Question about MSI K8N Neo-FSR Motherboard
My fan socket broke... can i order such a piece?
  • 557 Answers
Go to a computer repair shop and offer them a few bucks for a scrap board. They"ll probably give you as many as you want since they are only going to scrap them.
Posted on Oct 03, 2009
The little black piece that is on the connector that the keyboard ribbon connects to broke off. Can it be replaced? do you have the part?
You would have to replace the whole socket. If you are good at micro miniature soldering of multi-layer boards, you can attempt it. You may be able to buy a new socket and transfer the piece from the new socket to the old socket. As for parts, try your electronics supply house or, maybe ifixit.com.
Mar 09, 2015 | HP Pavilion Sleekbook 15-b142dx 15.6...
How to replace the ring spring to hold the socket on a black & Decker Bulldawg impact wrench
Lay a socket on a table or bench.Lay the spring on the socket. Push the square nose piece thru the spring and into the socket forcing the spring open enough to push it into the groove.
Jun 21, 2014 | Tools & Hardware - Others
The piece thaat makes my vitamix turn fell off
Sounds like your drive socket broke. Use a small allen wrench to loosen set screw under arrow on drive socket. You will have to order a new socket from Vitamix. Hope this helps.
Apr 29, 2012 | Vitamix 5000 Work Top Blender
Light bulb broke off in fan light how do I remove?
If the glass is broken and there are sharp pieces sticking out you can use the potato trick. Cut a small potato so you have a flat end, make sure the power to the fan light is turned off, and push the potato onto the broken remains. Then you can turn the potato to unscrew the base and just toss the whole thing in the trash. Wipe off the socket and you're set for a new bulb.
If the old bulb broke off clean so that only the base is left in the socket, you'll need to bend the edge of the base inward a little with a small screwdriver. Then grab the base with needle-nose pliers and unscrew it from the socket. Again be sure the power is off before working on the light.
Mar 15, 2010 | Hampton Bay 48670 Flemish Pewter Finish...
Broke the flimsy support plastic ring - Need to order new one
i would do a tack together job on it,,
get some thick fuse wire and tiy it round inside the grill holes on the out side edge tiy each one together at about every inch apart around the grill that will hold the two grill's tight, then if you still have the broken plastic bits glue them back on using supper glue its cheeper that trying to get part that you may never find?
Oct 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
Fan & shrould Broke off the water pump
I believe that the part your'e talking about is the clutch for the fan. It is a two piece unit, factory assembled. likely the bearing inside failed and caused this. You can change the fan and clutch unit, inspect everything for damage from the fan becoming disconnected and be OK, however running and wobbling may have caused some bearing damage in the pump...keep an eye on it...any noises or leaks from there, change it.
Mar 24, 2009 | 1995 Nissan Pathfinder
Broke a light in my ceiling fan its a hampton Bay Portland II model number 762 425
You mean the base remains and the glass broke off? After you turn off the power (you might consider turning off the breaker) Take a wire stripper, the type that has only one place to strip wire, the small stripper. Completely reverse the tool so that when you pull the handles the pointed end opens up. Stick this into the broken socket, use the handles to spread the pointed ends inside the socket and unscrew.
Oct 12, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Light cover/Dish for ceiling fan
My installation instructions say call 1-800-295-4448 and give the following infromation: 1. Part number 2.Part description 3. Style number of your fan. It is part number 31 Glass Shade
Jul 11, 2008 | Dryers
Hampton Bay San Juan Model # 360396
It is a special-order from Hampton Bay, not a generic piece. Their tech support number is located in the fan's owner's manual.
Apr 04, 2008 | Hampton Bay 24002 Ceiling Fan
MSI K8N Neo-FSR Motherboard Logo
26 people viewed this question
Top MSI Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Terry Hair
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
