Question about Nokia 6300 Cellular Phone
Phone cannot find new audio enhancements
Phone cannot find a device when new audio enhancements are sought trying to set up a bluetooth device
How do i pair my jabra easygo to my phone
Hold your blutooth switch on button at few second the light at bluetooth is starts to blink now open bluetooth menu in mobile select pared device and select search new device or go to blutooth menu and select search audio enhancement
Apr 20, 2013 | Jabra EasyGo Bluetooth Headset
How to pair the samsung wep450 with another cell phone
samsung wep450 bluetooth headset
This device is connected all mob. device and all androids,
How To Connect: You Need first power off and after 5 sec. Power on button press 10 sec. continue, and this time search or refresh your mobile Bluetooth . and Connect .
Nov 21, 2010 | Samsung WEP450 Bluetooth Headset - Retail...
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
Ensure that your phone is switched
on and the headset is switched off.
2. Press and hold the power key until
the green indicator light starts to
flash quickly.
3. Activate the Bluetooth feature on
the phone, and set the phone to
search for Bluetooth devices.
4. Select the headset from the list
Feb 09, 2010 | Nokia BH-208 Wireless Headset
I am connecting my o2 jet to my car via 'bluetooth'. The car asks me to input a code 1212 into the phone. How do I do this?
  1. You need to turn bluetooth on, on your device.
  2. Search for audio enhancements or bluetooth devices.
  3. Connect to your car bluetooth once it has found your car
  4. Your device will then prompt you to enter a passkey, enter 1212 and it will pair with your car.
Sep 01, 2009 | O2 Jet Cellular Phone
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Jul 11, 2009 | Nokia 3110 Cellular Phone
Motorola Bluetooth Headset MOTOPURE H12
My H12 manual has the passcode as 4 zero's for most phones.
Feb 05, 2009 | Motorola Mobility Motopure H12 Bluetooth...
I am trying to program my nokia 2600 phone to my motorla h700 blu
First of all, the Nokia 2600 is not a blue tooth phone.
If you should get a Nokia phone that supports blue tooth your best bet would be to make sure any previously paired devices are turned off.
Then make sure that blue tooth is enabled on your phone. For most Nokia models its as follows;
Menu > Settings > Connectivity > Bluetooth > Bluetooth On
Then attempt to put your device in pairing mode.
Return to;
... > Bluetooth > Search Audio Enhancements
If your phone supports Bluetooth the phone should and device should pair after you enter the pairing pin, usually 0000.
Johnny_Nh, to answer your question, different Models are equipped with blue tooth when they are manufactured. Also, there are different versions of bluetooth, 1.0 and 2.0. If you have an older phone supporting Bluetooth 1.0 you will not be able to use a bluetooth 2.0 headset.
Dec 26, 2008 | Motorola Mobility H700 Wireless Headset
Dan8888 seeking help
Strange. I'm wondering if there's a difference in the software between your original phone and the one you have now, something like that which is causing the problem. Your new phone I'm assuming is the same type as the old one right?
Have you made sure that the phone you have now doesn't already have a bluetooth device in its pairing memory? I know on my razr I could only have one device assigned to the phone, and I had to delete that one before I could pair a new one up.
Aug 29, 2008 | Plantronics - Bluetooth Headset Plus Base...
Don't know the pin to set up my bluetooth
Most Motorola bluetooths have a default passcode of 0000 and cannot be changed.
Mar 14, 2008 | Motorola Mobility RAZR V3
Nokia 6300 Cellular Phone Logo
43 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
