Question about Denon AVR-2802
My AVR2802 has no sound suddenly. All connections OK, tried radio and speaker level test but no sound? Digital is blinking (just started) but also no sound before this? Tx in advance for your help Gabe
    Problem Solver:
  • 6 Answers
Do you want to sell it? The best solution I can suggest is that you do like me. Try to find one that has a different problem than yours, and buy it from the owner. Swap internal parts relevant to your problem and say a brief prayer before turning it on.
myndseye@bellsouth.net
Posted on Dec 30, 2009
I started having the same problem with mine last week. Took it to a repair shop and was told it needs a new signal board which they don't make anymore. The repairman also said that he's seen a bunch of that model with the same problem.
My solution - went out and bought a Sony.
Mike
Posted on Oct 13, 2009
No sound from rear speakers Kia Sedona 2005 Front work fine with full sound but nothing from back speakers
Assuming the radio has an output for rear speakers and it is connected to them and you have selected the front/rear fader and attempted to adjust it to the rear, you can't do much more without removing the radio and checking the connections and the wiring to the rear speakers.
When I am faced with this problem I disconnect the speaker wiring from the radio and using a 9 volt battery and two lengths of wire I test the speakers and the wiring by connecting to each speaker in turn. A good speaker with good wiring will produce noise when the 9 volt battery is touched to the terminals. If there is no noise the speaker or the wiring is defective.
If all tests ok then the radio is probably faulty. This can further be tested by connecting temporarily to alternative speakers.
Jun 13, 2016 | 2005 Kia Sedona
I have a 2001 GMC Yukon XL and several months ago, I started having a problem with the OEM radio. The radio evolved to the point where it was in constant state of resetting itself on and off. The clock...
Initially, pls verify the splicing/wiring:
If verified and still no sound, either:
  • setting configuration (menu); or
  • internal fault of the Pioneer unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 26, 2008 | GMC Yukon XL Cars & Trucks
Low sound
seems like a component level problem, I would contact your dealer incase you have warranty to get it replaced.
Jun 08, 2008 | Sony HT-5100D System
I got a 91 chevy pick up with a cilfford, the radio works but hardly any sound comes out of speakers. I got a new radio and its the same. All speakers play buy sound is very low. I was told it was do to...
posted 6 times.
run new wires from new radio to speakers
or bench test your radio (easy) with your speakers.
if still low the speakers are bad or just dirt cheap , car speakers.
try new speakers, if weak now the wires are bad, try new wires
id still weak the radio is bad. (or just a cheap radio)
and define weak, to me most radios are way too load.
but to others, all are weak until 1000watt amp is added.
weak is a relative term. as is hardly any.
do not quote persons guessing, its just a wild guess. they can see car either, do the tests your self and find TRUTH.
to bench test, (modern way)
1: 12vdc 1amp power pack, or battery 12v. and ground.
2: connect up USB mem,. with some mp3s. on stick.
3: connect one good speaker (KNOWN GOOD)
to one of 4 speaker lines. (2 wires)
4: push play, does it sound good, yes, move to next speaker port.
ok , the radio is good. so
try it in the car, is it now low volumn
yes, then move that test speaker to the car speaker that is low.
still low, yes, then the wiring is bad.
easy huh?,,, takes only , a test speaker.
if no usb use, cassette, if no that , use CDDA disk( store bought real)
if none of that us the radio to test. connect a test antenna.
tune in Am or fm. bam.
May 06, 2014 | Cars & Trucks
Have a random popping sound coming from car speakers. Sometimes its just from the front right door speaker sometimes its from all the speakers, pops range in loudness levels, the loudest pop comes from the...
Is it after market radio? Check connections from radio to speakers and at the speaker(s) Door slamming knocks wiring loose. Also bad antenna lead can do it also since most radios get ground from antenna.
Feb 25, 2011 | 2001 Honda Accord
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
My suburban suddenly would not start - no lights -
check your battery voltage for +12volts off,then have the battery load tested and see if its above 10 volts under load test,if it shows ok,then you may have a high resistance ground in the system that needs to be traced probably at the e.c.m. power because of the clicking it sounds like its going thru the self-test before it starts
May 13, 2010 | 2000 Chevrolet Suburban
It started with the rear speakers on my 2001 Audi A6, all of a sudden, making a very loud distorted/cracking sound. Now, rear speakers do not work at all. Any clues as to what has happened and the what is...
try connecting them to a small radio or tape player to see if they still work ?? if they appear to work ok on a small set then i would be inclined to check the colours on the speaker wires then rmove the radio and try connecting another known to be good speaker to the output on the radio and if that works ok then renew the feed wires to rear speakers because thats where your fault would lie for whatever reason like a mouse got in or seat crushed the wires or whatever
Dec 01, 2009 | 2001 Audi A6
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
Sound Level Changes Constantly
Make sure digital sound control is not set to optimal
Make sure incredible surround is off
Press optimal sound mix until it says "OSM Off"
Double-check the speaker connections
May 07, 2007 | Philips FWC399 CD Shelf System
Denon AVR-2802 Logo
430 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
