Question about Standard Oregon Chainsaw Chain For Stihl Chainsaw 16" Bar Length 60 Drive Links 3/8 0.05 Gauge Chiesel Chain
Shihl 041 chainsaw what is the proper carburetor settings?
    Sergeant:
  • 302 Answers
Set both the H and the L jets at 1 1/2 turns out and then fine tune it from there . This is usually a final setting . hope this helps you
Posted on Oct 03, 2009
How do I reset carb. screws to factory settings
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws and other two-cycle engines. ... These saws have what is called a "fixed jet" which is set from the factory. ... (7) Go back to step (5) and reset the idle speed. ... NOTE: If you do not have a tachometer, set the RPM level so that the saw "four ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
Return a type A carburetor to its factory setting by turning the "H" screwcounterclockwise until it ... Where Do I Find the Carburetor on My Stihl 017 Chainsaw?
how to adjust carbs on 2 stroke weedeaters and chainsaws ...
Dec 25, 2015 | Garden
Could some help me with factory carb settings on this saw
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
Any complaints of saw catching fire?
Not really, but if you've had the issue, maybe the vent tube is allowing gas to be dripped into the carbuetor compartment behind the filter. Sometimes, when held horizontally, they will leak a bit out and older saws sometimes have the vent line to deteriorate from the alcohol in todays fuels causing a few drops of gas to escape. I've worn out two 041 Farm Boss saws and never a problem other than normal maintenance.
Mar 15, 2015 | Stihl 041 Av, Farm Boss Chainsaw Intake...
Chainsaw stalls and won't restart
make sure you have the right spark plug and gap is right on for that model.
Apr 13, 2014 | Craftsman Garden
No gas coming thru
Duane:
Take the saw and open the gas tank. There should be two lines going into the tank, one for the primer bulb and the other (with a line-end filter) feeds the engine while running. Make sure that the line-end filter is submerged in the gas in the tank. If the saw still won't start or run, you probably have a diaphragm in the carburetor that is torn (from letting the saw sit for a long period of time). You may need to rebuild the carburetor. A carburetor rebuild kit can be bought for very little $$ at a lawnmower repair shop.
Oct 21, 2012 | Stihl 040 041 Farmboss Starter Cover
How do I find Stihl 041 s/n with silver sticker gone?
you cant. that is the only serial number on the machine
Apr 16, 2010 | Garden
Standard Oregon Chainsaw Chain For Stihl Chainsaw 16" Bar Length 60 Drive Links 3/8  0.05 Gauge Chiesel Chain Logo
149 people viewed this question
Top Standard Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Standard Measuring Tool and Sensor Expert? Answer questions, earn points and help others
