Question about LG Dryers
How to change vent location in LG DLEX7177WM - LG Dryers
  • 304 Answers
See the procedure listed in this manual on page 34. The model is not the same but most LG dryers are similar in construction. Good Luck.
LG Dryer Service Manual
Posted on Oct 02, 2009
Water is running out of the vent hose in back of the unit.
If I have to guess it may have been some time since this unit has been serviced and cleaned out. I have a feaing there is lent stuck in the vent which is getting wet from the exchust, then draining.
Dec 03, 2015 | LG DLEX7177WM SteamDryer Front Load...
How do you change the thermostat
https://www.youtube.com/watch?v=nYua4dRsdeI
Jul 30, 2014 | LG DLEX7177WM SteamDryer Front Load...
Lg dlex7177wm heating element
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
This is a specialised job and should only be attempted by technically competent persons.
Mar 13, 2014 | LG DLEX7177 Dryer
Drum doesn spin
If this product is new, you will need to take out the carriage bolts located in the back of the machine.
Carriage bolts are meant for the shipping process to prevent the drum from moving while in transit. Most manufacturers use between 2-4.
Check your product manual for details on the removal of the carriage bolts
Jan 23, 2014 | LG DLEX7177WM SteamDryer Front Load...
My DLEX7177WM dryer has no power no lights nothing
I have two questions but no answers. Did the cycle of drying the shoes end normally. Did he take the shoe strings out of the shoes before drying them. I'm wondering if the shoestrings may have gotten entangled.
Feb 17, 2013 | LG DLEX7177 Dryer
My LG front loading dryer doesn't dry well
Check the exhaust vent when running and be sure there is a good flow of air. You may have to clean the exhaust pipes all the way through. Dryers require a good flow of air for proper operation.
Jan 10, 2012 | LG Dryers
I need to change vent location from rear to side. Should I remove the back of dryer for access? If not how best do I change the vent location? I have purchased 4'' duct pipe + elbow from hardware store.
Turn off the power. You will have to remove the top panel. Remove the front panel. Remove the belt. Remove the drum. This will give you access to the location for side venting.
Oct 02, 2009 | LG Dryers
Heavier clothes coming out damp
First, make sure your vent to the outside is clean. Second, on auto cycles, clothes should be consistant. If a smaller item keeps hitting the sensor, it will think the whole load is dry. For mixed loads, used timed dry.
May 02, 2009 | Dryers
Dryers Logo
245 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
