Question about Parmak Solar Fence Charger
We have 2.2 miles of fence,the charger is good for 30 miles.We have a 8 ft ground rod by the charger. the fence is a continues loop. positive wire to fence, negative to ground. meter on the charger says it is putting out max. But you can touch the fence no shock. The water table is 8to10ft.
    President:
  • 1,714 Answers
You have got to make sure there are no weeds or brush at all touching the hot wire. Nothing can touch it or it pulls the voltage level way down. Do a full inspection of line.
Posted on Oct 02, 2009
I have Parmak S.E.3 fence charger, it's send energy out into wire but not enough to shock cattle, the unit is around a 7 acre field with 2 lines, what could be the problem?
Grounding is very important for an electric fence, especially in dry soil. I normally drive 2 or 3 - 6 foot long ground rods 10 feet apart then join them all together and run that to the charger using double 14 gauge or 12 gauge copper wire. You can get the roda at Tractor Supply.
Aug 19, 2014 | Electrical Supplies
Hi, I have a 25 mile range Parmak solar pak 6 fence charger. When I test the lines it reads .02 and I noticed that the energizer unit itself is energized. I tested the unit and it reads between 3.8 to 4.6....
Any point you measure has to be compared to a reference. This can not be accomplished by just touching one spot....it must be compared to something. Do I make sense the way I explain this?
Hope this helps! Good luck
Dec 30, 2013 | Electrical Supplies
I have a Parmak Model DF-SP-LI. With a volt meter it reads 2.3 on the fence, but the performance meter is always reading beyond the green.
It depends on the type of fence tester. the common light-o-meters are a resistor ladder, calculated not only for voltage but current. the DF-SP-LI uses half the lowest current most are designed for. no if that is a digital or analog meter, then it would be time to check the out put from the charger with out the fencer connected. if you get the same reading it maybe defective unit. if you get a better reading then you will probable need to upgrade your ground system. insuffencient ground will show its self as a low out put on the fence but not on the charger.
May 20, 2012 | Parmak Solar Fence Charger
Model DF-SP-SS unit has been out of servicer for quite a while, stored in the dry and in the dark. The output from the solar cell is 8.6 VDC. With a new battery installed and left in the sun for several...
theses symptoms would say that your circuit board has/is failing. in particular the 25tts 12 SCR. you can contact Parmak for either parts or service.
Jul 14, 2011 | Parmak Solar Fence Charger
When I hook up the ground wire the meter shows not working but when I unhook it, it shows full power.
It sounds like to me that you have something shorting the "shock" output to ground. Check your fence to see if there are any plants, or other objects touching the "Hot" wire to the ground. You could also have a broken or cracked insulator that is causing the short circuit on the output.
joe
Jan 05, 2011 | Parmak Solar Fence Charger
How do i replace the head gasket in a 2000 dodge durango.
3.9L, 5.2L, and 5.9L Engines To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Battery negative cable
    • Coolant
    • Intake manifold-to-alternator bracket support rod
    • Alternator
    • Closed crankcase ventilation system
    • Evaporation control system
    • Air cleaner, air in-let hose and resonator
  3. Release fuel system pressure.
  4. Remove or disconnect the following:
    • Fuel supply line from the fuel rail
    • Accelerator linkage and, the speed control and transmission kickdown cables (if equipped)
    • Distributor cap and wires
    • Coil wires
    • Coolant temperature sending unit wire
    • Heater hoses and bypass hose
    • Vacuum supply hoses from the intake manifold (3.9L Engine)
    • Fuel injector harness and secure out of the way (3.9L Engine)
    • Cylinder head covers and gaskets
    • Intake manifold and throttle body as an assembly
    • Exhaust manifolds
    • Rocker arm assemblies and push rods, and identify to ensure installation in original locations.
    • Head bolts from each cylinder head and remove cylinder heads
    • Spark plugs
To Install:
  1. Install or connect the following:
    • New cylinder head gaskets into position on the cylinder block
    • Cylinder heads onto head gaskets and cylinder block
  2. Tighten all cylinder head bolts, starting at top center and in sequence
    1. Torque to: 50 ft. lbs. (68 Nm)
    2. Repeat and Torque to: 105 ft. lbs. (143 Nm)
    CAUTION
    When tightening the rocker arm bolts, ensure that the piston in that cylinder is NOT at TDC.
  3. Install or connect the following:
    • Push rods and rocker arm assemblies in their original positions.
      1. Torque to: 21 ft. lbs. (28 Nm)
    • Intake manifold and throttle body assembly
    • Exhaust manifolds
    • Spark plugs
      1. Torque to: 30 ft. lbs. (41 Nm)
    • Coil wires
    • Fuel injector harness (3.9L Engine)
    • Vacuum supply hoses to the intake manifold (3.9L Engine)
    • Accelerator linkage and the speed control and transmission kickdown cables
    • Fuel supply line.
    • Alternator and accessory drive belt.
      1. Alternator bolt - Torque to: 30 ft. lbs. (41 Nm)
    • Intake manifold-to-alternator bracket support rod and bolts
    • Resonator assembly (3.9L Engine), air in-let hose and air cleaner
    • Heat shields
    • Coolant
    • Negative battery cable.
Oct 14, 2010 | 2000 Dodge Durango
Installed the new solar charger in July. ZThe hot wires and ground wires are properly connected, snd the fence is properly grounded. It worked great until approximately two week s ago (end of Sept). The...
I have see this happen before and its usually do to most moisture/rain getting in. ie use multi meter to varify solar charger putting out current/voltage. Odds are its not anymore. Rechargable batteries are notorius for not lasting but not in 2 months.
Oct 07, 2010 | Parmak Solar Fence Charger
Need battery
We have one of these, it's great.
See these links:
http://www.parmakusa.com/Battery_Maint.htm
http://www.parmakusa.com/service.htm
I would try removing the battery and charging it with a proper low-amperage charger (1 amp). Your battery will either be 6 volt or 12 volt, just be sure the charger matches.
Also check the ground rod and all wiring connections.
May 13, 2010 | Parmak Solar Fence Charger
Controller has no voltage output when connected to fence
You have a dead short to ground somewhere along the fence circuit.Disconnect the leads again,and use a resistance checker to check resistance to ground.(Push a metal rod into the ground to connect one of your leads to,and connect the other lead to the fence.)One or the other fence circuit ends will have a lower resistance to ground.That fence end is closer to the short to ground.Follow that part of the circuit until the resistance to ground is as close to zero as you can find.(taking the ground rod with you as you go)Somewhere in that area you will find your short.
May 15, 2009 | Zareba Electric Fence 600 - 7,000 Volt...
Parmak Solar Fence Charger  Logo
491 people viewed this question
Top Parmak Electrical Supplies Experts
 Kenneth
Kenneth
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Parmak Electrical Supply Expert? Answer questions, earn points and help others
