Question about Technics SL-BD22 Turntable
I PURCHASED A LIKE NEW TECHNICS SL BD27 TURNTABLE. I HOOKED THE RCA AUDIO JACKS TO THE AUDIO INPUT ON MY SONY TV AND GET VERY LOW SOUND LEVEL WHEN TV VOLUME CONTROL IS AT MAX. REPLACING CARTRIDGE AND STYLIS MADE NO DIFFERENCE, DO I NEED A PRE AMP OR DO I HAVE ANOTHER PROBLEM?
  • 3,153 Answers
Yes you need a pre amp
It would also be the same if you connected it to a computer to record an LP to CD. Mine is a little different and has one already built in that I can switch in and out of line.
Try spend a little more if you can as many pre amps can introduce noise.
You may also want to check that the turntable is properly grounded to prevent noise too
Posted on Oct 02, 2009
Testimonial: "VERY FAST RESPONSE. THANKS"
Is it possible to connect a turntable to a technics HD51 amplifier ? There isnt a phono conection point
Are there any RCA audio input jacks maybe with the video labled "Aux"? If so, you can use only the Red and White jacks leaving the Yellow(Video) unconnected. Maybe you can attach a photo of the rear of this amplifier where the inputs are so we can show you another possibility...the mini computer input jack would be another choice with an adapter. Dave
Dec 23, 2014 | Technics Audio Players & Recorders
NO SOUND WITH EVERYTHING PLUG IN .
I assume that you're talking about the output from the 2 RCA Phono Jacks? Does this turntable output a "Line Level" signal, or a standard millivolt level 'turntable signal'? If it is an older 'standard turntable', then you need to run it into an amplifier that has a "PHONO" input and ground wire. This will amplify the tiny signal to a 'line level' signal that you can record or run to a computer, etc. If you do not have an older amplifier with "PHONO" input jacks, then you need to buy a separate stand-alone 'phono amp/preamp' that will boost your (tiny 10mv) turntable cartridge levels high enough (.5 to 1 volt) to record on another device. Let me know if that is the case. Good luck.
Jul 24, 2010 | Technics SL-1200MK2 Turntable
SL-BD22 SETUP
go to RADIO SHACK and get a pre amplifier module (hope its still available) , that will do the trick , AJ
May 20, 2009 | Technics SL-BD22 Turntable
Technics turntable model SL-bd27. center spindle rubbing noise.
hi, try to open or remove the platter on the deck, maybee there some small thing inside..
Apr 09, 2009 | Technics SL-1200M3D Turntable
Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Apr 07, 2009 | Technics SL-BD22 Turntable
How to connect turntable Technics SL BD20 to marantz SR7000 amp
Most recievers should have Phono Jacks labled on the back. That is where my Turntable an (MCS made by Technics but was sold under the J. C. Penneys name) connects on my JVC. I have 2 JVC 's One is old (1972) and one is new. Both of them have Phono jacks. Phono stands for Phonograph. This is an old term for turntables. The jacks should accept RCA patch cords. Good luck.
Apr 21, 2008 | Audio Players & Recorders
Where is the ground wire connected to on the Technics SL-BD27?
You will more than likely need to wire it up from the inside of the unit, unfortunately. Parts for this model are discontinued. You can also try an iPod cable. As the size is a 1/8" plug - same as an iPod cable, then just cut the other end, and ground to your receiver.
- TERMiNAL OPTiC
TWEAK AV REPAIR
Jan 09, 2008 | Technics SL-1200M3D Turntable
Turntable technics sl-bd27
You have 4 wires coming from the needle pickup to the cables which connect to the amplifier/receiver. I would check the needle, the pickup unit, and the leads from the pickup to the cables. You can probably run a continuity test or ohm test for verification. If that checks, pickup and needle is your next step.
Dec 18, 2007 | Technics SL-1200M3D Turntable
Technics SL-BD22 Turntable Logo
1,965 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
