Question about Kyocera FS- 4000DTN Laser Printer
Says paper jam, then open and shut top door and it prints.
4 Suggested Answers
  • 62 Answers
SOURCE: Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Posted on Jul 07, 2010
SOURCE: Says there is a paper jam and to open top cover
When your reports paper jam for any reason, whether there is paper jam or not, most times you need to go thruogh paper jam clearing procedure to have your printer printing again. So please follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Put off the printer and unplug it from its power source.
Open all the covers/shutters on the printer (usually you will find one in the front or top and one at the back of the printer).
(If the printer is a DeskJet, otherwise ignore this step) Now pull out the cartridge carefully and place it on safe surface. (Be careful not to place it where it may slide and fall. This could damage the cartridge)
Site the paper that has jammed and pull it out in the opposite direction of its movement. Do not pull in the direction it was coming out. (Pulling the paper in the opposite direction is important for the printer's mechanism. Printer must be off). Never pull out paper from a printer when the printer is powered on.
(If the printer is a DeskJet, otherwise ignore this step) Return the cartridge gently and press it firmly inside so that you here it snap inside.
Close all covers at the top, front or back.
Power on your printer and you should be able to print again.
Good luck and God bless!
Posted on Mar 04, 2011
Testimonial: "Thanks - I will follow this and see what happens!! Have a great day! "
zsomboribala
  • 11 Answers
SOURCE: My Kyocera FS-2000D always says
The problem should be with the transfer roller.
Open top cover and remove developer unit by pulling (it's under toner).
Open left side cover. Reomve the waste toner box by pulling a lever in its neck. There wil be a gray buttom on the drum unit. If you push it, you can pull out the drum unit. Better safe then sorry, avoid direct light, and any other dabage-hazard. The Drum is really very sesible indeed. Place it somewhere in safe and secure.
I you now opet top cover, and take your hand into the hole, you can realize, if the transfer roller isn't moving.
Try to rotate it by cw and ccw. Don't pollute this area! The only one thing you can do to wipe the transferroller softly.
Then put bak the drum, the waste t. box. The gray bottom in the drum unit have to stand vertically. Push it ttill it "click".
Then put back the developer unit with the toner.
Try to squeeze the side covers softly by bare hands. Furthermore do the same with top cover. Close rear unit if nessesary.
Try to cleaan the pickup rollers in the begining of the paper tray.
Try to replace the papers.
I hope my answer will help you.
I used to have the same problem.
Fell free to ask!
Posted on Oct 11, 2011
I have a piece of paper stuck in the top of my hp 1012 printer and I cannot get at the area where the paper is.
Follow these steps to remove jammed paper from the printer
1.Open the print cartridge door, and then remove the print cartridge.
NOTE:  Opening the print cartridge door and removing the print cartridge relieves tension on the product rollers, which prevents damage to the product and makes the removal of jammed pages easier.
Figure 1: Open the print cartridge door and remove the print cartridge
CAUTION:  To prevent damage to the print cartridge, cover it with a sheet of paper to minimize exposure to direct light.
2.With both hands, grasp the paper where it is most visible, including the middle, and then carefully pull the paper straight out of the product.
Figure 2: Remove the jammed paper
3.Look inside the product for any torn pieces of paper or labels, and then remove them.
4.If any jammed paper remains in the input tray or the output tray, grasp it with both hands and gently remove it.
5.Reinstall the print cartridge, and then close the print cartridge door.
Figure 3: Reinstall print cartridge and close print cartridge door
1.Press the Power switch to turn off the product.
2.Wait 30 seconds, and then press the Power switch to turn on the product.
Happy printing.
Regards,
Shrey
Jun 02, 2011 | Office Equipment & Supplies
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
I am having repeated paper jams in the rear door of y HP 4200. It occurs right when the paper hits the rollers to go into the outbin, and the paper stops and jams in the rear door area. I have to open...
It's been a while since I worked on a 4200. Will it print if you keep the back door open?
If yes, does it jam?
If yes, and it doesn't jam, replace the paper delivery assembly(RM1-0026-040CN)
Dec 23, 2010 | HP LaserJet 4200 Printer
Hp deskjet 6940 paper jam light blinking every time i try to print. no paper jammed, have opened and closed all doors, turned the wheels as the other help indicators say, but still it will not print. ...
This past Saturday we just had a similiar problem on our church HP printer. Different number than yours, but most likely the same solution. It jammed when the last person used it, so they removed the crinkled paper. Or so they thought - there was a piece maybe 1-1/2" triangular shape stuck on top. I liked to never found it, I looked even with a flashlight 4 times before I caught just a hint of white way up there. If that is not it, there could be a door you have not opened. Most of them open top, back, front. Ours also opens on the side. The back opens in two places. Occasionally there can be a piece of paper you can only see from one door.
Dec 14, 2017 | HP Deskjet 6940 InkJet Printer
HP LJ P3005 13.31.00 ERROR
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Solution:
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
Apr 11, 2009 | HP LaserJet P3005n Printer
Paper jam after first page prints.
Most likely something in the printer or software is set to an improper paper size. It's saying jam because it prints the first page and registers an incorret size.
Check BOTH the printer itself and the program you're printing from.
Feb 26, 2009 | Dell 1600n All-In-One Laser Printer
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
ON button on hp photosmart C5280 will not turn off. keep saying paperjam but there is no paper.
Open and clean your printer with some air compress can.
Check the cartridges, take out and put them on place again
Unplug the printer for a while and plug in again
Reset the printer to factory settings
If still not shut down, the printer need to be serviced
Solution one: Clear the jam from the back of the All-in-One
Follow these steps to clear a paper jam from the back of the product.
CAUTION: Trying to clear a paper jam from the front of the product can damage the print mechanism. Gain access to and clear paper jams through the rear door whenever possible.
Step one: Remove any loose paper
Remove any loose paper from the input tray.
CAUTION: Do not remove jammed paper at this stage.
Step two: Clear the jam from the rear access door
Press the Power button ( ) to turn the product off.
Unplug the power cord from the back of the product.
Turn the product so that you can access the back of the product.
Press in the tab on the left side of the rear access door to release it. Pull the door away from the product to remove it.
Figure 1: Remove the rear access door
Gently pull the jammed paper out of the rollers.
CAUTION: If the paper tears, check the rollers and wheels for torn pieces of paper that might remain inside the product. Remove all the pieces of paper from the product to prevent more paper jams.
Reinsert the rear door. Gently push the door forward until it snaps into place.
Plug the power cord into the product again.
Press the Power button ( ) to turn the product on.
Press OK to continue the current print job.
NOTE: Sometimes the print job cancels instead of continuing when you press OK . If this happens, restart the print job beginning with the page number when the jam occurred.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Solution two: Open the top cover and clear the jam
If you cannot remove the paper jam from the back of the product, follow these steps to remove the paper jam from the top.
CAUTION: Remove the paper jam carefully, because it is possible to damage the product when removing paper from the top.
With the product still turned on, unplug the power cord from the product.
Raise the cartridge door.
Figure 2: Raise the cartridge door
Gently pull any jammed paper out of the rollers.
Close the cartridge door.
Figure 3: Close the cartridge door
Wait until the product is idle and silent, and then try the print job again.
Solution three: Clean the rollers
Follow these steps to clean the paper feed rollers and the pressure rollers to remove any debris, dirt, or paper scraps.
Figure 4: Remove the rear access door
Lightly moisten a lint-free cloth with distilled water, and then wipe the rollers inside the product with the cloth. Rotate the rollers upward with your fingers to clean the entire surface.
Wipe the pressure rollers on the inside the rear access door in the same manner as you did for the rollers inside the product.
Allow the rollers to dry completely.
Reinsert the rear access door. Gently push the door forward until it snaps into place.
Try the print job again.
Solution four: Reload paper and check the print settings
Follow the steps to reload paper and check the print settings. The print settings must match the type of paper in the product.
Step one: Reload paper
Raise the output tray.
Slide the paper-width guide to its outermost position.
Figure 5: Slide paper-width guide outward
Fan a stack of paper to make sure the pages are not stuck together. Then tap the stack on a flat surface to align the edges.
Load the stack of paper in the main paper tray with the short edge forward and the print side down. Slide the stack forward until it stops.
Figure 6: Load paper in main paper tray
Slide the paper-width guide inward until it stops at the edge of the paper. Do not overload the main paper tray. Make sure the stack of paper fits within the main paper tray and is no higher than the top of the paper-width guide.
Figure 7: Slide paper-width guide inward
Lower the output tray, and then pull the output-tray extension toward you as far as it goes.
Step two: Check the print settings
Open the program that you were using to print when the paper jam occurred.
Click File , and then click Print . The Print dialog box opens.
Click Properties . The Document Properties dialog box opens.
Click the Paper/Quality tab.
Make sure the Paper size and Paper type settings match the paper loaded in the product.
NOTE: A paper jam might occur if the Document Properties dialog box lists photo paper, but plain paper is loaded in the product.
Click OK , and then click OK again to print the document.
Solution five: Reset the All-in-One
Press the Power button ( ) to turn off the product.
NOTE: The product might not turn off after pressing the Power button. Continue to the next step regardless.
Disconnect the power cord from the back of the product.
Disconnect the power cord from the electrical outlet, and then wait 30 seconds.
Connect the power cord to the electrical outlet.
Connect the power cord to the back of the product.
Press the Power button ( ) to turn on the product.
Step six: Service the All-in-One
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Nov 06, 2008 | HP Office Equipment & Supplies
I was wrong...
This is a common issue if you are using generic or remanufactured toner cartridges. However, if you are using authentic Samsung cartridges, then check that the paper size is correctly defined in the application you are printing from (i.e. Word, Excel, etc.). If both issues are ok, then my last guide is to take the unit to an Authorized Service Center and have the paper path senors replaced.
Oct 30, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Kyocera FS- 4000DTN Laser Printer Logo
23 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
