Question about General Electric RCA-25424RE1 4-Line Corded Phone
When you are on the phone, you can hear the ring of a call on another incoming line in your ear
Check inside wiring connected to jack for this phone.It is possible old sub-standard category -3 cable was used which would cause inductive cross.If that is the case use cat-5 or even cat-6 cable.The difference is the twists on this cable are tighter ,therefore eliminating most inductive cross.
Posted on Jul 20, 2010
My iphone 3g does not ring, i can hear the ring if i have on ear phones or an ear piece. the signal seems to be okay. the settings seem to be correct.
Dear Dburnett412.
If you can't hear the ringer when there is an incoming call to your iPhone 3G, you may have overlooked whether or not the ring/silent switch is set to silence the ringer. The ring/silent switch is above the volume switch. If you can see orange on this switch, it's set to vibrate. Switch it to ring and you should be all good.
If this doesn't help, you may want to consider resetting the iPhone.
Jun 30, 2011 | Cell Phones
Bold 9000 only rings through the ear piece when it is connect. Does ring when disconnected to ear piece. When ear piece is not in my ear, I can not hear the phone ring.
Hi, what makes it when disconnected to ear piece. When ear piece is not in my ear, you can not hear the phone ring is because the ringer of the phone that makes you know when there is an incoming call on your cell phone or a message alert tone on your cell phone is damaged and does not work and makes sound to notify you .
The ringer is a tiny speaker inside the cell phone that allows you to hear incoming call from your cell phone You will need to replace the ringer inside the cell phone ....
When you replace with another ringer (speaker inside the cell phone),phone will be Ok again.
Would advice that you contact an expert in phone repairs for asistance,that will do you good to prevent more damaged on the phone...
Take care.....
Feb 09, 2011 | RIM BlackBerry Bold 9000 Smartphone
Dell 2135CN cuts-off incoming calls to my home phone number after 2 rings and the call goes to the printer. I hear the ringer inside printer, then hear fax tones, even though the call is not a fax. My...
Hi and welcome to FixYa!
Well if that's the case, the printer should be detached or powered of during call operations. The printer detects incoming calls that's why it triggers it to operate. Turning it off during operation will surely be the solution.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 05, 2011 | Computers & Internet
1 lines is ringing & another is not ringing
Somewhere you should have a programming and operating manual for your phone system. Typically in a Panasonic you turn on CALL WAITING for both Intercom and Outside lines via a code you dial at each phone on the intercom (7311# 7321# for a TA).
This is assuming that the lines are already programmed to ring at the phone.
Carl
Aug 21, 2009 | Panasonic KX-T7730 Corded Phone
No ringing sound for second incoming call
On the intercom, if it's a TA or similar phone system, dial 7311# for call waiting on outside lines and 7321# for call waiting on the intercom. (0 cancels).
Carl
May 21, 2009 | Panasonic KX-TS3282W Corded Phone
I would like Line 6 on Norstar System to Ring Different
Normal 0 To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
Jan 15, 2009 | NorStar M7310 Corded Phone
Cannot hear incoming calls unless on speakerphone
take the phone to a mobile service center and have them replaced the mobiles' ear piece.
Feb 21, 2008 | Motorola Mobility L6 Cellular Phone
General Electric RCA-25424RE1 4-Line Corded Phone Logo
126 people viewed this question
Top General Lands Phones Experts
Are you a General Lands Phone Expert? Answer questions, earn points and help others
