Question about Gorilla Toys
How do you blow up the buoy ball? - Gorilla Toys
Changing colored lens on glow buoy
The way I change the colored lens to the glow buoy is with three standard screw driver, about a 3/16" head good 4" shank or longer. If you look close you can see four grab tabs in the middle of the lens, these hold on to a lip on the clear lens. Twist the colored lens till you can get to three of the tabs. I couldn't get to all four do to the triangular shape of the top. Slowly wedge the driversunder the lip of the colored lens center to the tabs one by one, alternately pressing the screw drivers deeper once you get the to where they wil continue no futher, due to the bevel in the lens, take the two drivers opposite each other and push them in forcing the edge outward. The lens will pop off violently, and most likely shoot the third screwdriver across the room, but after changing them a few times the lips wear down soon you will be able to pull them off with a good pair of fingenails. Hope this helps, you may scratch the lens a little, also the covers have a bit more flexibility then I thought I was afraid to break them but now I see the give.
Jul 20, 2013 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
A65 unit does not indicate proper position. When alongside a buoy it shows the buoy ahead by about 50 feet. When the buoy is 50 ft behind the sail boat, the A65 shows it abeam. Even my handheld Garmin does...
You may be aware that the system is "detuned" for security reasons. With GPS, repeatability is the key. A bouy is NOT a stationary item, especially at low tide, I suggest that you test your accuracy with stationary objects. A map (chart) cannot know which way the tide is moving a bouy, only the approximate anchor location, the bouy floats and moves....
Mar 04, 2011 | Raymarine A65 GPS Receiver
Toilet continues to run because the buoy (the black plastic piece filled with air) gets stuck and does not rise up as tank fills with water. This is an intermittent problem. I tried adjusting the...
The buoy or float cup as it is known by may not be the problem. Try removing the fluidmaster top cap assembly and flush our the valve for debris. If the valve is several years old you may want to replace the top cap seal with model 242.
For more information call 1/800-631-2011 and speak to a Fluidmaster Tech
Aug 17, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
I need to purchase/order a new plug in device for the glow buoy
You might want to check with backyardcity.com. I know that they sell an assortment of swimming pool lights. If they don't carry the charger, they can probably direct you to the manufacturer. If you have a number to the manufacturer, you might want to contact them directly. Also, a local pool store might carry them.
Jun 27, 2010 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
I have lost the ac charger power cable, manual, and other accessories that came with the 92000 i purchased a few years ago during a recent move. Where can I order these items and other accessory items for...
I am not sure if they sell accessories, but I know that Backyardcitypools.com sells these kinds of swimming pool lights so they might be able to help you get what you are looking for or point you in the right direction. Hope you find what you are looking for!
Jun 11, 2010 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
I need a new bulb for my glow buoy pool light! how much and were thanks!!!
The Glow Buoy swimming pool lights were designed so that the bulbs can only be replaced by a licensed pool supply store. If you open the light yourself, you will void any warrantly and risk breaking the unit. Becuase of this, they don't sell the exact bulbs that you need unless a pro is installing them.
Jul 07, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
My glow bouy won't hold a charge.
my glow bouy just keeps flashing on and off after recharge, had it about 2 years hardly been used
Apr 10, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Overlapping maps on a C330
On Page 17 of your manual:
Go to Tools > Map > Map Info
This should show you the mapping software installed on your unit. Uncheck the one you don't want to use.
Apr 02, 2008 | Garmin StreetPilot C330 GPS Receiver
Toys Logo
114 people viewed this question
Top Gorilla Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gorilla Toy Expert? Answer questions, earn points and help others
