When I go to print iget There is a problem with
When I go to print iget There is a problem with the printer. Both cartridges are new. I also can not scan.
4 Suggested Answers
  • 44 Answers
SOURCE: have just bought new printer
ensure that you remoove sticker before incert catridge
Posted on Jul 08, 2008
ikechinedu
  • 184 Answers
SOURCE: Printer wil print when scanning but not from computer
There are a few steps you will need to follow to resolve this problem. Follow these steps one after the other. start with the first step. after each step, try to print and see what happens. if your problem is resolved, ignore the other steps.
Step one: Clear any paper or carriage path obstructions
1.
With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2.
Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3.
Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4.
Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5.
Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6.
Press the On button to turn on the product.
Step two: Ensure correct installation of the front panel overlay
If the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, ensure correct installation of the front panel overlay by following the instructions below.
If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to re-install the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
NOTE: If you have already installed the front panel overlay, proceed to the next step.
1.
Disconnect the power cord.
2.
Locate the front panel cover and peel off the paper backing to expose the adhesive as shown in the graphic below.
3.
Lift the scanner lid and carefully line up and install the front panel overlay.
4.
Plug the power cord in.
5.
Try the print job again to see if this step resolved the issue.
If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
If the issue is not resolved , continue to the next step.
Step three: Plug the product directly into a wall outlet
Verify that the product is properly connected to a suitable power source by following the instructions below.
1.
Verify that the computer and the all-in-one product have a three-prong power plug.
2.
Unplug the power cable from the back of the all-in-one.
3.
Unplug the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
4.
Plug the power cable into the back of the all-in-one.
5.
NOTE: If the product prints when plugged directly into a wall outlet while unplugged from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
Step four: Perform a partial reset
A partial reset will return user settings to factory defaults. you may have, language and country/region settings also resetted. Perform a partial reset of the product by following the instructions below.
1.
Unplug the power cord from the unit.
2.
Reconnect the power cord into the unit.
3.
When the lights begin to flash, press and hold the On/Resume and Paper Size buttons.
4.
When only the On/Resume light is flashing, release the buttons.
When the On/Resume light is steady, the reset is complete.
5.
Step five: Remove and re-install the print cartridges
Improper placement or installation of the product's print cartridges can cause the product to indicate a carriage stall error condition. Ensure correct installation of the print cartridges by following the instructions below.
1.
With the printer plugged in and turned on, open the cartridge access door (see the illustration). After a moment, the print carriage should come to the center.
The print cartridge carriage is the plastic part that holds the print cartridges.
NOTE: If the carriage does not come to the center, try turning the printer off and on.
2.
When the carriage is at the center of the access area, unplug the printer.
3.
Remove the cartridges from the carriage and check them for damage. Check for obstructions under and around the carriage. Replace any damaged cartridges.
NOTE: Try to inspect and reinstall the cartridges as quickly as possible, so that they do not dry out. Avoid touching the copper-colored parts of the cartridge.
4.
Reinstall the print cartridges.
The black or photo cartridge goes on the right.
The tri-color cartridge goes on the left.
5.
Close the cartridge access door, plug the printer back in and turn it on.
6.
Step six: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on May 19, 2009
sam_ajayi
  • 74 Answers
SOURCE: colors are off even with new cartridges
change toner
Posted on Dec 13, 2009
The printer doesn't print all the in their entirety. Some lines are fine but many are not.
Think you need a new print head which is a component in your printer. Canon ink cartridges just contain ink. HP, on the other hand, have ink cartridges with the print head built in to the ink cartridge so that every time you buy a cartridge you basically have a new printer.
Oct 08, 2015 | Canon PIXMA MX452 Wireless Office All In...
My hp d2360 is not working properly and i bought new cartridge but printer wasnt recognize the cartrige..
Please follow the steps below to install the Cartridge:
Install or replace the print cartridges
  1. Turn the printer on. The cartridge cradle will not move if the power is not on.
  2. Open the printer cover. Figure 1: Printer cover openc00658567.gif
  3. Wait until the print cartridge cradle moves to the center of the printer and is idle and quiet.
  4. If you are replacing a print cartridge, press down on the print cartridge to be replaced, and then slide it out of the print cartridge cradle. If you are installing print cartridges for the first time, go to the next step.
    NOTE: HP recommends using a print cartridge protector to store an opened print cartridge for later use. Figure 2: Print cartridge being inserted into a print cartridge protectorc00658568.gif
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 3: Removing the protective tapec00658569.gif
    CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts. Figure 4: Print cartridge facing upc00658570.gif 1 - Ink nozzles 2 - Copper contacts
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 5: Installing the print cartridgec00658571.gif
  7. Repeat steps 3-4 for the remaining print cartridge.
  8. Close the printer cover. The printer automatically prints a calibration page.
Mar 07, 2011 | HP Deskjet D2360 InkJet Printer
I have a smudge on the right side of paper when printing on my lexmark E250dn printer. How can Iget rid of this smudge?
You have a mark on the drum. Find the drum cartridge and rotate the drum by the gear until you find a mark on the surface of the drum. You can try wipe it off with a very soft dry cloth but it is unlikely that this will be a cure and you will probably have replace the drum cartridge (+ $70). Do not try to clean it with any solvents or polishing material.
Feb 02, 2011 | Lexmark Office Equipment & Supplies
How do I insert new ink cartridges in my HP 4385 all in one printer?
Buy a New model of printer... not that HP 4385... it so cheap yah...
Sep 23, 2010 | Computers & Internet
What is the replacement printer for HP Laser Jet
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions. Print cartridge life expectancy The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges. Changing the print cartridge Follow the below instructions to change the print cartridge:
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box. Figure 1: Removing old print cartridge c00028312.gif CAUTION: To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
  2. Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge. Figure 2: Gently shaking new print cartridge c00028313.gif
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling. Figure 3: Removing tape from print cartridge c00035442.gif
  4. Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door. Figure 4: Inserting new print cartridge c00028315.gif
Apr 20, 2010 | HP LaserJet 1010 Printer
Hp photosmart 2610 not recognizing new color printer cartridge (97)
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | Office Equipment & Supplies
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Prinitng only in varying shades of green and non-existent photocopying
not really..did you clean and re calibrate those print heads?
also, you might need new drivers(they get finicky at times)
Mar 08, 2008 | Office Equipment & Supplies
After changing cartridge, printer will not print, z645?
First... check to make sure you removed the yellow tab from the new print cartridge
put the ink cartridge back into the printer
click Start
click Control Panel
open Printers and Faxes
click (or double click to open) your printer icon
click on Printer menu
click on cancel all documents
Then try printing again.
If this does not work, look in the manual that came with the printer and check out the troubleshooting section.
Dec 18, 2007 | Lexmark Z645 InkJet Photo Printer
13 people viewed this question
jasbo
jasbo
