Question about HP Computers & Internet
Cant get icons or tool bar go to task manger and new task,type in explore.exe and get cannot access path or file. i may not have the appropriate access to the item
    Problem Solver:
  • 5 Answers
Depending on what os if drag and drop does not work you may have to copy paste if copy paste does not work you may have to reinstall the program and select add to quick launch
Posted on Oct 03, 2009
    Genius:
  • HP Master
  • 1,274 Answers
Probably because it's explorer.exe,
Explorer.exe errror
if you having trouble with explorer.exe not opening on start up then there is something potentially wrong, an easy way to get around this is to press [ctrl+shift+esc] this will open task manger, then click file and new task and type explorer.exe, this will now boot the process into life.
if it is a regular thing try booting into safe mode to see if it reoccurs if not but does normally work out when it last worked fine and then back track your installed programs
Jan 09, 2014 | Sony VAIO Computers & Internet
No start task bar in safe mode
It sounds like explorer.exe is being turned off. When you log in to Safe Mode hit Ctl+Alt+Del to bring the Task Manager and see if explorer.exe is running under Processes. If not, you can go to the Applications tab in Task Manager and click the New Task button and simply type in explorer.exe.
If this does not give you your Start Menu and Task Bar then you need to take your computer back to the repair service and have them fix it properly this time. Otherwise, you'll have to reinstall the operating system.
Jul 06, 2012 | Dell OptiPlex GX260 PC Desktop
On starting up my d800 dell,all i see is a blank page with only the mouse cursor,i have use ait,ctr,del, to enter task manager,i cant find explorer.exe in the processes, It all started after i install...
Click Ctrl+Alt+Delto get to Task Manager. Hold the Ctrl key, plus Hold the Alt Key then hitthe Del key while holding them.Once the task manager opens Clcik the Processes tab then click the Image NameColumn heading on the left to get them in alphabetical order. Scroll downand look for explorer.exe. If you see it click it to highlight it thenclick End Process.
Next, click the FILE tab at the very top left of the window and select New Task(RUN). When the Create New Task window opens type explorer.exe and pressok. Your start menu, task bar and desktop icons will start appearing andpopulating. if not that means a virus has hidden your files and folders.
May 27, 2012 | Dell Computers & Internet
Help me to uninstalled think point
ONE WAY USE WINDOWS DISK TO RESTORE ALL SYSTEM FILES.
OR TRY USING THESE STEPS:-
1. Restart your computer. Once the ThinkPoint window comes press Ctrl+Alt+Delete or Ctrl+Shift+Escape. You should now see the Windows Task Manager screen as shown in the image below or a screen where you can select the Task Manager to be run.
Click on the Processes tab. Then click and highlight hotfix.exe and click End Task. If it asks you "Are you sure you want to terminate the process?" click yes (or press Enter). This will close the ThinkPoint program.
2. While in Windows Task Manager, click the File -> "New Task (Run...)" from the menu on the bottom right. Type in explorer.exe and click OK. Your desktop and icons should start up as normal.
NOTE: if you got an error message "Windows cannot access the specified device, path or file. You may not have the appropriate permissions to access them", then please run this command first:
cacls "C:\Windows\explorer.exe" /G Everyone:F
A new windows will come up asking "Are you sure?" Type Y and press enter.
Now run explorer.exe again.
3. Download the following file to your Desktop: windows-shell.reg. Double-click to run it. Click "Yes" when it asks if you want to add the information to the registry. This file will fix the Windows Shell entry. This step is important because if you won't fix this entry, then your Windows Desktop will not be displayed the next time you reboot. Once the new registry value has been added, you can delete the file from your computer.
AFTER ALL, USE A GOOD ANTIVIRUS AND TRY TO CLEAN YOUR SYSTEM WITH IT.
Dec 09, 2010 | Computers & Internet
I can not start Internet explorer. I click on the icon and it does not start.
Hey,
1. try to open the windows explorer and in the address bar type the address of any website.
2. right click on the task bar and then choose the option task manager, select the tak processes and then check for instances of the application iexplore. In casse there are multiple, select one and click on end process. repeat the same for all instances
3. In case still inaccessiable, try to restart the computer.
4. If the issue still persists, try uninstalling the application using the control pannel and add remove programs, Add remove windows components.
If the problem still persists, use a different browser
Jul 12, 2010 | Microsoft Internet Explorer 8
I HAVE A WINDOW XP HOME EDITION AND WHEN I START MY COMPUTER THE ONLY THING THAT COMES UP IS THE BACKGROUND. THERE ARE NO ICONS OR A BAR AT BOTTOM OF SCREEN.
the icons and the bar(task bar) at the bottom of the screen are enabled by the explorer.exe file
it starts automatically but in your case it is not starting
to start it when your computer starts and comes at the desktop, press alt+ctrl+delete button at the same time to bring up the task manager
when you do this a task manager shows up in a window
in task manager window click on file, it will be located on the top left portion on task manager
now click on "new task(run)"
this opens another window, in that window type
"explorer"
without the quotes "" and press enter
this will bring you icons and task bar at the bottom of the screen
Sep 29, 2009 | Computers & Internet
Windowx xp booting time no icons appear.
Changing the default shell (all users):
1) open regedit (start menu > run, and type in regedit)
2) go to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon.
3) Change Shell from explorer.exe to the new shell path e.g C:\Litestep\litestep.exe
4) log out and log back in.
Changing the default shell (only current user):
1) open regedit (start menu > run, and type in regedit).
2) go to: HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Winlogon.
3) add a new string value (Edit > New > String Value) called shell. and set the value to the path of the new shell e.g C:\Litestep\litestep.exe.
http://support.microsoft.com/kb/228309
May 09, 2009 | Computers & Internet
Acer boots up and gos to wallpaper but there are no start icons o
try this for me when you get to your desktop
press ctrl+alt+del, youll get your task manger up, from the file option select new task (run) and type explorer.exe in there then hit ok
check to see if the explorer.exe is running in the processes tab before you add it, if its there right click and end process
let me know what you get,
Apr 28, 2009 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Internet Explorer problem
Step 1: Use Windows File Search Tool to Find msas2009.exe Path Go to Start > Search > All Files or Folders.
  1. In the "All or part of the the file name" section, type in "msas2009.exe" file name(s).
  2. To get better results, select "Look in: Local Hard Drives" or "Look in: My Computer" and then click "Search" button.
  3. When Windows finishes your search, hover over the "In Folder" of "msas2009.exe", highlight the file and copy/paste the path into the address bar. Save the file's path on your clipboard because you'll need the file path to delete msas2009.exe in the following manual removal steps.
Step 2: Use Windows Task Manager to Remove msas2009.exe Processes
  1. To open the Windows Task Manager, use the combination of CTRL+ALT+DEL or CTRL+SHIFT+ESC.
  2. Click on the "Image Name" button to search for "msas2009.exe" process by name.
  3. Select the "msas2009.exe" process and click on the "End Process" button to kill it.
Step 3: Detect and Delete Other msas2009.exe Files
  1. To open the Windows Command Prompt, go to Start > Run > cmd and then press the "OK" button.
  2. Type in "dir /A name_of_the_folder" (for example, C:\Spyware-folder), which will display the folder's content even the hidden files.
  3. To change directory, type in "cd name_of_the_folder".
  4. Once you have the file you're looking for type in del "name_of_the_file".
  5. To delete a file in folder, type in "del name_of_the_file".
  6. To delete the entire folder, type in "rmdir /S name_of_the_folder".
  7. Select the "msas2009.exe" process and click on the "End Process" button to kill it.
MSAS2009 IS SPYWARE!
good luck!
Feb 02, 2009 | Toshiba Satellite A100-S8111TD Notebook
Blank desktop, no start button
open task manger > applicatiins tab > selct new task> type explorer then ok then the desktop will coome uo
Dec 22, 2007 | Northgate STAC2217L (Bundle) PC Desktop
Computers & Internet Logo
56 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
