Question about Xantrex Technology DR2412 Inverter / Charger
I am connecting the input wires... I know where
I am connecting the input wires... I know where to connect these... the ground is in the center and the other 2 connect right next to this...
Does it matter which of the 2 leads are connected to the 2 connectors for in input?
I got no where with this site -- so I found the manual for the xantrex (google search) and downloaded the info I needed. No charge!
Posted on Oct 05, 2009
Jet sound equalizer js 214 wire color code
Black wire is ground, Red with 5a fuse is hot. Green/black is L Ground BTL, Grey /black is right ground BTL, the RCAs are left and right low level inputs. Then there is the 5 pin connector. It has a red wire for +12v, two black wires for input grounds, a green wire for left Hi input and a gray wire for right high input. If you install using traditional common ground high level, then you don't used the two BTL wires. Just connect the wires from your 5 pin connctor. If you use the low level RCAs for inputs, then you only need to connect the red and black from your 5 pin connector.(Plus the main red and black) Make sure the switched on the bottom of your EQ are set correctly. COM for common ground and LOW for RCA input or High for Green/Gray wire input. If you are using a floating ground the select BTL and connect the two BTL wires to the floating grounds of your stereo. There is also a line input adjuster so you can adjust your input sensitivity to match your reciever. I have the owners manual if you have any other questions.
Feb 01, 2012 | Car Audio & Video
I am installing a 30 amp cord on my Whirlpool dryer. The model number is WED5100VQ. I am having a problem finding the ground wire in which to ground the dryer because it only has a white wire coming from...
On whirlpool (all manufacture) dryers the ground wire is linked to the center terminal with the white wire and attaches to the cabinet grounding all metal on dryer since on panel attaches to the next making the entire cabinet have continuty through the neutral/ground wire.
When connecting 3 wire cord connect the two outside wires to red/black on cord block and center wire to white/center terminal connection on block.
For a 4 wire cord red to red black to black white to white and the green to rear of cabinet/any panel near block
(same question listed 2 times gets same answer 2 times)
Aug 13, 2011 | Whirlpool Dryers
Wires
Wiring Connections
1. TV TUNER
2. ANTENNA
3. POWER ANTENNA WIRE (Blue) – Connect to a motorized (power)
antenna and/or to a remote turn-on lead for an amplifier.
4. CONSTANT POWER WIRE (Yellow) – Connect the 12V PLUS constant
power wire to a live 12 volt wire in the vehicle. Before making a connection,
check that the wire you intend to connect it to is always live, even when the
car’s ignition is turned off. If a live wire is not found, route the wire to the
car’s fuse block and connect it to a live circuit there.
5. GROUND WIRE (Black) – Securely fasten the Ground wire to a grounded
metal part of the car’s chassis. If you cannot find an existing bolt or screw
to fasten it to, drill a hole in the metal and secure it with a screw. To ensure
a good ground, remove any paint or grease from areas where the wire will
contact the surface.
6. PARKING (Pink) – Connect to negative parking brake wire. This wire
MUST BE connected in accordance with federal, state and local laws. It is
the end-user’s responsibility to make sure this wire is connected properly.
7. ACC POWER WIRE (Red) – Connect to a +12 volt circuit that is only live
when the ignition is on. The best connection point is at the car’s fuse block
at the “RADIO” or “ACCESSORY” identified terminals.
8. LEFT FRONT SPEAKER (white, white/black)
9. RIGHT FRONT SPEAKER (gray, gray/black
10. LEFT REAR SPEAKER (green, green/black)
11. RIGHT REAR ( + ) SPEAKER (violet, violet/black)
12. FRONT AND REAR RCA OUTPUTS
13. CENTER RCA OUTPUT (Gray) – The center output must be connected to
an external amplifier for 3D or 6-CH mode.
14. SUBWOOFER RCA OUTPUT (Blue) – The subwoofer output is available
in all sound/audio modes.
15. DEDICATED DVD OUTPUT – Video output for rear screen and left/right
audio output for headphones.
16. AV1 INPUT
17. AV2 INPUT
18. VIDEO OUT (Yellow) - V. SEL output for rear screen.
Or you can go to link below for the manual page 4
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ's/VM9510_DOC_OM.pdf
Good Luck and please rate 4 thumbs for the free answer
Mar 31, 2010 | Jensen VM9510 Car DVD Player
Dryer outlet does not have common wire.
You can replace the 4 prong with a three prog cord found at Lowes etc.
First, disconnect the black wire, one of the "hot" connections, from the left side post by removing the terminal screw. This is one-half of the 240-volt connection.
Next, disconnect the red wire, another of the "hot" connections, from the right side post by removing the terminal screw. This is the other half of the 240-volt connection.
Then, disconnect the white wire from the center connection. It is used for the neutral connection.
Now, disconnect the green wire from the machine case by unscrewing the green screw.
The next step is critical to return your electrical connection to factory condition before installng the 3-prong cord! Locate the white machine wire that is now connected to the neutral (center) screw terminal. Disconnect it from there and install it under the green ground screw.Connect the outer two wires (hot wires) to the outer two screws, obviously, one on each screw.
Now connect the center wire (neutral) to the center post. You'll notice the white machine wire is now the case ground connection, unlike the 4-prong cord connection in which the green wire from the cord makes the ground connection.
Sep 10, 2009 | Dryers
Mintek Fix
Mike
No problem. What I was suggesting you could do with the speakers is to splice the positive (it should be red or white) speaker wire to the hot part another separate RCA (I used the side input) jack and the ground to the jack's ground sleeve (the outer part). So the process is similar to what you're already doing with the component RCAs and wires. Once this is done you can hook a receiver up to the built in speakers in the TV with no hassle. The speakers will not be powered, however, so you can't just hook the audio output from your cable box to the TV. All this process allows you to do is hook a powered amp or receiver to the speakers.
What I meant by saying to make sure there are no grounds was to double check and make sure each bit solder did not bridge over to another strand of metal or the metal chassis of the TV and cause a short or a ground.
Anything else, just let me know.
Ryan
Mar 11, 2008 | Mintek DTV-263 26 in. LCD Television
Mintek Fix
It may be a little different on the 26" model. It's been several months since I did the repair so my memory is a little fuzzy. It sounds like the non flat strands are a common ground and the flat ones are the hot wires. The best thing to do would be to take a multimeter and test for continuity on the center of the RCA jack and the flat strand of metal. If you get a reading, that is where the input wire should be soldered. More than likely you're correct and you should proceed as you found logical.
All you're really doing is making a new connection for the component input on the back of the TV. So just make sure that each hot wire from the DVD player will be on the strand of metal that corresponds with the hot wire from the component RCA jack, which is the center part of the jack, not the outer metal sleeve. In theory you could just attach all of the grounds from the DVD player to any metal part of the TV; I do not know if this will work however because the set might have a failsafe on the motherboard, not allowing video pass through when grounds are not detected.
I hope this helps! And please let me know if you get it working or have any other issues.
Ryan
Need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Feb 17, 2008 | Cameras
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Wiring Installation - Satellite Radio
The wire that runs along with the P-bus cable connects to constant power; the other wire needs to be grounded.
Jan 08, 2007 | Pioneer GEX-P910XM Satellite Radio...
Xantrex Technology DR2412 Inverter / Charger Logo
Top Xantrex Technology Electronics - Others Experts
Craig Butler
Craig Butler
EE Eddie
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
