Phaser 8860 error 09,005.40:71198
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Oct 30, 2014 | Xerox Phaser® 8860/8860MFP Extended...
FAULT CODE 094-322. WHAT CAUSES IT AND HOW DO I GET RID IF IT?
ERROR CODE 094-322 RAP Second BTR Retract Failure
The error relates to the Second bias transfer roller not retracting. It could be a fault with the roller but i would open the transfer draw and check the connections and seating of everything and try it again. More often than not this clears the error.
Jun 24, 2011 | Xerox DocuColor 12 Color Copier
Xerox 4595 gives me a fauld code 010-315
Check that the front door magnets are still attached to the door. They can come out of their holders and this will cause the front door not to close properly. They are easy to snap back in. Squeeze the sides,then put it back in it's holder. There are 2 magnets. One on the upper corner and one on the lower corner. You must reset the power to clear this error. Also check that the door closes properly by holding the top right side shut. I have had to bend the door switch bracket out to make proper contact. Check that the cover of the duplex tray is all the way on,too. If it is loose on the lower right corner it can interfere with the front door. After checking these items,reset the power to clear code.
May 31, 2011 | Office Equipment & Supplies
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
How can i clear error c-0521
To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note : On the7915/7920,after opening the front door,it is in the lower right corner.
2. Insert a suitable object into the hole to actuate the reset switch .
3. The code should clear and a message to close the front door should appear.
Dec 06, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
XEROX 8550 DP ERROR
when are you getting this error message?
Oct 28, 2008 | Xerox Phaser 8550DX Laser Printer
Phaser 7700 gx getting false errors all ove the printer
It might be somthing with the side cover not sitting right. If you feel comfortable doing it, remove and reseat the right side cover. I had a similar problem and this fixed it.
May 29, 2007 | Xerox Phaser 7700 Laser Printer
k24674
