Question about Gateway 500 CS PC Desktop
Gateway EV730 has lines on top making it hard to view top of page what can I do? thanx
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello Jahodi
Happy Holidays
WHat kind of lines has it? from any program or it is directly from your monitor? may be is your monitor that has problems with horizontal lines, this happend sometimes.
try changing to the refresh rate to 75, or the size of the screen. to 1024 x 768
Posted on Dec 21, 2007
Replacing a power switch on a gateway tower
The plastic front of your computer is the Front Panel
http://support.gateway.com/s/PC/R/1009566/1009566nv.shtml
Slip this off to access the Power On Button assembly, which has the Power On switch inside it,
Outside view,
http://support.gateway.com/s/CASES/GERSHWIN/8016200R/8016200Rmv.shtml
Rear View,
http://support.gateway.com/s/CASES/GERSHWIN/8016199R/8016199Rrv.shtml
-> FOLLOW Anti-Static Procedures -> BEFORE reaching inside, your unplugged from power, computer.
If you do not know, post back in a Comment
Now look at the Rear view of the Front Panel again.
The LEFT Side Panel removes.
Looking at the Rear view of the Front Panel; note that the LEFT side of the Front Panel, is towards the Bottom.
See the three TABS sticking up along this edge?
One at the Bottom, one in the Middle, and one at the Top.
Flat plastic TABS formed out of the Front Panel itself.
Another point of view.......
The metal framework you see that the CD/DVD drive/s are in, is the Optical Drive Bay.
Look at the Optical Drive Bay, and towards the Top/FRONT.
See that flat TAB sticking in from the Front Panel?
Now come down to the Middle of the Front Panel.
See how out at the bottom of the Optical Drive Bay, there is a TAB sticking in from the Front Panel?
See the TAB at the Bottom?
They hook on the metal framework of the computer case.
They go through SLOTS in the metal framework.
The Tabs are pressed to the Inside of the computer case, OR to the outside of the computer case.
This action brings a hooked end on the end of the TAB, to the Middle of the slotted hole it\'s in, and then the Tab is free.
Suggest start with the Bottom TAB, press on it when hooked end is free of slot; then do the same for the Middle TAB.
Now perform this on the Top TAB.
The TABS are pressed to the inside, or to the outside, and pressure is put against them towards the Front Panel.
Push on the Tabs, to push the Front Panel away from the computer case.
Once all three TABS are free, the Front Panel will swing out, and remove.
Power On switch is mounted to this metal case,
http://support.gateway.com/s/CASES/GERSHWIN/8016038R/8016038Rmv.shtml
Me?
I would open that case, and take the Power On switch itself, out.
Then see if I could find a replacement, or one that I could live with,
http://www.ebay.com/sch/i.html?_nkw=atx+power+switch
Direct link to Hardware Reference Guide,
http://support.gateway.com/s/Manuals/Desktops/8512041.pdf
Let\'s see if it works.
If not here is the Gateway Support page for it.
http://support.gateway.com/s/PC/R/1009566/1009566ul.shtml
8512041 - Gateway Hardware Reference Guide (5-Bay uATX Case)
Go to Pages 37, and 38. (Top of Adobe Reader in page number box)
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 19, 2013 | Gateway GM5472 PC Desktop
DX4300-05 How to open Gateway panels
1) Jaws of Life.
2) Acetylene torch
OH, I'M JUST KIDDIN'!
Gateway Support > DX4300 series of Desktop PC > Main Support page,
http://support.gateway.com/us/en/s/desktop/2009/gateway/dx/dx4300/DX4300nv.shtml
http://support.gateway.com/s/desktop/2009/gateway/dx/dx4300/DX4300rv.shtml
Looking at the Front of the computer, is how you determine Right side, and Left side.
The Right side removes with two screws, as far as I can see.
The Left side is a little harder to tell.
Gateway Support is of no help on this one. At least that I have found. Not in User Manual, because it's generic. One size fit's all.
However looking at the Rear View, it looks like the usual style to me.
Hard to make out though, because it's painted Black.
ON the back edge of the Left Side Panel, appears to be a Thumbscrew.
Even with centerline of Power Supply fan.
But there also appears to be a type of flip lock.
Or should state; push over to the inside; a little.
Then using the Fingerpull molded handle on the Left Side Panel, pull the side panel back.
Usually there are Slots in the metal frame, of the computer case.
The side panel has Tabs that stick out, with hooked end.
Along the top, and/or along the bottom.
You pull the side panel back until it stops, then move back forward about an inch, or so. Then bring the side panel straight out.
No?
Then post back what you see, and we'll try to figure it out together.
Post back in a Comment.
Regards,
joecoolvette
Mar 22, 2013 | Gateway Computers & Internet
Archos 605 web browser
to create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options or
click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search providers you
have if dont need any of them you can disable or remove them
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
hope it helps
Jul 31, 2012 | Archos 605 WIFI 405 2GB 4GB 30GB 60GB 80GB...
My Gateway laptop model MX6453 wireless adapter is shut off and I'm unable to find how to turn it back on
Frequently Asked Questions
Q: How do I turn my notebook's wireless on and off?
A: Most Gateway® notebooks have a designated multi-function button or function key to turn your wireless on and off. This information is located in your notebook's user guide. The user guides for the Gateway® branded notebooks are installed on your hard drive. To access your user's guide, from the Start menu, point to All Programs, and then click Gateway Documentation. User guides are also located on the Gateway® Web site. To download or view a copy of the user's guide from Gateway.com, select your notebook type from our Notebook User Guides support page. http://support.gateway.com/support/manlib/Notebooks/notebook.shtml Another source of reference for networking your computer is the Gateway Notebook Networking Guide. http://support.gateway.com/s/Mobile/Gateway/M250/8510650.pdf Quick reference:
  • Gateway® M675 - Multi-function button (last on right)
  • Gateway® 200ARC - Multi-function button (last on right)
  • Gateway® M505 - Multi-function button (first on top)
  • Gateway® M500 - Multi-function button (first on top)
  • The Gateway® M275 notebook uses the system keys FN+F7
  • Most other notebooks use FN+F2
Dec 08, 2010 | Gateway MX6453 Notebook
Where is the headphone jack for the gateway EV730
You have to connect your headphones at the line out of the audio card at your desktop. It's the green jack with 3.5mm diameter at the back of your case. If the place that you have the desktop is not conventional for plug and unplug the headphones, I suggest you using an extender like this one. In case you use a speaker set there must be a headphones output either on one of the speakers or at the control unit.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 04, 2010 | Gateway EV 730 17 in.CRT Conventional...
How do I enable the wireless switch on a Gateway mx8711
HI there,
The user guides for the Gateway® branded notebooks are installed on your hard drive. To access your user's guide, from the Start menu, point to All Programs, and then click Gateway Documentation. User guides are also located on the Gateway® Web site. To download or view a copy of the user's guide from Gateway.com, select your notebook type from the Notebook User Guides support page. Another source of reference for networking your computer is the Gateway Notebook Networking Guide. Quick reference:
Hope this helps you out.
TheSelkie
Jul 21, 2010 | Gateway MX8711 Notebook
I would like a manual so that i may use my new computer, i am on a friends computer
I'm not aware of a Gateway NV500 Series line, of Notebook PC's.
I would like you to look on the bottom of your Gateway laptop, for the exact model number.
Are you referring to the Gateway NV5207U?
It's part of the Gateway NV50 Series. (One of the one's sold at Bestbuy?)
While I wait on the exact model number, let me give you the page for the User Manual for the NV52 Series.
Never mind! 17.79MB's of anything but where the Power On button is, and what the basic parts of the laptop are!
Sheesh!
Here is the page to download the Gateway NV50 Series User Reference Guide,
http://support.gateway.com/s/notebook/2009/gateway/nv/nv52/NV52ul.shtml
On this page scroll down to - Gateway NV50 Series Reference Guide - English, and Left-click on it.
This is a PDF file download. (The computer you are on now has Adobe Reader on it, which uses PDF files)
It takes a few seconds to see the first page. It takes an additional 24 seconds or so, to fully download the file.
I advise letting the file fully download before looking through it. Otherwise you might break the download connection.
The first page is solid Black. The second page is solid White.
Should you not be aware of how to use a PDF file, and/or, want to burn off a copy to your computer, come back, and state so.
This reference guide shows the basic views of the laptop, the various function buttons, all about the Keyboard, and other details.
On this same Gateway Support page, is the Gateway Quick Start for Windows 7. It's listed at the bottom.
The Power On button is on the Right side of the laptop.
It's in the round hinge for the LCD screen.
The symbol on it is an international one. It's a circle with a line coming part way into the top. The top middle of the circle.
This is a video on Youtube, showing a user un-boxing his Gateway NV5207u. I included it to show more of where the Power On button is, and also that there is an Enable/Disable button for the Touchpad.
Would be kind of perplexing also, if you went to use the laptop, and couldn't get the Touchpad to work.
http://www.youtube.com/watch?v=B1IB6u1iHaY&feature=related
Once I have the exact model number we can proceed forward, if the Gateway NV5207u is not the laptop in question.
Dec 27, 2009 | Computers & Internet
How can I change my font size? I can hardly read my page
You can change the font size in your browser. If you use Internet Explorer, go to page (usually top right toolbar) or View (top right tool bar) above the address bar. In both places font size displays. Under page, there is also a magnifying glass, but that will make the whole page larger.
In Firefox, you can go to View, and use that zoom text only.
On facebook, You can also hold down CTRL and then hit + key. CTRL and then hitting - key will make the whole page smaller.
Permanent changes can be made for all web viewing in all browsers under tools.
Dec 23, 2009 | Facebook Computers & Internet
Lines on screen
This happened to me once too. It is something with the monitor, which needs to be cleaned inside, that is all. Just take it to a mechanical store and they will fix it
Aug 09, 2009 | Gateway 500 CS PC Desktop
White horizontal lines of static on monitor
Can you try reducing your monitor refresh rate to a lower frequency, or the lowest frequency.
Apr 10, 2008 | HP Pavilion F1703 17" LCD Monitor
Gateway 500 CS PC Desktop Logo
323 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
