Question about JVC LT-32X787 32 in. LCD Television
Digital breakup I have had my JVC 32 LCD for about 1 year. In the last two months a problem has showed up. The digital picture breaks up and the audio gets delayed, green and red pixels appear and breaks up the picture and audio. My cable company replaced their box and it worked fine for about a day. Then the problem started again. I do not have a digital receiver. When the video breaks up you can hear a small click coming from the LCD, You hear the click and the sound and audio brek up...the next day the reception is fine...it is an intermittent problem. Any ideas of what to do to fix this????
  • 9 Answers
SOURCE: JVC GM-P420E Plasma no video green screen
the problem is with the micro processor on the back of the fx-1169a board (gm-p420ug) this is the board the inputs connect to . yours may be a diffrent p/n due to yours bein a "e" extention model. to repair this problem you need to remove the processor from the socket, remove the socket from the board and solder the processor onto the board. the processor is ic002 on the back side the problem is thermal in nature due to cold solder joints on the socket. i have fixed this problem many times by using this method.
Posted on Jan 28, 2009
  • 105 Answers
SOURCE: JVC LT 42x688 no picture just sound
Sorry, this has no easy fix. The good news is you do not need an LCD Panel. The bad news is the Video Processor has a problem.
This TV has x3 Boards. The one you should replace first is the one in the middle. If this doesn't fix it, try the one on the right. The Part #s are on the Boards if you wanna try ebay.
Posted on May 06, 2009
  • 105 Answers
SOURCE: No Picture
I am deeply sorry but you will need to replace the backlight bulbs. These are not available.
Look on Ebay for a 32" JVC with a broken LCD Screen. Buy it and use these bulbs to fix your TV. I am sure there will be a few good ones in the broken TV. It's that or list it on Ebay for $50 and expect to get about 200-300.
LCD Panel repair for this problem is $500 for parts so you are stick with repair yourself or sell.
Posted on May 27, 2009
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
Posted on Jul 21, 2009
TODDAS
  • 431 Answers
bad main logic pcb
Posted on Oct 08, 2011
The tv will not show a picture
take a look at this, also make sure your screen is not cracked by using a flashlight and taking a close look
Dec 04, 2013 | Emerson LC320EM2 32" LCD HD Television
We have a sharp lcd tv. it is 2.5 years old. The
the lcd tv hhave somethig like a bulb and after a period of use that bulb must be changed. take the tv on service. the service man wil see what is the problem most accurate.
Feb 14, 2010 | Sharp LC-32AV22U 32 in. LCD TV
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
JVC i art 32" flat screen
Does anyone know where can I buy a screen for a 27" LCD Insignia TV. Model is NS-27LCD? My screen creaked. I checked out e-bay and have not found a broken TV with a good screen. Does anyone know where I can buy a screen at.
Thank you all for you time.
JC
Jul 22, 2008 | Televison & Video
Picture blacks out after a few seconds after turning on the tv
Anytime an LCD has a shade of pink, that means the CCFL lamps are about to go out. Now that you have a black screen, I'd say you just need some new bulbs.
Dec 07, 2007 | JVC LT-32X576 32 in. LCD Television
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
JVC LT-32X787 32 in. LCD Television Logo
177 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
