Question about Car Audio & Video
Rockford Fosgate 200S amp, not powering up, some burnt components found.
I just got my hands on a rockford fosgate 200s amp, it didn;t power up for me, upon opening it I spotted a burnt trace on the ground side, I patched this and nothign happened, looking closer, R29 and R20 look to have over heated and come un-soldered from the board, I found them and they appear to be 100 Ohm resistors, I replaced them and I get no power up. When power is applied ot the amp those resistors get very very hot. Guessing I have a short somewhere. Any guesses? I can get pictures of the damaged areas of the amp if that will help. I do know electronics fairly well design wise, but is the first time I am taking a crack at a rockford fosgate amp and I don;t have a schematic.
~ Night
  • 631 Answers
If the resistors go to the gates of the power supply FETs, the FETs are probably shorted. Measure the resistance between the gate and the drain (no power applied to the amp). It should be at least several thousand ohms.
If you can take high res photos, send them to my email address:
babin_perry@yahoo.com
Posted on Dec 21, 2007
What would cause 1 channel of a Rockford Fosgate T800.4ad 4 channel Amp to fry speakers while there are no such problems with the other 3 channels?
Question: what starts to smoke, the speaker or the amp? I'm assuming it's the amp. It cant be a fuse because that's what fuses are for to cut the power on an overload or surge. I would have a look at you circuit board for the amp My guess is what you;ll find is a burnt spot on the board and that will tell you what component is bad and needs replacing. Good Luck
Apr 19, 2017 | Rockford Fosgate Car Audio & Video
Rockford fosgate p5002 amp keeps blowing fuses as soon as i turn it on.
make sure your power hasnt found its way in the the ground and vice versa
Apr 02, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Rockford Fosgate T15004 The Amp still powers up with the
Check you inputs to verify you have a signal coming in, if signal then check outputs try a speaker that you know is working and plug it in if that speaker plays then the subs/ or speaker wiring is bad, if it doens't play then you probably have a blown output transistor on the amp or possibly a terminal ground/positive has come loose on the inside..
Oct 27, 2009 | Rockford Fosgate T15004 Car Audio...
Rockford fosgate amp keeps shutting down when volume is cranked
your cd player cant handle all the power, time to upgrade to a cd player with at least 80w10
Jun 12, 2009 | Rockford Fosgate Punch P5002 Car Audio...
Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Apr 27, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Sub hook ups
There's a lot more factors involved than that.
  • Power capability of the subs
  • Type/size of the sub box
  • Allotted space in the vehicle for the sub box
  • Voice coil impedance of the subs versus the capability of the amp
  • Etc.
Jun 19, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
Rockford Fosgate 501bd question
that amp should work fine with those speakers,just make sure that they(speakers)are wired for 2 ohms.at 500-600watts coming from amp, you should be getting 250-300 watts per speaker,just dont crank your gain too high on the amp.
Aug 29, 2007 | Rockford Fosgate Power 501BD Car Audio...
Car Audio & Video Logo
286 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
