Question about GE Spacemaker JVM1640SJ Microwave Oven
My JVM1740SM1SS over door has a stain inside the window between the black lining. How can I clean it?
  • 11 more comments
  • Debbie Lewis Feb 22, 2010
    Are you talking about the hard black plastic around the inside window?
    The only screws I see are for the door handle
    Do I need to unscrew the handle first?
    I have taken off the hard plastic around the inside of the microwave door and taken the screws and handle off but I still cannot get to the inside window to clean.
    The stain is in between the glass. I need to get to it first.
    Same problem--stain in between outside window and black metal shield of the microwave door. I cannot get to it. How can I get to it?
    I took that part off and then the door handle but don't know how the rest comes off. It is pretty tight. Do I take off the springs to the latches and then try to remove the next piece? I do not see any clips??
    It is a stainless steel door on the outside.
    I do have the manuel but it doesn't tell you how to take it apart.
  • Debbie Lewis Feb 23, 2010
    I am talking about inside the door window and black metal shield. There is a stain that got in there from steam or something that I can't get to. That is why I need to take the door apart.
    Please, I am trying to get a stain that is in the microwave window and black metal shield. I cannot get to it. How can I take the door apart?
    So far I have not received much help on cleaning between the microwave glass and inside of door. I don't think anyone understands.
  • Debbie Lewis Feb 24, 2010
    I have taken off the hard plastic around the window when I open the door and removed the screws from the handle now I don't know how to get into the glass. There is a metal piece all around and it looks like there are dimpled areas but I don't know if that comes off.
    President:
  • 1,891 Answers
The jvm model ss door / open the door and inside there is a black border around the screen / this will pop out with a putty knife . after removing it you will be able to remove the glass and screen to clean. . stains are caused when food blow's up . if you have a handle modle there are two screw's inside the ring . most of this should be done with a ridgid type putty knife as not to brake the plastic . 2 in blade.. hope this help **** ..
Posted on Feb 23, 2010
  • dennis dodge Feb 24, 2010
    hi /Im back . to help . the area you are working in is not normaly a user area / but i do understand your problem . the springs will have to be removed and any pressure points that hold the screen are to be released with the putty knife . they do fit very tight as if they did not you would have leakage . i think you are doing a good job. / the ring is removed and handle / do the springs and pry the holding points to relace the screen . if screen does not clean it may have to be replaced . **** ..
  • 1,428 Answers
Get an oven stain cleaner to do the trick.
Some soil from cooking operations is usually present. The catalyst is continually working to oxidize soil when the oven is hot enough, thus the "continuous" clean name. The rough porous surface spreads out greasy soil, thus increasing contact with hot air in the oven. Fats and oils are quickly oxidized; milk and cheese take higher temperatures (about 475 F.); sugar spills are hardest to remove so protection from spills like fruit pie boil-overs is important.
If large spills occur, you have to remove the promptly to stop the "glazing" effect which seals the surface and prevents oxidation of soil. Follow this procedure:
1. Blot up excess with paper towel or sponge while oven is still slightly warm and the soil soft. Do not rub towel or sponge across surface; particles may clog the surface.
2. After the oven is completely cool, spray the soil area with all-purpose spray-on/wipe-off cleaner ("Fantastik", "409", etc.). Work into porous surface by scrubbing with a nylon-bristle brush or nylon net pad. Let stand 15-30 minutes.
3. Scrub softened soil with the nylon brush or pad.
4. Rinse thoroughly with cold water, by squeezing out clean, wet sponge over area; then blot up (not mop up) excess water with paper towel or sponge. (Do not let water run down into burner assembly, especially in gas ovens.) Repeat rinsing and blotting, if needed, to remove all softened soil and cleaner residue.
5. Turn on oven at 475 F. and leave two hours. If some soil remains, the continuous-cleaning coating should work to oxidize it.
CAUTION: Spray-on/wipe-off cleaners volatize rapidly with heat and may leave a chalky stain, hard to remove. So do not apply to a warm oven, and be sure to rinse away all residue.
Occasionally wipe out whole inside of oven with a nylon pad and plain water; blot dry and then run oven empty for 2 hours at 475 F. This helps the oven catch up with accumulated grease and soil. This may be needed when the oven is used for more broiling and roasting (with more grease spatters) but short time cooking (broiling) or lower temperature (roasting), than for baking. This also helps clean the door, which usually get less heat in cooking.
NEVER use oven cleaners on continuous-clean ovens, as they will clog the pores in the coating, and, may damage the coating, or the aluminum backing if it is used.
NEVER use scouring powders or any other powdered cleaners, as they will clog the coating, and the abrasive action also damages it.
NEVER use any metal pads or abrasives, as they will wear off the coating, and also metal filings may come off and clog the coating. Manually clean oven racks.
Visit http://www.pioneerthinking.com/stove.html
Good luck and thanks for using Fixya.
Do remember to rate this solution.
  • Titilayo Sodipe Feb 23, 2010
    Of course you need to remove the crews first and you sure have to be very careful about this so as not to break the glass.
    be careful dear.
    President:
  • 563 Answers
Hi djl4.
You have to take the door apart from the microwave to clean that stain.
Now, open the door of the microwave, you will see all the way around the oven, there is a trim about 2 inch wide. You can use a kitchen putty knife or any putty knife that you have to pop/lift the trim out. After that, you will see the door is held together with a few clips. Then you can start the cleaning using a soft cloth with detergent to clean the stain.
Hope it helps.
Posted on Feb 22, 2010
  • 1 more comment
  • Naajiyah Auladin
    Naajiyah Auladin Feb 22, 2010
    Do you have the manual with pictures so that it can guide you to open the door? If there's no clips, is there any screw or it can be the spring.
  • Naajiyah Auladin
    You should be careful when you clean the door as cleaning it with chemical or bleach can damage the colour of the oven. What type of door it is, stainless steel, graphite or cleansteel?
  • Naajiyah Auladin
    Hello. The stainless steel door can be clean with a clean soft cloth, do not use any detergent except you can use the stainless steel magic or any other suitable product used to clean stainless steel. If you cannot see the clips try the spring or unscrew it.
    President:
  • 1,871 Answers
Hello :
Follow these instructions :
  1. Wipe down the microwave with warm soapy water and a clean cloth or sponge. Use a grease-cutting dish soap such as Dawn. This will help to remove the first layer which is usually just grease. Wipe the area with a clean damp cloth.
  2. Apply nail polish remover with acetone to cotton balls and use them to wipe the stain with. Remove as much of the stain as possible. Most or all of the stain should come off with the nail polish remover. Use new cotton balls as the old one gets too dirty and discard them.
  3. Make a solution of equal parts vinegar and water and wipe down the microwave with a clean cloth dipped in the solution.
  4. Wipe the microwave with a damp clean cloth to rinse.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Things you need :
  • Dish soap
  • Soft clean cloth
  • Nail polish remover
  • Vinegar
Tips & Warnings
  • Place two scoops of fresh coffee grounds into a ceramic cup and fill halfway full with water. Set the cup in a bowl to catch any water that boils out and put it in the microwave for two minutes. This will help to eliminate any residual odors.
  • Acetone is the key ingredient in nail polish remover that helps to remove the stain. Ventilate the area well when using acetone as the fumes can be harmful.
good luck
rate if useful please !
  • Fathi Elmahdi
    Fathi Elmahdi Feb 22, 2010
    Hello :
    Try this solution :
    Things you need :
    • Small cloth
    • Baking soda
    • Warm water
    • Bowl
    • Sponge
    • Paper towel
    1. Make a thick mixture of baking soda and a little water in a
      bowl.
    2. Open the oven door.
    3. Using a small cloth, cover the entire inside of the oven
      window with the mixture.
    4. Let sit and dry.
    5. Using a sponge and warm water, clean off the window.
    6. Let air dry or wipe with a dry paper towel.
    I hope this will help
    rethink about rating please !
    $this.remove();
  • 416 Answers
The outer surface pops off of the door and the screws you need to remove will be visible. something like a bic pen cap is good to force in there to start the separation, then you can slowly and firmly run it down the edge to pop it out.
GOOD LUCK AND PLS RATE THIS POST!!!!!
  • 2 more comments
  • Remote Computer Rescue
    Yes...if you pull on it from the bottom you can see how they separate, and get something firm yet mailable between the surfaces.
    many times, there will be more than one component that snaps off.
    The manufacture doesn't want the general public to know how to disassemble certain safety features. Microwave radiation leaking into your home isn't exactly the healthiest choice to be made. Many time you can get into these doors if they are layered with panels. If they are welded tight, you will have to cut your way in, remove the glass completely, grind the edges down, replace the glass, and then use an fast setting epoxy (like quicksteel) to remold the edge, allow it time to dry (about 3-4 hrs) and sand it down to a finish. If you have the time and the patience, you could clean it well. Just remember to leave absolutely nothing in between the glass because it will cook in there.
    Those little dimples are robotic rivets. You can pry at the point of the dimple and it will pop off, just make sure you have something around you can seal it with when your done. Quicksteel is a great product and can withstand amazing temperature variations. Be carefull not to put to much strain on those glass plates, they aren't easy to break, but when they do, that's it.
    GOOD LUCK!!!!!
Fan blows when doors open
One of the three door switches has failed and will need to be replaced. You would need to access behind the control panel to check them and or replace it. Good luck
Feb 08, 2014 | GE Spacemaker JVM1740 Microwave Oven
There are stains in between the glass on the door. How can I remove and clean this?
Hello :
Disassembling the door yourself will void the warranty and may require a service technician to repair any damage or put the door back together. It is recommended that a service technician complete this for you. It is not recommended that you disassemble the door yourself.
Things You Will Need:
Glass cleaner
Soft cloths
Glass stovetop cleaner
Steps to Remove the Glass:
Make an appointment with a service technician to remove the glass from the door.
Use glass cleaner to remove as much of the debris as possible.
For tougher stains and food debris, use a glass stovetop cleaner to aid with removal.
Once the stains and debris are removed, allow the service technician to reassemble the door.
Cleaning Through the Door Vents:
When the glass cannot be removed or is no longer covered by the warranty, there are other, more creative, ways that can be used to clean it.
Long handled cleaner
Bottle brush
Yardstick/ruler wrapped in cloth
Bent hanger wrapped in cloth
Dryer vent brush
Glass cleaner
Soft cloths/towels/long socks
Duct tape (optional)
Steps to Clean Between the Glass:
Some Microwave ovens have small vents along the bottom or top of the door. These vents go in between the glass (and are likely part of the problem with other materials getting in there as well). By inserting a towel on a long-handled stick, you can gently clean between the glass without disassembling the door.First, find the vents on the door if you have them.
It may be easier to remove the door from the hinges and lay it flat on the floor. Many microwave oven doors simply lift right off of the hinges, others will require loosening a few screws first. Replacing the door should be easy to do at the end of the cleaning and will not void the warranty.
Start by choosing a long-handled cleaning tool. There are a variety of options available, so be creative.
Secure a towel or soft cloth (long socks work well) to the handle with duct tape or other strong tape. Make sure it’s well fastened so it doesn’t come off and become stuck in the door.
Moisten the towel or soft cloth with the window cleaner or other cleaning product.
Insert the cleaning tool through the vents.
Move the cloth back and forth to remove the debris from between the glass.
Remove the cloth.
Repeat with a clean cloth until all of the debris is gone.
Replace the door on the oven and enjoy the clear, clean view.
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Whirlpool MH7140XF Microwave Oven
All is black...fuses ok..door switches ok...
well there's not much to go on is there? but i bet its blown up on you,
black staining if from the capacitor, realy not worth fixing, and if you dont realy know what you are doing inside that microwave, il tell you!!!! you are dicing with death,, the capacitor will kill you if there is any charge left in it,, be warned,, bont die young,,, die old! go and buy a new one fast,,,
Oct 21, 2009 | Kenmore Microwave Ovens
Golstar MV-1501V Microwave
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Sep 25, 2008 | Goldstar MV-1526 Microwave Oven
I would like to know how to clean the inside of my microwave,the wrong cup was put in,and it caught on fire ,and I can't get smoke stain out. Thank you,Molly Dickerson
The smoke stain is almost impossible to remove as smoke tends to get in the pigment of the paint.
If there's a burn smell, you can try simmering a lemon juice and water mixture for several minutes in the microwave. You can also set a plate of charcoal briquettes inside and leave the door closed overnight (DON'T turn the microwave on - just let it sit). Keep the charcoal inside when not using the microwave and it will absorb a lot of the odor.
Jul 17, 2008 | GE Microwave Ovens
Popcorn stain in Microwave
Uhhhmmm, paint? Inside a microwave? YUCK.... that would make food taste like paint.
The yellow stain from microwave able popcorn is most likely a permanant issue. I have heard of the vinegar water, bleach etc working, but never had it work for me.
I don't recommend you painting the inside of a microwave. Some paint is flammable. Almost all paints are toxic.
May 14, 2008 | GE JVM1650 1000 Watts Microwave Oven
Kenmore Over the Range Microwave
If you think the window is stained, you ought to see the rest of the inside! Wife is probably right. (wink, wink, nod, nod)
Actually, you can take the cover off, remove the front panel without much effort and clean everything and get a lot more life out of it. Microwaves usually die because of heat related problems caused by buildup of yuck on the guts.
Hope Ya Make your Wife Happy!
Jan 24, 2008 | Microwave Ovens
Modelnn-h264/s254 1100 watts
This door screen as it's called protects the metal mesh screen from moisture and food debris. The door screen must be replaced or the mesh screen can arc and be damaged, which can lead to microwave leakage. You can order a new screen from Panasonic at: http://www.pasc.panasonic.com/Epartr/PartsListChoice.asp It may be this part: F31455H00AP DOOR SCREEN A 5.75 But it might be better to call Panasonic at 800-833-9626 and be sure this is the right part. Be sure to have your FULL model nuber (with suffix) when you call. Be sure to use a cleaner like acetone, etc. to remove all the old adhesive before applying the ne wone, or it will not stick. The door must be squeaky clean and dry.
Sep 21, 2007 | Panasonic NN-H264 Microwave Oven
Burnt stain on door
In most cases you must replace the glass in the door. Sorry i couldnt be of more assistance. Good Luck
Jul 03, 2006 | Roper MHE14XKB Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
113 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
