I need to know the orientation of the Gear Worm Wheel in a RDR-VX530. The illustration in...
(More)
I need to know the orientation of the Gear Worm Wheel in a RDR-VX530. The illustration in "Broken Cam Gear" posted Feb 06, 2009 is not clear enough to tell. The wheel spokes are offset from the center and since it has fallen apart and I did not take note, I am no longer sure of the orientation. I am going to Bondo this ****** back together!! Are the spokes closer to the sheet metal?
when I try to record, the vcr gives a message to use a tape without the tab removed. The tab is in...
(More)
when I try to record, the vcr gives a message to use a tape without the tab removed. The tab is in place. I've tried numerous different tapes. The vcr won't record because it thinks the tab is removed, Sony RDR-VX530
Sony RDR-VX530 - almost exclusively used for copying video VHS tapes to blank DVD -R Had this...
(More)
Sony RDR-VX530 - almost exclusively used for copying video VHS tapes to blank DVD -R Had this problem before - when changing brands of blank DVD discs the unit will record for limited time - sometimes just 20 minutes, others 35 minutes - last night I got an hour of a two hour VHS - rec mode is set correctly - just seems to reject record process somewhere along the way - last time I took it in and got charged $150 for a thorough cleaning
