Sharp SF-2030 c2 error - Office Equipment & Supplies
    Guru:
  • 389 Answers
C2 Transfer corona problem or HVT
See the corona of the carrying the scene. Recommend to clean and выдуть toner, better retighten and install the new corona. If mistake S2 will be repeated look the breakdown of high power in the dark and if his(its) no, look the transformer of high power. All.
1 Corona
2 Transformers of high power.
Posted on Oct 03, 2009
My printer is saying i should replace used toner container?
Dear User,
I am sharing with you the following objects to help you achieve your desired results,
1. Service manual of your printer to understand the problem
2. A link to step by step, with pictures to understand how it is done for a Samsung printer (will help you understand the process)
Link 1. : http://diagramasde.com/diagramas/otros/SF2025_SERVICIO.pdf
Link 2 : http://www.samsung.com/us/support/howtoguide/N0000190/12120/144599
Regards,
Sid
Nov 13, 2014 | Sharp SF-2030 - Lower Pressure Roller -...
How to check the meter
just push the 0 key or cancel key, just try you can read the counter
Jun 24, 2013 | Sharp SF-2025/2030 Copier Toner Black...
Code error H2
h2 means the open the termistor.
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 03, 2012 | Sharp SF-2025/2030 Copier Toner Black...
I have sharp AR-163 it indicate f5 error. And Sf 2030 error code f2
Ar163 F5 = Copy lamp problem.
Possible causes are:
Blown Copy Lamp
Inverter trouble (copy lamp driver module)
MCU Board failure
This is most likely to be a blown copy lamp.
Ar2030 F2 is a process control error - depending on the sub-code it could be a number of different things. Please repost with the full code.
Hope this helps.
Feb 09, 2011 | Sharp SF 2540 Copier
U3/ sf 2030 sf
U3 PROBLEM MIRROR LENS ERROR REMOVE DARK COVER LUBRICATE LENS DRIVE RAIL THIS SHOULD SORT THE PROBLEM OUT
Oct 21, 2010 | Sharp Office Equipment & Supplies
Sharp SF 2030: How do I clear code 115?
we don`t have code 115 in 2030 model .maybi it is H5 but your led doesn`t show.
May 18, 2010 | Office Equipment & Supplies
How to clear a C2 code on a Sharp copier?
C2 error appears due to one of the following 1. TC Unit malfunction or 2. Current leak at coronas or HV supply unit.
See the corona of the carrying the scene. Recommend to clean and reset toner, better re-tighten and install a new corona. If error S2 is appearing look at the breakdown of high power in the dark and look its nos, look the transformer of high power.
1 Corona
Mar 24, 2010 | Sharp SF 2020 Copier
Error f1
How do you do. You should check join from the main of the charge to device сортера.If connections is checked and where are no mistakes in join no pay attention to mechanical possible damages, findings scrap papers and stranger subject in sorter device. Recall, pr what circumstance appeared the fault.Error code F1 for sharp copiers sf 2020.2030 Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive.
Sep 23, 2009 | Sharp SF 2020 Copier
I have a Sharp SF-2030 copier and it is diplaying a F1 code.
F1 FIRST OF ALL CHECK WHAT IS THE SUB CODE .IF SUB CODE IS 00 ITS COMMUNICATION ERROR BETWEEN MAIN BOARD AND FINISHER.IF 01 FINISHER SHIFT PROBLEM.IF 06 FINISHER MOTOR PROBLEM.IF 10 THAT IS STAPLER PROBLEM.DO NOT FORGET TO RATE THE SOLUTION.MIAN JEE
Feb 21, 2009 | Sharp SF 2020 Copier
Diagnostic codes for Sharp SF-2014 copier
Sharp SF 2030 On power need enter operator key code, need reset.Please help.
Jan 06, 2009 | Sharp Office Equipment & Supplies
97 people viewed this question
jasbo
jasbo
