Question about Kenmore HE2 Plus Front Load Washer
I have a F-21 error. Manual says it is drain
I have a F-21 error. Manual says it is drain problem, but have not found a problem.
    Top Expert:
  • Kenmore Master
  • 76,164 Answers
Does the drain have a filter? many new ones do.
Posted on Oct 02, 2009
I have a F21 Error on my HE 2 Plus have neverr seen this error before? Any Ideas
Posted on Oct 03, 2009
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
Error code f 21 how do I fix the problem
this is the code for a drain problem. most front loaders have a clean out just before the pump. mine has a round door that you unscrew to clean out. I just did mine a few nights ago and found if full of coins that was slowing the drain.
Jun 06, 2014 | Washing Machines
Need manual for whirlpool front load sport duet model wfw8600sr00
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged / kinked
Unplug washer/disconnect power
Check electrical connections to pump and make sure pump runs, check drain pump filter for strings,sand etc., plug in washer. If this don't work dismantle pump carefully to check if anything is clogging it. If the electrical side of pump is faulty this can easily be replaced, it is normally not repaired.
Washer parts can be found on this site.
www.youtube.com/watch?v=2abTptUYXH8
Mar 04, 2013 | Washing Machines
Kenmore he2plus what's troublecode f-21
F21 on the tech sheet says Long Drain If the drain time exceeds 8 minutes the water valve turns off.
NOTE: After 4 mins the "Sd" error will be displayed then 4 mins later the f/21 error code will be displayed.
Press Stop two times to clear the display.
(Solutions:) Check drain hose
unplug washer and check electrical connections at pump
Check filter for foreign objects
If these fail it says to replace pump.
Dec 11, 2011 | Kenmore Washing Machines
F-21 comes up on screen
F21 is an error when the machine takes too long to drain. Usually caused by a blocked empty pump filter. A full set of error codes and troubleshooting actions can be found at:
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
This will give you more information
Jun 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool frt loading washer is flashing a F 21 code and will not run. Can you help?
This problem is a good illustration of how there's just no substitute for actual hand-to-hand combat with broken appliances. Here's an excerpt from the service manual on this fault code: EXPLANATION AND RECOMMENDED PROCEDURE F21 LONG DRAIN
If the drain time exceeds eight minutes the water valves turn off.
NOTES: After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
I've worked on dozens of these washers and have only found the above service manual solution to apply once or twice. The vast majority of the time, I'd arrive and all the washer would do is drain and flash F-21 in the display. I couldn't even get the control board to go into diagnostic mode.
Using my keen Samurai Insight®, I unplugged the washer and removed the molex connector from the water level switch (also called a pressure switch). To get to it, remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right there on top, as seen in the picture below:
Anyway, I plugged the washer back in and, lo!, the washer did enter diagnostic mode and the people did sing and the Lord did grin. And there was much rejoicing. Especially after I replaced the water level switch where up on applian to logical harmony was restored.
Hope this helps (remember to rate and comment this answer)..
Apr 28, 2011 | Whirlpool Washing Machines
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
LONG DRAIN
NOTES:
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
F-21 error means What?
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
plug in washer If this dont work
replace pump.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
I am getting a LE code repeatedly. I have unplugged it, cleaneaned out all lint filter things and call the 800#. They told me to drain the water out by picking the normal wash cycle/no spin. Still get the...
I found the service manual online and follwed the directions to drain the tub. Still getting the error code, thinkin' it's the hall sensor. A part that is under warranty still, that's good, service call, not...So for a $21-22 part, it costs 150 for the call....Something wrong w/ that.....Since I can replace it myself....sigh..........
Jun 16, 2009 | LG Washing Machines
Whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Mar 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Kenmore HE2 Plus Front Load Washer Logo
307 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
