I was just given a Mitsubishi VS-4571 tv from my buddy, and it turns off after about 15 minutes of running, then will not turn back on for a long time (overnight) after that. Any suggestions?
  • Michael sWEET Oct 02, 2009
    What can I do to check for those/ fix those. For reference I am a civil engineer with limited electrical experiencs but am very able regarding learning and troubleshooting.
  • Michael sWEET Oct 03, 2009
    I need a solution in less technical terms
    Guru:
  • 830 Answers
Replacing the lamp will fix this problem. Projection tv's lamps have a life of about 8000 hours and depending on how much it was used (not neccesarily how old the tv is), the lamp will need to be replaced. Generally there is a built in timer that will warn you before it goes out but I heard that they didn't start putting these on until they built the earlier models.
Unfortunately, I learned this the hard way and sold two good projection screen tv's when this happened because I assumed they were goners. I have one now that tells me when the lamp needs to be replaced and I just bought it a year ago...already needs a new lamp.
You can find the user manual online that will tell you what part number is needed. Once you get this info, head over to eBay and get a new one for half price. Mine ran me $189.99 but on eBay, I found a new OEM for $69.00.
They are pretty simple to replace and the manual will give you instructions on how to do so.
Hope this helps!
Posted on Oct 03, 2009
    President:
  • 1,922 Answers
One of 2 problems #1) the H.O.T. is overheating and avalanching till it cools/#2)the hi-voltage circuit has gone over voltage specs and the bleeder resistor isnt bringing it back into voltage spec
Posted on Oct 02, 2009
  • daniel  hendrickson
    daniel hendrickson Oct 02, 2009
    the deflection board will be marked on apron and the board, you will see some heat sinks with transistors and your flyback will also be on the board with a heavy red or black insulated single wire going to the screen,it should be about 3" high X 2" around and have two copper lines that split the transformer and it will say transformer/flyback on the board
    also its just easier and less time consuming to replace the whole deflection board with a re-built one under warranty
Our Mitsubishi rear projection TV model VS-60707 keeps turning itself off. it is like it overheated cuz it comes back on after about 15 to 30 minutes being off, it comes back on by itself.
Called a repair man, he adjusted the convergence, with a remote for Mitsubishi. (I lost mine years ago). He thinks that is what was causing the TV to turn off. Time will tell if that cured it.
Dec 07, 2009 | Mitsubishi Televison & Video
Mitsubishi vs 60707
pleaser eset you TV as below.
Turn off and remove the power cord from the main socket.
leave it for about 30 min
turn back on again.
please make sure your sleep mode is off.
May 19, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Vs 4571
you must replaces many electricaly capacitors located on video board
good luck!!
Aug 18, 2008 | Mitsubishi WT-42413 42" Rear Projection...
Mits rear projection VS-4543
i wouldahve the power supply checked out,,,it sounds like it may be getting weak
Jul 08, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mithubishi projection tv VS 4571
Try resoldering the vertical output IC if that doesnt help your IC may be faulty and need replacement
May 10, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
IS THIS TV PLAYING OUT
Color separation is called convergence mis-alignment......that
problem can be repaired...............Blurry,darker when cold may
be a bit of difficulty..............Have a skilled tech give it a look.....T.
Nov 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50707 - Scrambled picture
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Nov 08, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Tv shuts off
When you let it sit for approx. 15 minutes it will come back on and usually stay on. I've also noticed that the color will fade in and out at times. during 15 mts of your sitting do you get sound & less brightness then problem in video or luminance section. if picture is dim & color will fade in and out at times then possibility of crt is getting less voltage on g2. if set is old then there is a possibility of crt getting weak. but if the above things are not there then problem in power supply. good luck
Sep 22, 2007 | Mitsubishi VS-55707 TV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
