Question about Pioneer CDX-FM653 6-Disc CD Changer
Error code 80
Just purchased a cadillac sls with the changer already installed but when I press the power button I get "error80" and nothing happens although I can here the interference in the radio frequency.
  • Anonymous Dec 02, 2008
    i have the same problem, i just bought a car with a pioneer sound 6 disc cd changer already installed. i put my cds in and it just says err80 but the radio gets static-y..... what do i do?
Range rover cartridge that holds dvd & cd's will not eject.
Hi, I am having the same problem with a RRSC that I have just purchased, the blue eject button on the boot mounted DVD changer lights up but nothing happens when you press it, not even the sound of things trying to happen... Did you get anywhere with your?
Dec 02, 2009 | Dual Car Audio & Video
CD Changer doesn't work after changing battery on Jeep Liberty 20
The CD changer probably failed to establish it's link to the head unit when you put the new battery in.
Since you've already tried the clear button, I'd suggest unplugging the IP-BUS cable (black cable) from the back of the changer, wait a minute (literally, 60 seconds) and plug it back in.
Jul 20, 2009 | Jeep 2003 Liberty RBQ AM/FM Radio w/...
1996 cadillac seville sls codes
1996 cadillac sls. Oil light comes on and car stalls. Oil is full
Oct 17, 2008 | 1996 Cadillac Seville CA Value
Installing Sony CDX-454XRF
check all wires are attached to correct positions expesially speakers and when resetting hold the reset button for atleast 15 secs it also could be a faulty system.
May 25, 2008 | Car Audio & Video
Getting error code C1
First with the original memory installed, Unplug the power cord, remove the button cell for the RTC/BIOS, press the power button(to Dissipate any stray volts) reinstall button cell and reset BIOS/CMOS. Hopefully with the bios back to default everything should come up ok. Next goto crucial.com and check for memory compatibility either with the config tool or enter MOBO info.
May 11, 2008 | EPoX EP-8K3A+ Motherboard
Error problem on Canon BJC-80
Try this:
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
Jan 17, 2008 | Canon BJC 80 InkJet Printer
Cannot get the unit to come on
most chargers use the power from radio so if radio is working you should be getting power to changer bemore of a wire issue so you need to find out where power cable is going if seperate to radio possible it will have fuse and earth cable that could have come loose
Jan 03, 2008 | Sony CDX-540RF 10-Disc CD Changer
Help - can't use it!
usually there is a button combo you press on the stereo in the car to tell it to enter CD changer mode, his combo is dependent on the manufacturer of Stereo in your car, on mine you press the CD button while turning on, once in CD changer mode you should be able to select CD and track. Yes the CDs have to be a particular way up, although there is only a choice of 2 different ways so trial and error should suffice :)
Aug 17, 2007 | Pioneer CDX-FM653 6-Disc CD Changer
Pioneer CDX-FM653 6-Disc CD Changer Logo
264 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
