Question about HP PSC 2410 All-In-One InkJet Printer
SCannwer noise and four blinking buttons.
I have exactly the same problem.
I can not find what it is but it looks like the initialization of the printer goes wrong. usually the scanner bulp comes out much further but now just a bit so if it goes back it hangs up or so and after a minute or 2 all four buttons around the ok button blink and nothing can be done.
May be it has to do with the message I get that the black ink is not good. Strange. sometimes, really sometimes the printer works but mostly not anymore.
When switching on the printer and press the BLACK and COLOUR button on the bottom of the panel, it will show 1-time mfg.mode in the display.
Anyone an idea what that's supposed to mean?
Greetings Danny...
Buffalo12980
  • 625 Answers
SOURCE: ink replaced, but sows nothing
the ink cartridges have a ink memory chip inside. it operates on the number of pages printed not the actual amount of ink inside the cartridge. if you go to some sites that refill cartridges, they'll tell you how to reset the "ink left" memory. the ink is in a sponge inside the cartridge. it flows by gravity to the printhead. the sponge is an open celled poly sponge. there are tiny air flow passages just under the tape on top of the cartridge. I have an all-in-one 5610 and when I get a low ink indication I just keep printing. when the copy gets blotchy I just replace the cartridge. If my color is off, I can usually refill the color and keep printing. I can refill the cartridge twice before the bubble jet printhead needs a new cartridge.
Posted on Aug 30, 2007
SOURCE: HP 3310 - problem with black ink supply
I heard you can get the 3310 to do a pump up the tubes cycle but i don't know how to make it do it. Pressing the ok and cancel buttons when you power up didn't work for my machine. Which has too died a inkless black death!
Posted on Oct 01, 2008
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
SOURCE: Won't work, "Colour" indicator + "Check cartridge" indicators blinking
I had the same problem and I accidentally found out that if you press the cancel/resume button + the color scan, the printer starts printing a test page I had never seen before (includes error codes and stuff?!?!) and color as well as black comes out perfect but it will go back again into color cartridge problems after printing. Could it be something with the printer software itself? Hell, I am kind of getting sick with HP products. They are overrated and cannot be serviced. Kinda disposable printer although it was being sold as medium range all in one printer.
Posted on Oct 24, 2008
SOURCE: hp psc 2310 is "stuck"
This has been solved in the fixyourownprinter.com forum. Clean the bottom of the scanner glass. You have to take a bit of it apart but it's not hard with the help of this HP site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00553775&cc=us&lc=en&dlc=en&product=303753&dlc=en&lang=en
Good luck.
Posted on Apr 29, 2009
What does error code F7 E1 mean on a whirlpool VMW washing machine
This code indicates a motor speed sensing error, the motor can not achieve the correct speed for the cycle selection.
Have the shipping bolts been removed?
This error code indicates that the motor is having difficulty turning.
All four (4) shipping bolts and the plastic spacers must be removed from the rear of the washer before you operate it. Each unit is shipped from the factory with four bolts, which are designed to secure the washer during shipping. Failure to remove all of the shipping bolts, and the four plastic spacers that are with them, can result in noise, vibration or error codes. See your Installation Instructions for details on how to remove the shipping bolts.
Dec 27, 2016 | Whirlpool Washing Machines
On/Standby light flashes red four times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 27, 2012 | Sony VPL-EX100 3LCD Projector VPLEX100
Every time i push the button for the four wheel hi it makes the click noise in the front but DOES NOT ENGAGE. only the back tire spins
Depending on the year, it is not posted, it may be a bad transfer case motor. The clicking you are hearing is the motor trying to engage transfer case & front axle. It looks like a windshield wiper motor & when it gets power & works properly it engages front wheels. Again, depending on the year, may be 4 wheel drive actuator or switches bad on front axle or transfer case.
Jan 17, 2011 | GMC Jimmy Cars & Trucks
My wii remote wont work !!!!!!! I turned on my wii and it said to push A on your wii remote and I did and the four little light things just blink and shut off !!! What do I do ?
1. Take the battery cover off from the back of the wiimote. Look for a little red button. 2. On the front of the nintendo wii console open the little door that covers the SD slots. Look for another red button.3. Press both red buttons, it does not have to be at the exact same time, but within about 2-3 seconds.
Jun 11, 2010 | Nintendo Wii Console
Main board green light blinking at 5 flashing intervals
researched your problem a little, it sounds like a burnt out board. It doesn't look too good for parts either. google your symptoms and you will see a few hits on your exact issue
Jan 29, 2010 | Gateway GTW-P42M303 42 in. Plasma...
I have 2001 isuzu rodeo that the four wheel drive will not engage when the button is pushed. All I hear is a clicking and the four wheel light blinking. Any thoughts?
fords are famous for this. Its electronically controlled 4x4(push button) i would start cheap and replace that switch
Dec 08, 2009 | 2001 Isuzu Trooper
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Aquos LC37D40U Blinking light and won't turn on
The power light is an error code that tells me exactly what is wrong with the TV. Count how many times the POWER led flashes per second? (Dont worry about the OPC led)
1x per second (constant steady blink) = bad inverters/lamps
2x per second = bad power supply
3x per second = bad main board
If its 1x per second, try doing the factory initialization to get the TV back on to confirm a bad lamp/inverter.
Try doing the Factory Initialization (WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go.
Once the TV turns on, take a look at the screen. Does it flicker then shut off? Or do you hear a buzzing noise from the right edge of the TV? If so, then you have bad inverters or lamps. Once youre done, unplug the tv to get it out of the service menu.
If it is 2x per second or 3x per second, then those boards are just bad and they need to be replaced. There isnt anything you can do right now to fix it.
Mar 27, 2008 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
ON BUTTON BLINKING - CAN'T GET IT TO STOP
what exactly were you doing.. installing cartridge or were you in the process of printing.. it helps to know the situation.
also is there any abnormal sounds during it's initialization(startup).
Let me Know
Jan 16, 2008 | Office Equipment & Supplies
HP PSC 2410 All-In-One InkJet Printer Logo
81 people viewed this question
Seeker5211
Seeker5211
