I am trying to print a booklet with two pages front and back from publisher 2007 on a Konica Minolta Bizhub C250 and when I print one copy it folds and staples fine. When I print two or more copies the machine prints all the pages, then staples them all together and folds them. I've tried to print a bunch of different ways (with collate checked and unchecked) but it still happens. I need to print out a few hundred booklets and do not want to print them one at a time. Any ideas?
1)The print driver has two collate buttons and you only need to uncheck the first one (which is the windows driver not the Konica Driver) or
2) Install a new driver
We can scan to email from a xerox MFP thru xchange2007 within the domain but cannot scan outside....
(More)
We can scan to email from a xerox MFP thru xchange2007 within the domain but cannot scan outside. Relay is set up for not only the machine's IP but the entire inside network (!). All credentials and NW config's. have been triple checked. There is a Savin 3740 MFP on this network that can scan outside just fine.
machine will not work, it says 'direction for this OHP size is not supported. Please change to...
(More)
machine will not work, it says 'direction for this OHP size is not supported. Please change to direction or set size larger than A4'.
