Question about Nintendo Rock Band for Wii
My drums have flashing blue lights and won't work
Drum light will not cut off
The drum light flashes when the drum is almost used up and solid when it is used up. You open the front door and hold the go button til all lights flash and that resets the drum counter. You may need also to run the blue tab on top of the drum back and forth about 20 times to clean the corona...
Feb 01, 2010 | Brother HL 5140 Laser Printer
Wii drum set doesn't work
if the blue light's are flashing on first,second,third,or fourth light then it means your batteries are low or your drum set is for another game
Jan 28, 2010 | Nintendo Rock Band for Wii
Drum light on HL2030 won´t go off!
Open the front door, and press the go button until the lights flash, after closing, press the go button 3 times for a printout showing the drum as full again. The instructions come with the new drum...
Jul 30, 2009 | Brother HL-2030 Laser Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Blue light flashing light, red light on
The flashing means that the toner and/or the imaging drum is empty or missing (printing halts on these errors). Lights on steady means low toner.
Jun 24, 2009 | HP LaserJet 2550n Printer
Drum light flashing
Try resetting the drum counter:
open the front cover, press the blue button and keep it pressed until all the LEDs are lit - hold for a few seconds and then close the front cover.
Feb 21, 2009 | Brother HL-2030 Laser Printer
Rockband special edition for wii....guitar lights and usb light is flashing
Make sure that the Guitar Wireless receiver, microphone, and drums are connected to the USB hub provided with Special Edition. Ensure that the foot pedal is connected to the drum set. Then, perform the following:
1) Ensure you have fresh batteries in the Wireless Guitar
2) Insert receiver into USB hub
3) Turn on Guitar via switch on back.
4) If both the guitar and the USB receiver is flashing blue, then press the guitar logo button until flashing blue light on the receiver stops flashing.
Jan 19, 2009 | Nintendo Rock Band for Wii
Drum Light is flashing yellow
Drum light flashing yellow means the drum is near it's end-of-life. There is some life left in the drum at this point. Do the following to get some more mileage out of your current drum and also when you finally do replace it (this resets the drum counter):
  • Printer on and paper loaded
  • Press and hold blue button until all LEDs light up
  • Release button
Oct 28, 2008 | Brother HL 5140 Laser Printer
Flashing red light
On the alarm and data light blinking, it is saying the toner cartridge is empty. You will need to replace it. Once in a while you can remove the toner cartridge and shake it and have it work for a little while longer. This does not work all the time however.
If you can't get it to work by shaking it, you will need to purchase a new toner cartridge.
When you have the new cartridge, you will need to slide the blue corona wire cleaner back and forth. This is just in front of the toner cartridge in the drum unit on the top of the drum unit. There is a small light blue colored piece of plastic with an arrow in it that you will just push back and forth. This will help the drum unit do its job better.
May 06, 2008 | Brother HL 1440 Laser Printer
Nintendo Rock Band for  Wii Logo
378 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
