Question about IBM Infoprint 6500 Matrix Printer
The printer doesn't print with the CPI and LPI changed incustom 1
It print the reports to 17 CPI,
I want to print with the CPI defined in the report
  • 537 Answers
SOURCE: fax transmission reports
What you are explaining should work. If you need prior activity reports from previous faxes, you can press Function then 2 (Act. Report)
I think you might need to press Function, then 7 then 1
From the manual:
Transmission Verification (Xmit) Report You can use the Xmit Report as proof that you sent a fax. This report lists
the time and date of transmission, and whether the transmission was successful.
When the feature is OFF, the report is printed automatically only if an error occurred during transmission. If the report indicates NG, send the document again. If the report indicates you should check the readability of certain pages, resend those pages.
If you typically send multiple faxes to the same destinations, you may need a reminder to identify each fax transmission. You can select OFF+IMAGE or ON+IMAGE to print a portion of the first page of the fax message on the report.
1 For the FAX, press Function , 7 , 1 .
For the MFC, press Function , 1 , 7 , 1 .
2 Press or to select OFF, OFF+IMAGE, ON or ON+IMAGE and press Set .
3 Press Stop to exit.
Hope this helps you.
Mike
Posted on Nov 14, 2007
SOURCE: Printing Speed
what interface are you using? sounds like windows is sending the data to the printer as graphics which is much more intence then EPL hence the delay between each label.
Posted on Nov 21, 2007
SOURCE: Draft Printing with EPSON LX-300 with custom page 10x6 inch in windows xp sp2
i used Epson LX-300+ printer suddenly the printer not work/no printout everthing is correct please help me
Posted on Jun 08, 2008
  • 66 Answers
SOURCE: Some reports will not print
you will need to disable  the netware setting and maybe the appletalk setting via the browser.
make sure you have the i.p address of your printer and enter it in the address bar
Posted on Mar 10, 2009
SOURCE: Zebra Printer / SQL Reporting Services print problem.
Any joy on this, we have the same problems.
Posted on Feb 11, 2011
Why does TI OMNI 800 Model 880 Printer print report lines off page?
Cuz RM=220. Right margin.
this is for wide paper for 16cpi characters per inch.
Jun 03, 2014 | Texas Instruments TI 880 Matrix Printer
Fax transmission reports
From the manual:
Mike
Nov 14, 2007 | Brother MFC 8300 Laser Printer
At times while printing reports, the printer will continue printing off the page
LM=1 is left margin, RM=220 is right margin, TM=2 is top margin, BM=64 is bottom margin, FL=66 is form length (66 lines is 11 inches when LPI=6 lines per inch) PRTFEA=H means you have the print feature dial set to Host. Change the dial and you get different settings for forms, checks, invoices, reports. A-F.
Perf Skip just skips over the perforation where the pages are perferated. Enhanced means its double strike vs Draft mode.
These settings tell me you are printing compressed print (CPI=16) on wide paper (green bar) cuz RM=220 right margin is 220. For 8.5x11 paper 132 is the correct margin with at 16cpi. or 80 for 10cpi. Clearly you have the wrong paper in here if you print off the page. You must have 8.5 x 11 or 11 x 8.5.
Host allows the computer to change the settings on the fly. That may be why it goes off the page later. (Or it could be a carriage jam that makes it think its at space 1 when it isn't.)
I don't know what you are trying to print so I can't help you. I can tell you that having right margin on 220 is why its printing off the page.
You can change the dial to preset draft 16 and print a menu for those setting or you can change the RM to 132 or 80 by using the command, menu, change and accept keys.
Its been 10 years or so for me but take the printer off line by pushing the on-line button, press command, press menu and it will print all the settings like you have done. It will then print whatever the first item you can change is, press accept and keep accepting until you get to RM=220 then press change. It should print 80 or some number, press change until you get to 132 then press accept. Press accept until you get to the end. Press Normal and on line.
If you change the print size from 16 to 12, or 10 you will need to change the RM to the correct width.
Can't find a manual online for you. I probably thru away 200 of them in 2007 when PCS closed. It would show you what the choices are for each setting. And what the preset and A-F settings are without printing a menu on each one.
ftp://ps-2.kev009.com/incoming/jim/TSSPRT/acroread/tssfact/tfsprt/ti/tfsti001.pdf
You might can buy a manual from Dennis or Rick...
https://www.fastprinters.com/ProductDetails.asp?product_id=TI-880DP
Are you a Auto or Ag Equipment dealer?
HP Queue Printer prints one extra job report page
Define the number of pages to be printed when the printer is selected.
Jan 13, 2013 | HP LaserJet Office Equipment & Supplies
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
WHEN i TYPE A REPORT IT HAS NO PAGE BREAKS AND I CAN ONLY PRINT THE FIRST PAGE WORTH...
Page breaks are are generally supplied by the controlling application, for example, Word, Excel.
For Excel, apart from using the "File" > "Page Setup" to define the page, you also have to define the "Print Area".
What is the application you are using to create the report?
Don
Dec 31, 2009 | HP J3680 Officejet All In One Printer
Can't get transmission report on bizhub 250 to print in Portrait
to change the tray that reports print from
it can be changed in service mode soft switch 323
change bit 7 to a 1 to print from tray 1
change bit 6 to a 1 to print from tray 2
bit 5 to 1 to print from tray 3
bit 4 to 1 to print from tray 4
bit 3 to 1 to print from bypass tray
Mar 19, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
How do I stop daily reports from printing? How do I change the default tray for fax reports?
To program a default paper tray to print fax reports, perform the following:
1. Select Utility/Counter.
2. Select User Setting.
3. Select System Setting
4. Select Paper Tray Setting.
5. Select Print Lists
6. Select the paper tray for the fax reports to print from.
7. Press OK.
8. Press Exit on the lower left side of the display to return to the copier screen.
to set the activity report to not print daily
1 touch the utility button
2 touch administrator settings and enter the password 12345678
3 press fax setting
4 press report settings
5 select activity report and change to off
6 press close then exit
Mar 17, 2009 | Konica Minolta bizhub C250 All-In-One...
Lexmark T642 Missing Character
change font size CPI from 10 to 15
Jul 04, 2008 | Lexmark T642 Laser Printer
You have to install the printer through it installer, it that way the advanced features of the printer will be activated and can be manually configured to what you want.
Click the link to get your driver. download here
Don't forget to rate me, "Fixya"... thanks.
Jan 27, 2008 | Epson LX-300 Matrix Printer
IBM Infoprint 6500 Matrix Printer Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
