Miele S171 Bagged Upright Vacuum Logo
Posted on Oct 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Miele silver canister vacuum has a clog in its hose. Can I fix it myself?
Anonymous
Level 2:
Sergeant:
  • Expert 302 Answers
  • Posted on Oct 03, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
302
Questions
0
Helped
116148
Points
740
Sure you can. get a broom handle, pound a large finish nail into the end and bend the nail into a hook shape. stick the broom handle in the hose which needs to be straight and use the nail hook to grab and pull out the clog. hope this helps you.
My Vacuum constantly switches down from Max to Min vacuum speed.
Someone gave me a Miele S558 with this exact problem and I fixed it by disassembling the power hose and cleaning the contacts, bend them a little bit so that they exerted more force onto the metal ring, and reassembling. The end of the hose that attaches to the canister had the worst connection and this end was the most difficult to disassemble (I actually could not disassemble it completely, just enough to pull out the contacts and cleaning/bend them). Check other answers for how to clean the power hose contacts for more details on how to do this, I'm just saying that cleaning them did fix my problem. Good luck!
My miele silver moon attachment brush stopped spinning. the belt looks good what could it be
It is most likely the hose. There are wires inside the hose that connect the speed and suction control on the handle, to the board inside the canister. After years of use, the wires can become damaged to the point that they wont complete the circuit anymore. Any vacuum store that sells miele will have the replacement hose. You can also get it from miele directly, or off ebay. Be careful going to the vacuum store if you dont have a trusted shop, as they make more money from the sale of a new vacuum, rather than a replacement hose.
Power Problem
Hi There,
Unfortunately this is being caused by static electricity building up in the electronic controls in the handle of the hose. I've seen this problem on numerious occasions, and in fact I have the twin brother of the Blue Moon, or the Silver Moon which used the same hose, and has the same problems in my own home.
The good news is that Miele has redesigned the hoses to fix this, and I have never seen a single problem on the newer style hoses. I guess the bad news is that the hose is not cheap.
I would recommend to you to go ahead and purchase the new hose. The average life expectancy of your Miele is 20-25 years, so you still have a lot of life left in your vacuum.
Here's a link to the SES125 Hose that fits your Miele Blue Moon on our website:
http://www.govacuum.com/miele-165.html
To change the hoses out, simply push the two tabs on the end of the hose that plugs into the vacuum, and pull the hose backwards until it disconnects. You'll see on the end of the new hose electrical connectors. Simply line these up with the opposity receptacles on the canister and push the hose down until you hear a snapping noise.
I really hope that this information was helpful to you. If you have any follow up questions, or would like a clarification, please use the comment box on this page.
If this was able to help you fix your machine, please be so kind and rate my repair or leave me feedback. This is really appreciated.
Thanks again,
Chris Jones
GoVacuum.com
My Miele Red Star suddenly has very weak suction
Either motor is clogged with dust or suction hose is clogged, replace bad also.
1helpful
S248i canister vacuum: electric cord retractor kaput
It is pretty tough to fix a retractor. Maybe hook direct and wind up the cord manual like uprights.
My almost new miele Dog and Cat vac keeps telling me the bag is full when it's not (new bag, no clogs)and I have almost no suction. Any ideas?
Remove the hose and check the suction. It it is still bad check to see if the canister is closing on the bag. Most likely the hepa filter needs replaced. Here http://www.totalvac.com/mielevacuumcleanerfilters.htm
Miele Deluxe 5247i Air Clean Plus Canniter
most vacuum hoses are made so you screw off the end attachment not real familiar with your model but pretty sure you can do that then just disattatch from canister and run broom handle through it hope this helps
Miele big blue
Could be a problem with the cord. There also is a circuit board by the motor that could be the problem. Did you drop something in the hose to see if it comes out the other end? Because you could have a clog. Or just unhook the hose and see if it runs that way.
3helpful
My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Top Miele Vacuums Experts
john h
Ngoro
jws1013
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
