Question about Garmin StreetPilot C330 GPS Receiver
Tip on plug in has been lost. When I plug in the unit into my car's cigarette lighter it does not charge the unit.
    Top Expert:
  • Garmin Master
  • 75,817 Answers
Buy a new car charger, they are avil on ebay very cheap.
Posted on Oct 02, 2009
Nuvi will not charge when plugged into car charger but will charge when plugged into house charger
  1. Check that the cigarette lighter socket is working. If not it may be a fuse blown in the fuse-board.
  2. In the charger plug, that goes into the cigarette lighter there is a fuse which may be blown. At the tip of the plug you'll see a ring. On most chargers it's silver but some are black. Unscrew the ring and the plug will come apart. Take care not to lose the small metal tip when you open it. Replace the fuse. If there's power going to the charger and this fuse is replaced your problem should be solved.
Dec 17, 2010 | Garmin Nuvi 770 Car GPS Receiver
I brought a new Garmin nuvi 1490T recently from Staple. The only problem is the GPS would not be charged when I use in my car. (the cigarrete lighter is in good condition). I tried to use another new cable...
The cigarette lighter adapter has a fuse in it, Carefully unscrew the Silver tip of plug, Carefully its spring loaded... and check the fuse..
Did you buy your unit with a credit card? If so you could possibly get a receipt,
Did you Register your unit with Garmin? If so they would have some kind of record when you brought it.
Nov 03, 2010 | Garmin nuvi 1490T GPS Receiver
My garmin nuvi 650 na keeps depleting its battery even though I just fully charge it on the computer. It also does not charge when I plug it in the cigarette lighter in the car. The screen turns dark...
well if you have the factory car charger. There is a fuse inside of it. This is indicated in the manual. But it could also be the cigarette lighter fuse in the car is blown. I would make sure the cigarette outlet has power. If the cigarette lighter has power and you have the factory power cable that has a fuse try this. f the unit will not charge in your vehicle, you might need to replace the fuse that is located at the tip of the vehicle adapter.
1. to change the fuse unscrew the black, round end piece on the vehicle power adapter and remove it. inspect the fuse to see if it is blown. If not end here.
2. if determined the fuse is blown remove the fuse (glass and silver cylinder), and replace it with a 1A fast blow fuse.
3.ensure that the silver tip is placed in the black end piece. screw on the black end piece
let me know how this works by following up with a comment and i can instruct you on where to go from here. Thanks.
Aug 26, 2010 | Computers & Internet
Is the cigarette lighter also the plug for cell phone charger?
The cigarette lighter plug should also work for the phone charger as long as the phone charger uses the cigarette lighter style plug(long with two metal contacts on the sides and a button contact on the tip). Most standard car chargers will fit both cigarette and auxillary style plugs.
Dec 29, 2009 | 2004 Ford Focus
My garmin charges with my computer but stopped charging in the car
The most obvious answer is a possible blown fuse in the cigarette lighter socket or the in the tip of the charger plug. Most charger plug fuses are accessed by unscrewing the metal tip. Check both for good fuses.
If this doesn't solve the problem, make sure the points of contact between the charger, cradle and GPS are all free of dirt and grime. Don't forget to vacuum the cigarette lighter socket - especially if it is used as a lighter, too.
Sep 16, 2009 | Garmin nuvi 200W GPS Receiver
Fuse blown on cigarette lighter Saturn 2001
It sounds like you have a bad charging cable for the GPS or the cable is overloading the cigarette lighter.
The cigarette lighter is designed for less power then a 12v power outlet.
Therefore it is easy to blow the fuse for the cigarette light if you install something that draws too much power.
Jul 07, 2009 | 2001 Saturn S-Series
Unit (tom tom 1xl) turning off
One hour is about the time the unit will run without a power source.
You need to check that the cigarette lighter is working. Check the car fuse.
Check the fuse (one of the six bumps) on the cigarette lighter plug has not blown.
Is the cigarette lighter / Tom Tom lead damaged in any way?
Peter
Mar 01, 2009 | Tomtom One XL GPS Receiver
Can not figure out how to charge the Vector start it pro
Easy, just insert the "cigarette lighter style" plug from the A/C charger into the "cigarette lighter style" socket on the top of the unit, and then insert the A/C adapter in to a wall socket. It can also be charged in your car with a cord that has double "cigarette lighter style" plugs at ether end, one inserted in the Vector and the other in your cigarette lighter.
Wait, one more - clamp the units cables properly on to your cars battery terminals, then start your car. periodicly checking for full charge.
Hope it helps... Good luck
Feb 21, 2009 | JUMP START SYSTEM
How to recharge the unit
you can charge it via the usb or cigarette lighter.  either method will work and i am not aware of any problems created by using the lighter.  that really should be the primary charge method as it is expected to be used in the car.  is it charging on your computer.  if it is, but not on the lighter you may want to ensure that the lighter is itself working correctly and then also check to make sure that the fuse in the car charger is intact.  just a few suggestions
Dec 25, 2007 | Garmin StreetPilot c510 Deluxe GPS...
Garmin StreetPilot C330 GPS Receiver Logo
79 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
