Question about Magickwoods Black Glass Vessel Sink
New Vessel sink is leaking at the spud gasket.
Hubby is afraid to tighten the gasket anymore or it will break the glass sink. Is he being paranoid?
  • 31 Answers
Well if he is afraid then you take a chanel lock plier and go under the sink and titen it
Posted on Oct 03, 2009
  • 302 Answers
Just do a quarter turn at a time. Check for leaks and turn again if needed.
Tell your hubby it's ok...I don't like installing those sinks either...always afraid they'll break and that the customer is gonna take my first born lol.
Posted on Oct 05, 2009
We have the Kokols Wallmount Bathroom Pedestal Glass Sink Vanity Combo but the p-trap keeps leaking. How do we fix it?
Remove it, (Don't forget water will come out when you uncscrew it!!!) clean it thoroughly, especially the ends, clean and check seating of any rubber washers to make sure they are fitted correctly and not being distorted when the rings are tightened, reseat it with no force (it should sit naturally without having to force it in) and tighten rings. There are lots of videos on youtube showing how. If you cant stop it leaking buy a new trap. It's worth while looking very carefully for exactly where the leak is before you remove the trap, it might be coming from higher up. Repair Leaky Sink Drain Pipe
Jun 21, 2014 | Kokols Clear Vessel Sink Pedestal Bathroom...
I have a manual flushometer by sloan. It is a royal type, and when the unit is flushed water is leaking from the spud coupling where it connects to the porcelain bowl. I suspected the spud coupling was...
if a leak can't be repaired by tightening, you can try taking it apart fully and seeing it anything is twisted or perished. Best way though for trouble free use and peace of mind is a new coupling.
Jul 25, 2017 | Home
Just installed a vessel sink and it leaks between the vessel and under sink.
Use silicone to seal the flange and teflon tape on the threads that the drain flange screws onto. make sure that the sink isn't cracked. make sure that you have a washer under the rubber gasket that seals the bottom of the sink and tighten the nut against the washer snuggly.
Mar 23, 2011 | Vessel Home
The sink leaks at the bottom of glass sink where it connects to the piping
THE PART YOU ARE TALKING ABOUT IS CALLED DRAIN TAIL PIECE. THE DRAIN YOU CAN REMOVE BY LOSENING THE NUT UNDER THE SINK WHILE SOME ONE HOLDS THE DRAIN INSIDE THE SINK FROM TURNING THE OART KEAKING IS CALLED A SPUD GASKET WHICH SEALS THE DRAIN TO THE SINK
Aug 18, 2009 | Magickwoods Black Glass Vessel Sink
Vessel sink's drain is leaking
a waste with a over flow does not work well with a vessel sink because the sink is to thin
Jun 16, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Poor Draining of Vessel Sink
have the plumber pop an opening on the side of the drain pipe under the sink. and add a indoor vent.
Apr 10, 2009 | Advent KRAUS Amber Rectangular Glass...
Pegasus Push Button Vessel Sink Drain with overflow
Put plumbers putty around the flange that will be in contact with the sink. When you put it into the hole, try to line up the overflow as good as possible. The nut that goes onto the bottom (tailpiece) has a rubber gasket that will go between the nut & the sink. Adding some plumbers putty here won't hurt. After all is secure, just remove the putty that squeezed out from tightening.
Feb 21, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Magickwoods Black  Glass Vessel Sink Logo
377 people viewed this question
Top Magickwoods Home Experts
Donni Steen
Tom Chichester
Are you a Magickwoods Home Expert? Answer questions, earn points and help others
