Question about Microsoft Windows XP Professional for PC
Windows cannot find scvhost.exe
Sir in office system i face this problem "Windows cannot find SCVHOST.EXE" when ever i reboot or logoff the system the popup shows this error
plz help me wat i will do to solve this problem
    Problem Solver:
  • 6 Answers
This is the Internet Virus , to overcome this , you may kindly be taken following steps .
Step 1: Write click on the start button task bar .
Step 2: Select Task manager by left click of you mouse.
Step 3. Under the process option , select line
svchost.exe system Administrator
Step 4. Select End process .
Step 5. Repeat Step 3 & 4 until the end of the bellow message.
svchost.exe System Administrator
Step 6. Close the Windows Task Manager by click X button .
or
Run the Original Quick Heal / AVG antivirus software in your system .
The steps are the solution for your problem.
OK
nilamani
nkjbbsr@yahoo.co.in , nkjbbsr@rediffmail.com
Posted on Dec 21, 2007
Svchost exe error
upgrade to a newer OS helps alot
Jul 18, 2014 | Toshiba Satellite Computers & Internet
Tip
How to remove the scvhost.exe Virus.
Svchost.exe is the name of a generic host process for services that run from dynamic link libraries (DLLs). A variety of worm malware programs spread a similarly named file <b>Scvhost.exe </b>via Yahoo! Messenger that blocks the Task Manager and Registry Editor, as well as use of the command prompt.<br /> <br /> <b><u>Warning</u></b><br /> Manual removal of Scvhost.exe may be very difficult as the removal process requires knowledge of the Operating System's command prompt and Registry Editor. If not performed properly, your computer system might experience permanent damage. Consequently, manual removal might be best for experienced users. Less experienced users might want to consider using an automatic spyware removal application, such as that offered by Trend Micro. This worm duplicates itself to different locations of shared folders. The duplicated program uses a folder icon that has an .exe file extension. DO NOT double click on any of these folders.<br /> <br /> <b><u>Follow these step by step instructions to remove the scvhost.exe virus.</u></b><br /> <b></b> <br /> <b><u>Step 1 (Turning off System Restore)</u></b><br /> This is so that if you ever need to use System Restore after you have removed the virus, it doesn't restore the virus aswell.<br /> <br /> If the operating system of the infected computer is either Windows Me or Windows XP, turn off System Restore while this fix is being implemented. To turn off System Restore within Windows Me, click <b>Start &gt; Settings &gt; Control Panel</b>. Double-click <b>System</b>. Select F<b>ile System</b> from the Performance tab. Left click the <b>Troubleshooting</b> tab and check the <b>Disable System Restore</b> box. Click <b>OK</b>. <br />To turn off System Restore within Windows XP, log in as Administrator and click <b>Start</b>. Right click <b>My Computer</b>" and select <b>Properties</b> from the shortcut menu. Check the <b>Turn off System Restore</b> option for each drive on the System Restore tab. Left click <b>Apply</b> and <b>Yes</b> to confirm when prompted. Click <b>OK</b>.<br /> <b></b> <br /> <b><u>Step 2 (Run in safe mode)</u></b><br /> Restart your computer in Safe Mode and log in as Administrator. Press <b>F8</b> after the first beep occurs during start up, before the display of the Microsoft Windows logo. Select the first option, to run Windows in Safe Mode from the selection menu.<br /> <b></b> <br /> <b><u>Step 3 (Accessing Command prompt)</u></b><br /> Access the command prompt. Click <b>Start &gt; Run</b>. Type <b>cmd</b>. Click <b>OK</b>. Then in the command prompt type <b>cd </b>to<b> </b>change directory then press the space bar. <br />Type the name of the full directory path of the folder containing your Windows system files. It will be either <b>C:\Windows\System </b>or<b> C:\Windows\System 32</b><br /> <b></b> <br /> <b><u>Step 4</u></b><br /> From the command prompt, type the following to unprotect the files for removal:<br /><b>attrib -h -r -s scvhost.exe</b> and press <b>Enter</b>;<br /><b>attrib -h -r -s blastclnnn.exe </b>and press<b> "Enter</b>;<br /><b>attrib -h -r -s autorun.inf</b> and press <b>Enter</b>.<br /> <br /> <b><u>Step 5</u></b><br /> Delete the files by typing the following from the command prompt:<br /><b>del scvhost.exe</b> and press <b>Enter</b>;<br /><b>del blastclnnn.exe</b> and press <b>Enter</b>;<br /><b>del autorun.ini</b> and press <b>Enter</b>.<br /> <b></b> <br /> <b><u>Step 6</u></b><br /> Type "<b>cd\</b>" to return to the main Windows directory.<br />Unprotect and delete the Autorun.inf file by typing the following from the Windows directory command prompt:<br /><b>attrib -h -r -s autorun.inf</b> and press <b>Enter</b>;<br /><b>del</b> <b>autorun.inf</b> and press <b>Enter</b>;<br />Type <b>regedit</b> and press <b>Enter</b> to open the Registry Editor.<br /> <b></b> <br /> <b><u>Step 7</u></b><br /> Locate the following entry:<br /><b>HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run</b>.<br />Delete the incorrectly spelled Yahoo! Messenger entry with the value<br /><b>c:\windows\system32\scvhost.exe.</b><br /> <b></b> <br /> <b><u>Step 8</u></b><br /> Locate the following key:<br /><b>HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon</b>.<br />Within the key, there is a <b>shell</b> entry with the value of <b>explorer.exe, scvhost.exe</b>. Edit the entry to remove the reference to Scvhost.exe, leaving Explorer.exe as the remaining value in the registry entry.<br /> <br /> <b><u>Step 9</u></b><br /> Locate the following key:<br /><b>HKEY_LOCAL_MACHINE&gt;SYSTEM&gt;CurrentControlSet&gt;Services&gt;<br /></b>Delete the following subkeys from the left panel:<br /><b>RpcPatch</b><br /><b>RpcTftpd <br /></b>Exit the command prompt and return to the operating system. Type <b>Exit</b>, and press <b>Enter</b>.<br /> <br /> <b><u>Step 10</u></b><br /> Reboot the PC.<br />If Scvhost.exe still resides on the computer, repeat these steps or try using an automatic removal program from McAfee or Symantec.<br /> <br /> <br /> <br />
on Feb 25, 2011 | Computers & Internet
Scvhost.exe driver not redy..please solution
Glad to help YOU!
The svchost.exe file is located in the folder C:\Windows\System32.
On STARTUP Svchost.exe checks the services portion of the registry and constructs a list of services that it needs to load. Usually multiple instances of Svchost.exe will be running simultaneously. If the process svchost.exe uses high CPU resources it is mostly due because Windows Operating System is downloading some updates.
WARNING: A 100% CPU usage could lead to the presumption of a hidden malware on your computer!!! Same for the message that you got: "scvhost.exe driver not ready"...
I'd suggest you to do a SPYWARE/MALWARE scan AS SOON AS POSSIBLE and AS DEEP AS POSSIBLE!!!
GOOD LUCK!
Mar 14, 2011 | Computers & Internet
Undetected scvhost.exe
svchost is part of the os, not the motherboard
Oct 24, 2010 | Computers & Internet
After shutting down svchost.exe appeared.and hang itself.
If its not doing this all the time, and the laptop is just stuck on, press and hold the power button down until the laptop turns off.
If its a reoccurring problem, run a check disk.
if it still does it, disconnect one piece of external hardware one at a time until the scvhost.exe doesn't hang on shutdown, and you have found the culprit.
Jan 21, 2010 | HP 510 Notebook
Loadig script C WINDOWS System32 scvhost vbs
your svchost file is been couruted or damaged, get ur system formated by well qualified engineer and first antivirus installed.
Jun 20, 2009 | Computers & Internet
Lost My Clipbook cant turn it on, cant restore CA called scvhost.exe a virus so deleted it
remove the virus with anti virus software, then go to start>programmes>accesories>system tools>system restore and choose a date before this happened, when it is restored, turn off system restore as you would have reinstalled the virus, re run the anti virus then turn system restore back on.
Sep 03, 2008 | Computers & Internet
Windows cannot Find SCVHOST.exe.
Boot from your Windows XP disk and use recovery console, follow the onscreen stuff and put the admin password in that you setup when you installed windows, you should now be at a prompt EXAMPLE: C:\WINDOWS>
At the end of the prompt type: cd F:\I386
F is the letter of the drive where your XP disk is so you will need to change it to your drive letter. The prompt should now be F:\I386>
After the prompt type: Expand svchost.ex_ C:\windows\system32
C is the letter of you HD were windows XP is installed, needs to be changed accordingly. At the prompt type: exit
Your sytem will re-boot and you will now have a copy of svchost.exe in your system32 folder again.
If you have found this solution helpful please rate it as Solved, otherwise please ask again.
Thank you
Nov 01, 2007 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional for PC Logo
120 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
