Question about Karcher Garden
2 wires from the plug wire to the on/off switch have come off. there are 4 connectors on the switch no1 has come off no2 has a black wire on no3 has come off no4 has a blue wire still on .so do i put the blue or the brown wire on no1 connector
smartr10U
  • 1305 Answers
SOURCE: need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
Posted on May 31, 2009
  • 228 Answers
SOURCE: Neff oven internal wiring colours
red is positive and black is neutral normally on these ovens, dont recall seeing blue and lilac.
Posted on Jul 20, 2009
  • 115 Answers
SOURCE: HONDA power washer ON-OFF switch
more than likely the switch complete the circuit and allows the engine to run you canjumper the switch and see if it runs, if so, you can buy a switch from auto parts store and mount it
Posted on Aug 19, 2009
SOURCE: Need wiring diagram for Sony XM-E70 Equalizer/Amp
RCA JACKS ARE THE INPUTS
RED IS HOT
BLACK IS GND
YELLOW IS CONSTANT POWER
BLUE IS REMOTE/ANTENNA
9PIN IS SPEAKER OUTPUTS
Posted on Sep 03, 2009
SOURCE: I need to replace the 15 connector, but I only have 6 colored wires, pink, blue, purple, black, brown and white. Then there is a transparent wire and the ground. How do I wire it?
ineed to replace the 15connector
Posted on Feb 01, 2010
My 1991 FZR600 is only firing on cylinders 1 and 2
Hi, Steve_laught and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
fzr firing issue The FZR Forum
FZR 600 cylinder 4 not firing Problem solved
https://www.tradebit.com/filedetail.php/269137237-yamaha-fzr600-1989-1999-factory-service-repair-manual
OEM parts for Yamaha
http://www.fzrarchives.com/fzr600/600_manual/1999fzr600r.pdf
Aug 31, 2012 | 1991 Yamaha FZR 600
I have a cell phone nokia 2630 when i open the web and search the facebook always say's that subscribe packet data first
first you activate your subscribe packet data step no1:go to your mobile main menu press it.step no2:you saw a tools icon in your menu press it.step no3:you saw a sim icon or carrier icon press it . step no3: you saw a list of multimedia messaging or internet messaging press it.step no4:then you saw a wap gprs and mms option click the wap or gprs option and your packet data is activated if problem is not solved go to your carrier service center or call service help line thanks
Jun 30, 2011 | Nokia 6300 Cellular Phone
My nissan hardbody 2004 model overheated please tell me what is the problem
hello this could be a number of things
No1 Thermostat faulty No2 water pump not functioning No3 cooling fan not working your thermostat could be malfunctioning and sticking it would be wise to get it checked by a mechanic as prolonged use will damage your head gasket if its not damaged already
cheers goodluck
Mar 29, 2011 | Metra 99 7477 Nissan HardbodyPathfinder...
My problem is that when am formating my mobile.password 12345 is not taking showing wrong
try 00000 mate it will work.
if above code is not working then provide us your imei no we will send you master code for your mobile.
there is one alternate method method which dose'nt requires any password. just follow the step below.
step 1. switch off your phone.
step 2. now press these three button at the same time.
(no1.*key
no2. green dialing key
no3. 3number key)
step3. switch on your phone while pressing these keys.
a message like formatting will appear on screen(in some mobile the message not come up but do'nt warry keep pressing.
now you are done.
Feb 10, 2011 | Nokia 6600
How do i identify 1-6 cylinders on a1988 nissan terrano v6 engine and the firing order.engine is a vg30i
sorry but my alldata book doesnt show this model ,come to think of it never seen a petrol version here ,only diesel but i have found two firing order layouts and thats with engine infront of you no 1 back left and another one with no1 front right ,so its no1 say front right side then no2 at the back behind it no3 at front in middle and no4 behind it then no5 left front with no6 behind it and firing order 123456 then reverse that layout if it doesnt work
Oct 04, 2010 | Nissan Hardbody Cars & Trucks
Wirring set up for spark plug wires for a 1997 ford probe
2.0 firing order - 1-3-4-2
V6 firing order 1-2-3-4-5-6 - pic of engine and cylinder numbers. http://www.aa1car.com/library/ford_firing_orders.htm
Where to put the leads on the distributor
from standing at the front of the car looking down onto the disributor cap the connector closest to you on the top is no4,the one in the middle is no5. and the one at the back is no3
The connector closest to you on the bottom of the distributor cap is no2, in the middle no1, at the back furthest from you and separated from the other two a little further back is number 6.
------------------- 2.0 probe I have no pic of the engine myself but I found this for the 2.0 4cyl http://www.btinternet.com/~madmole/images/Idle.h10.jpg you can see the wires and where they go (zoom the image by pressing CTRL and PLUS keys together in your browser)
Jan 24, 2010 | 1997 Ford Probe
Show diagram of where spark plug wires go on distributor cap and spark plugs on engine.
firing order 153624 front left is one right no1 is 2 left no2 is 3 and so on
Dec 24, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Trying to install a ge digital time switch. all i have is a white black and ground wire. the diagram on instructions would be more helpful if it said ground, white, and black instead of to power supply and...
I just installed this thing yesterday and it was a PITA. ecupirate988's post was useful but I needed more.
NO is "Normally Open", meaning that whatever is plugged into COM (not necessarily what's plugged into TIMER, but could be) will get power. NC is "Normally Closed", meaning that when the switch is off, this will get power. The NO2, NC2 and COM2 lets you have 2 different voltages going through the same switch.
To wire this thing like simple wall switch, put the incoming hot (black) into the left side of "TIMER" and put the neutral (white) into the right side of "TIMER". Then with a second 6-8" wire, take of the sheathing so you have an 8" black, white and bare/green wire. Throw away the bare/green wire & the sheathing. Plug the black into the other side of the screw your first black went into (TIMER [LEFT]) and the other side into COM. Then plug the white into the other side of the screw your first wire went into and use a nut to connect it to the white (neutral) of your light. Connect the black of your light into NO1 and.
That worked great for me. Took a lot of work with a voltmeter & some learning on Wikipedia to figure out exactly what I was doing. It's a nice switch once you get it wired.
Ryan
Nov 17, 2009 | Intermatic Inc. EJ500C Digital Wall Switch...
How do i arrange spark plug wires on my hyundai accent? I need a diagram pls
hifrom the uk if you look at coils on rear of engine they are set in more or less a square arrangment ? now the No 1 IS REAR LEFT /No 4 REAR RIGHT No3 IS FRONT LEFT / No2 IS FRONT RIGHT then arrange the plug leads by length of each to fit to each plug fire order is 1/3/4/2 anticlockwise rotate if you understand ? why not number the coil to leads correspond using dymo tape to coils? for any future reference hope this helps
Nov 17, 2009 | Hyundai Motor 1995 Accent
Wires
Set your engine to TDC. Now your rotor arm should be pointing to the No1 cylinder. Your firing order should be 1-3-4-2. Get someone to spin the engine for you so you can see which way the rotor arm moves and put the leads on in the order of rotation. Starting at the rotor set at TDC, put that lead on the plug in No1 cylinder. The next one should go on No3 plug then 4 then 2.
Nov 20, 2008 | 1990 Volkswagen Jetta
Garden Logo
76 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
