Question about Dryers
Heat keeps cutting in an out - Dryers
    President:
  • 1,922 Answers
Your cycling switch or hi-limit switch are getting bad
Posted on Oct 02, 2009
  • 120 Answers
Check your setting on the dial. Is it set for soft heat? Adjust accordingly.
I have a Performa Maytag dryer it will sometimes turn on run a few seconds and then cut off and it will do this in consistently as I left it plugged in and left it on it was run and then cut off run and...
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Feb 20, 2015 | Maytag Dryers
Living solution
Does it have a timer cut off switch or a heat cut off switch? Sometimes when a heater reaches a pre-set temperature it cuts out, otherwise it could over heat and cause a fire.
Jan 18, 2014 | Heating & Cooling
Stops working after 20 seconds
The magnetron is over heating causing the thermal fuse to open to cut power, the only option is replace the part, but keep in mind it is the most expensive item to install.
May 07, 2012 | Bosch HMT9626GB Microwave Oven
Washing machine cuts out
The pump is over heating and cutting power.
Mar 30, 2012 | Fisher and Paykel Washing Machines
I just got a new heating unit installed. However it runs constantly. If the target temp is 68 degrees it will hit 68 degrees and just keep running. It does the same at 63 degrees. Is this normal?
Dear friend! Any thermostat, it's calibrating to cut off at the end of 2nd beginning and cut in 2nd ending of temp.
Ex: In heat mode, If you set @ 68 degree, it will cut off 70 degree beginning and cut in at the end of 66 degree.
Hope it's helpful to you?
Jan 10, 2011 | Intertherm Heating & Cooling
AC WORKS FINE HEAT COMES ON BUT WHEN TEMP IS REACHED FAN NEVER GOES OFF AND TROUBLE WITH HEAT COMING BACK ON
When temp reached to thermostat level heatewr only will cut off not the blower. And secondly all thermostat at heat stage will cut off at the end of +2 degree and cut in starting of -2 degree.
E.g; If you keep 30 degree heat it will cut off at 32 and cut in 28 degree.
Dec 07, 2010 | Crosley CAE12ESR Air Conditioner
When cutting 40mm mild steel with oxy/propane is it recommended to heat the plate before hand,and would a 1/16 nozzle be sufficient?
No heating the plate before cutting is never recommended and a 1/16 nozzle is small for cutting thicker steel, My recomendation is to get the next to largest tip for your torch and use that for most of your cutting needs as for thinner material you just keep the settings turned down and for thicker you have the capabilities to increase you gasses to addiquitly cut the thicker material. Hope This Helps Don
Dec 03, 2009 | Welding Tools
When air/heat is on the car cuts off
any check engine lights,tps sensor might be going
May 10, 2009 | 2004 Dodge Stratus
Dryers Logo
46 people viewed this question
Top Dryers Experts
