Please tell me the make and model number of your copier?
well i think it's a toshiba copier and this error means in a toshiba copier could be your exposure lamp..... when you turn on you copier keep the document feeder open and see if the lamp turns on, if it turns on and turn off means its ok.
Then you can clean your white reference guide......it's located under the glass, you need to take off exposure glass and clean under it especially a white strip on the edge of the glass.
note. turn of your copier first then clean after adjustment turn on.
you can also check the following link to check the error codes -
http://www.visualhawk.vcc.ro/toshiba_error_codes_en.html
Thanks
It's a Sharp SF-2030 copier with the C2 error code
Comments:
Oct 02, 2009 - Ok, then this error code means Transfer corona problem or HVT
This error code can be cleared by removing the paper jam also reboot your machine......
i didn't get the remainder of your message please reply
Thanks
