Question about Thermos Grilling
Low flame; won't get any large or hotter - Thermos Grilling
  • 464 Answers
Try opening the tank really slowly. if you open it too quickly the overfill protection devise inside the tank will restrict the gas flow to the grill. hope this helps.
Posted on Oct 14, 2009
Express soldering iron normally has a blue flame , but today when I lit the gas it just gives off a large non directed yellow flame?
could be low on gas if propane or if not its the porcelan blocks however not sure we are speaking of the same iron
Mar 16, 2016 | Blue Flame Heating & Cooling
Why does My dm2852 works on electric, but not gas. It lights (small flame), but doesn't cool.
It is more than likely just a dirty orfice. It can be cleaned quite easily by soaking it in rubbing alcohol then blowing it out. Do NOT POKE ANYTHING THROUGH IT! 946177a3-e85b-4832-879e-b23434d529ef.jpg ArctiCold Refrigeration We keep it cold
Jul 22, 2014 | Dometic DM2852 Americana Fridge...
Why is the right side of the heater flame higher and hotter then the left side
Combustion needs air mix in the correct proportion to burn efficiently-also gas supply may be stronger on the outlet side of burner causing an imbalance-chech for obstruction in either area-cheers Denny
Oct 11, 2013 | Vanguard International Blue Flame - Large...
Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Feb 07, 2012 | Heating & Cooling
The flame in weak and it heater will not light
You need to replace the ODS pilot assembly.A low pilot flame will not allow sufficient heat to generate proper voltage to hold valve
Nov 13, 2009 | Vanguard International Infra Red - Large...
Just bough weber Q200 grill. Is it normal that the flame burns so low and blue?Used to large flames off conventional grills. Thanks.e.
I have used the Q-series for 2 years. The blue and low flame is absolutely normal. Weber's philiosophy is of avoiding flare ups when grilling for best taste. I love this grill - very easy to clean, uses less gas and makes great food.
Aug 23, 2009 | Weber Q Grill
Charbroil master flame gas grill the flame is either very high or very low
How old is the grill? The size of the holes in the burner is critical. As burners age, the holes rot out, and get bigger. The velocity of the gas exiting the holes has a large effect on flame size. New burner is the most typical solution.
Mar 08, 2009 | Char-Broil CharBroil Master Flame Gas...
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Grilling Logo
79 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
