Question about Refrigerators
I have a side by side kenmore, modle 106.9545720. The ice maker will not fill with water to make ice.
  • milten1
    milten1 May 11, 2010
    please check you water filter
peyton32034
  • 410 Answers
SOURCE: Maytag ice maker wont fill upwith water
is the icemaker cycling at all? pull the front cover offf of the icemaker and verify that the gear isnt broken. if so replace the motor module. if thats ok the next 2 things could be either a frozen fill tube or bad fill valve..
Posted on Dec 12, 2007
SOURCE: ice maker not filling with water
I have a model KSRG25F and found that the solenoid that controls the water to the icemaker was not working. I tested by switching the water dispenser connection to the ice maker coil.
And then had the wife push the water fill in front of the fridge. I had aready changed out the control board in front because I didnt have the flash codes or solid led when simulating door closed. the parts is about $55 and hope that does it. Good Luck
Posted on Jul 05, 2008
  • 149 Answers
SOURCE: Ice maker water tube keeps freezing
u can replace the plAstic one with a copper one
Posted on Oct 27, 2008
duby1990
  • 370 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
freetek
  • 5568 Answers
SOURCE: amana side by side ice maker will not fill with water
Old message, I'm sure you have solved your problem by now, but . . .
IF
 Amana/Whirlpool conforms to wiring standards (no guarantees), the main AC wires should be white=neutral, black=hot, red=switched line.  Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
It would be kind to post back what you found as it might benefit others in the future.
Thanks-
Posted on Jan 09, 2009
Modle # 106.55639500
The ice maker has gone bad and will need to be replaced. Here is the ice maker kit to order.
Jun 27, 2013 | Kenmore 57029 Side by Side Refrigerator
Kenmore 5483300 side by side. no ice!
your fridge will have a dual water inlet valve, one for water and one to supply water to the ice maker. it could be that the solenoid on the valve that supplies water to the ice maker is not working.
Nov 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice Maker does not work.
Check the line going to the ice maker for clogging.
Sep 25, 2009 | Kenmore 57029 Side by Side Refrigerator
Water not dispensing to fill up ice maker
Hi: Make sure your freezer is at zero degrees F. It will take 24-72hrs for an ice maker to produce when the freezer is at 0 degrees. Only then will the water fill the trays. I hope this helps, Jeff
Jul 07, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore 106.56662500 side by side. The
you will need to check your water valve on the fridge itself if it has a double valve. if it has a single valve and the water comes out of dispenser in the door then it is probably going to be the ice maker itself.
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
THE ICE MAKER WILL NOW ONLY MAKE A FEW CUBS
Our Kenmore ice maker GSI23 has stopped making ice cubes, the water still flows out the front, the sensor arm is down and we have pushed on the O button numerous times but still no ice. Help please
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
