Question about Bose QuietComfort 2 Consumer Headphones
I have a break in the cord, what is the part number, price and where can I order a new cord?
    Scholar:
  • 92 Answers
Go to the Bose Web Site.
>customer service/support.
give them any and all information on the headphones.
Alternatively, find a Bose dealer close to you.
same thing, or take the head phones with you when you go.
Good luck.
Posted on Oct 02, 2009
Makita drill corded model 6404 3/8"
You can order a new cord.Go to e replacement parts and put your model number in and this will get you a parts break down
Jun 07, 2013 | Drills
Tip
Troubleshooting Laptop Power Failures - The AC Adapter
Symptom:
Wiggling the AC adapter cord causes the power status LED on the laptop to blink.
Diagnosis & Solution:
The problem could be that the copper wires inside the AC adapter cord became frayed or broken right where they enter the connector on the end of the AC adapter cord. The wires (a number of very thin conductors twisted into a heavier cable) are sized for the amount of power the laptop requires. As thin wires break and lose contact, all of the power must flow through the remaining conductors, leading to overheating, which can cause damage or be a safety hazard.
To make sure that this is the case, first test the output voltage from the connector on the end of the AC adapter cord using a digital multimeter set to measure DC voltage. While measuring, bend the AC adapter cord in various directions. If this causes the reading to jump betwwen zero & the nominal output voltage (written on the label on the AC adapter), then you know that you will need to replace the connector.
In order to get this fixed, you will need a new connector and basic soldering skills, or you can take it to an electronics shop for a cheap repair but get the price before agreeing. If you decide to repair it yourself, then you will have to find a replacement connector. Most of these connectors are easy to find and your local Radio Shack often has them in stock. Just bring your laptop along to make sure you get the right size. However, some laptops use a highly proprietary connector for which you can't easily find a replacement, in which case your best option is to find a failed AC adapter for your laptop model, cut the end off (with plenty of slack) and splice it onto your AC adapter's cable.
If you work on irregular surfaces (like a lap) and allow the cord to dangle, the wires may break just inside the connector due to pulling, despite the fact that the factory connector is encapsulated in molded plastic. You can carefully take apart the molded plastic with a razor knife to temporarily fix a connection, but it's smarter to replace the connector end as soon as you determine it is causing intermittent power failures.
Another possibility might be that the power receptacle in the laptop (where you plug the AC adapter cord) has failed. Sometimes the center pin of the connector breaks off, sometimes the solder joints on the main board fail, sometimes there's a break between the connector contacts and the motherboard contacts. In all these instances, you or the technician has to gain clear access to the laptop's motherboard to make the repair. In order to get this done, you might need clear disassembly instructions, as well as decent soldering skills. You could get a replacement connector usually for less than $10, but the repair charge can be several hundred dollars for some models if you take it to a local shop.
Please Vote for this Tip if you found it helpful.
M. Omran
on Oct 13, 2010 | Computers & Internet
Where can i buy an electrical cord and the medal cord for my brother cs 6000 sewing machine
Call Brother at 1-877-276-8437 and order it direct from them, or go www.sewingpartsonline.com and buy from them, the foot control costs $29.99 and the power cord costs, $13.99 from Sewing Parts, I don't know what Brother's price is, but you can compare. Happy New Year
Jan 03, 2011 | Brother CS-6000
THE PLUG BROKE
Go to your local hardware or big box store and buy a heavy duty replacement plug. Cut the old one off of the cord and install the new one...
heatman101
Aug 29, 2010 | Sharp AF-S120FX Air Conditioner
I have an old corded 3/8" corded Craftsman reversible variable speed electric drill (1051). It squeals when I use it. Wondering if it needs to be oiled.
Yes, the bushings are dry, and it is screaming for oil. But, it doesn't like oil, it likes grease better, but it is hard to get in there to grease it. (sometimes), you might get it apart and both ends exposed. Then get the bushing off the end, you won't be able to get it off the front, either squish some grease in there or get the oil can out and try it. Good luck.
Apr 25, 2010 | Craftsman 3/8" Corded Drill
The switch face panel on my Maytag gc2225geks has started to break up infront of the switches due to ware an d tare can you get new switch panel covers.
most of the time u can call maytag or go online to maytags website and find a number to call to get the part u need and u r going to have to order it but the price may be ridiculious
Mar 01, 2010 | Refrigerators
Need to order a new car cord that goes with the
hi,we can provide you portable dvd player,they are good quality and price,please contact me:MSN:szkingpeng02@hotmail.com
Good day !!!!
Jorsph
Jul 09, 2009 | TruTech LMD-5702RT Portable DVD Player
Open power cord housing on kenmore 116 vac
You can go to the Sears Parts Direct website and type in your Model number. It will return both an exploded view and parts list, with pricing for replacement parts. You can also order from them, and they can tell you stock status as well.
Jan 15, 2009 | Kenmore 25512/ 25513 Progressive Canister...
LOST POWER CORD
I need a new ac adapter and I sent an email to evergo@att.net which is the customer service for the company that makes the PDV-709 dvd player. They responded within 1 day and gave me the instructions as to how to order one from them and the price ($20) etc. They require a money order sent to the address below.
Lenoxx Customer Service
Lenoxx Electronics
35 Brunswick Ave
Edison, NJ 08817
Oct 11, 2007 | Durabrand PDV-709
Bose QuietComfort 2 Consumer Headphones Logo
108 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
