Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
I want to reset the entry combination - Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
  • 13 Answers
Try and use default code 159a then try and reset if not go to harborfreight.com put in safe it has instructions on how to change all these are the same even if name is different
Posted on Oct 04, 2009
How to reset the entry code to homcom 12"x14"x10"
Most of these Chinese safes have a reset button inside the safe. Open the safe, press reset and enter your new combination. Then check it before closing and locking the safe.
Jul 12, 2014 | Safe International Digital Electronic Safe...
Why Brinks dead bolt keyless entry stays locked
If the bolt moves freely it should work with the correct combination. Test with door open. Reset the combination to be sure you have it correct. If it still won't work with good batteries, then the lock must have failed. Check for loose connections or broken wires. Unless it's under warranty, you'll probably need to replace it.
Jun 20, 2014 | Locks & Locksmithing
I previously set my combination and it worked fine. Now my combination will not work on my cal pak lock luggage. how can I open now and reset combination?
Try rotating the numbers on the combination dial three times to clear any previous entry (stop on the zero's if this applies) and enter your combination one more time to see if this works and gets it open.
The default is 000; to set it, hold the lock open, move the dials to your numbers, and close/open three times. This will set the combination to your numbers.
Aug 27, 2011 | Locks & Locksmithing
Factory reset la gard 3715 electronic safe
Welcome to FixYa.
How to reset or change your lock combination:
  • 1. Enter "zero" six times.
  • 2. Enter your existing six (6) digit combination one time. (or 123456, factory default if you haven't changed the combination yet.
  • 3. Enter your NEW six (6) digit combination two times.
  • 4. If a mistake is made wait thirty (30) seconds and repeat steps 1 - 3.
  • 5. Test lock operation several times before closing the door.
CAUTION: When selecting a combination do not use birthday or other predictable data that could give correlation between the user and combination.
• Valid Combination Entry - Double signal after valid six (6) digit combination is entered.
• Invalid Combination Entry - Triple signal indicates the old combination is still valid.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 01, 2011 | Office Equipment & Supplies
I am the third owner of this car and I want to use the keyless entry combination that is located on drivers door but never knew the combination. How can I set it back to default so I can use my own...
I can send you one for a '96 which should work just fine. The info about the keyless entry is on page 128 and tells you exactly where the code is and how axcess it. email me at iambanshee74@yahoo.com
Nov 02, 2010 | 1994 Mercury Sable
Recently purchased a used Navigator and dont know the combination to the keyless entry. How do i reset it
look under your dash (driver side} ther will be a set of numbers on the computer that will be your lock code
Sep 19, 2010 | 1999 Lincoln Navigator
How can I reset the combination for the key entry?
you need to know the permanent code on the plastic card in the owner manual packet. I think the number is on the module as well. It is behind the center console. Enter permanent code, hit 1, enter new 5 digit code, hit 1 again. should be set.
go here for villager help
http://groups.yahoo.com/group/villagerquest/
Jun 26, 2009 | 1995 Mercury Villager
Forgot keypad combination
In order to change the keypad number code u have to have the original code Numbers, this is printed on a tag on the key-less entry module mounted under the rear glass package tray, on a shelf inside the trunk
Apr 08, 2009 | 1995 Ford Taurus
Keyless entry lock pad not working
Check with the dealer to see if the combination was reset when the battery was changed.
Feb 14, 2009 | 2003 Mitsubishi Outlander
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
782 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
