Question about Refrigerators
My fridge seems to be getting water on the bottom and it turns into ice under my vege bin. I checked the little drip tray and that isn't frozen.
    President:
  • 1,304 Answers
Check your water filter it could be dripping from a small crack
Posted on Oct 03, 2009
Scotsman DCE33A-1WB not draining
Check that Ice cubes are freeezing completely before dumping into tray.
Check that spray nozzle isn't inadverdantly clogged and spraying water everywhere.
Check that water inlet solenoid is actually closing and not leaking water into bin.
Check thermostat for the bin not working properly, frozen over or something.
Oct 31, 2012 | Scotsman Refrigerators
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
I have an LG LFC21770 refrigerator and have noticed a build up of ice on the back wall of the freezer section. Yesterday, when I opened it to get some ice - the ice was frozen but had obviously melted...
If the freezer fails to defrost you get ice building up at the back of the freezer.
The defrost cycle relies in a thermistor transducer to detect the ice build up and to turn on the defrost cycle. The water usually then drips down to a tray under te fridge and then gets evaporated away.
Hopefully you only have a problem with the thermistor and not the defrost circuitry,
This is hard for a repair man to diagnose as when you call them out to your fridge it will be impossible to diagnose if the freezer is totally packed with ice.
And if you let it defrost totally it will be hard to diagnose as they may not be allowed to use freon to cool the transducer.'
So if you call someone in to check this you need to know if the ice build up will be a problem for them .
Youtube has several videos on this situation .
Apr 21, 2017 | LG LFC21760 Bottom Freezer French Door...
Water drips down from Freezer. The water is coming
Since you said the water supply is shut off, the likely culprit is a clogged drain tube that connects the defrost tray to the water collection pan for evaporation at the bottom of the fridge.
The source of the clog is usually either mold growth or more likely, ice build up. Regardless of which, if you access the defrost heater in the freezer section, you can thaw ice that has collected in the tray and if needed, use a turkey baster to direct a hot stream of water at the point the hose attaches to the tray and treat the hose for mold, below.
Once cleared of ice, mix a small amount (5 or 6 oz) of water and 1/2 to 1 ounce of bleach and direct down the tube to kill any mold / growth. Be careful not to use to much or overflow, as clean up will be difficult due to the bleach mixture.
The next thing to do (if icing up) is to determine why. A careful check of the defrost circuit should be done. Otherwise, you'll be doing this over - and it may start to affect the temperatures in the frozen and fresh food sections of the fridge.
I hope this helps!
Nov 05, 2009 | Air Purifiers
Fridge Leak
We fixed the leak by putting a pipe cleaner down the hole inside the fridge, at the back. This cleared the tube as it had gunk and grime blocking it. Now the water can run freely down the tube and into the drip tray which is at the back of the fridge above the motor.
Jun 12, 2009 | Fisher Refrigerators
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Water line freezing
I have a lot of ice in the freezer and ice is forming and catching vege bins in refrigerator
Jan 06, 2009 | Fisher and Paykel Active Smart E522B...
Kenmore 795.755744
I have a trio 7755 and had this problem within 6 months of ownership. It was the valves that fill the ice trays not completely closing when tray is filled (continued to drip--building up an ice block on the back wall and in the ice tray. I replaced the set of valves in the lower right (when looking at the back of the fridge). Problem solved, has worked perfectly since.
May 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice tray sometimes stuck when dumping off ice
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
Mar 24, 2008 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
