Question about AandD Health & Beauty
Inflation rubber ball disintegrating - AandD Health & Beauty
Solved problem with disintegrating pressure bulb on blood pressure machine. found your HELPING website unhelpful so bought a different machine which does not use rubber pressure bulb. your product is very harmful to the environment since the whole unit now has to go to garbage.
there should have been a replacement rubber bulb.
Posted on Oct 03, 2009
Black tar balls in Kenmore model #665.13722K600
No, don't run Coca-Cola in it! I would call a repairman immediately - you may have a rubber hose that is disintegrating, and you dishwasher could start leaking seriously!
Sep 05, 2012 | Kenmore Dishwashers
How do I know how much air to put in my exercise ball when I fill it?
The most precise way to know that you have enough air in your exercise ball is to measure the height of the ball once it has been inflated. The easiest way to accomplish this is to make a very small pencil mark on the wall (equivalent to that of the proper size of your ball), then inflate your ball with the pump provided until the top of the ball matches the mark on the wall.
Aug 06, 2012 | Exercise & Fitness
Can I inflate/deflate an exercise ball?
Ofcourse youcan! Check out these two informative websites to learn how to inflate/deflatean exercise ball: www.livestrong.com/article/22214-inflate-exercise-balls/and http://www.livestrong.com/article/73718-deflate-exercise-ball/
How To Pump Up A Soccer Ball?
To watch an instructional video on how to pump up a soccer ball follow this linkhttp://youtu.be/SK1PohTCJj8
According to FIFA the pressure inside a soccer ball must be of a pressure equal to 0.6 -- 1.1 atmosphere (600 -- 1,100 g/cm2) at sea
level (8.5 lbs/sq in -- 15.6 lbs/sq in)
When inflating the ball, use a small pump and pressure gauge. Avoid using high pressure pumps made for cars and motorcycle tires, which can easily over-inflate and damage your ball.
Jul 18, 2012 | Sport & Outdoor - Others
When I'm pumping it up the ball sticks and will not inflate. I hear air coming out from the ball you squeeze.
If this is happening when the finger valve is closed, there is a leak either in the rubber tubing or the inflation bulb. Try putting soapy water on the tubing and then on the bulb. Squeeze the bulb with just your thumb and forefinger, so that you can see any air bubbles. If the leak is in the rubber tubing, you may be able to repair it with a couple of laps of vinyl tape. If the bulb is leaking, that will have to be replaced.
Hope this helps you solve the problem.
Mar 18, 2011 | Health & Beauty
How to inflate the shake & monkey rattle ball?
Look for a plug on the plastic ball, it may be under the monkey fabric cover. Pull plug and blow air in just like inflating a small beach ball. Re-insert plug to seal.
Nov 06, 2010 | Toys
Nois in the suspention
Look at the anti-roll bar bushings and end connect points--they are all rubber pieces and prone to wear and disintegration. Push down repeatedly on the corner that the noise comes from while someone is looking and listening for the source. Make sure that the struts aren't making the noise. Turn the wheels to the right for a better look. Leave the wheel on so that the suspension will move.
Aug 19, 2009 | 1994 Toyota Tercel
When using an air pump to inflate a ball, where should you put the ''pin''--should you make a hole in the ball (where the plug is?) or should you just stick the pump into the plug?
wet the pin lightly with spit and insert pin into the small hole in the plug and inflate
when desired firmness achieved pull pin out
the ball will seal it self
Jun 25, 2009 | Toys
Drum will not drain
There is a rubber boot from the wash tub to the pump. At the tub end of the rubber boot is a plastic ball slightly larger then a ping pong ball. The space around the ball was plugged with paper towel. The paper towel pieces were removed and the unit reassembled. Access to the rubber boot required removing both the front and back panels.
Apr 28, 2009 | Bosch WFMC2100UC Nexxt Essence Washer
Bought a newwprosport fitness ball from Target. no instructions
You just use a pump with a pointy nozzle, even an air compressor with the tip for inflating rafts and inflatables. You should fill it with enough air so that it is firm when you sit on it, but it should still have about 2" of give. (knee's @ a 90 degree angle when sitting on the ball). Hope this helps!
Nov 15, 2008 | Bally Total Fitness Exercise Ball
Health & Beauty Logo
178 people viewed this question
Top AandD Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an AandD Health and Beauty Expert? Answer questions, earn points and help others
