Question about Cross Infoguard Shredder SX102M
Sx-102M Power light goes on, but nothing else. Inserting paper gets no response. Completely dead when put in reverse; not even a power light. Cutters look clear, with no apparent paper jams.
  • 4 more comments
  • bibblybot Apr 10, 2008
    We have the exact same problem.  We called tech support and they simply said to throw it away as it is out of warranty...  a sensor is dead and not worth/cannot be fixed...
    As a side point, the "red" switch appears to be actually a safety trigger rather than a reset button as mentioned, so at least mine does not stay depressed unless it is in the basket and aligned with the metal piece...
  • Anonymous Apr 14, 2008
    tHE LIGHT DOESN'T GO ON AND NOTHING HAPPENS.I have tried to pull out all shreds, but can not reach all
    bjschaef@mbol.us
  • Anonymous Jul 23, 2008
    Place power switch on Auto and light turns on but when paper is inserted nothing happens. There is a little white plastic switch that you can hear click when you put paper in and out. I assume that switch is dead which acitvates the unit. Can a switch be purchased. The unit is only two years old. Does anything last these days???? I have to spend 2 hundred dollars to replace it.
  • desiff Jan 03, 2009
    Ready light is on but paper wont feed and start motor. Reverse does work and motor turns when revrese switch is used.
  • Anonymous Jan 10, 2009
    SX100M -
    Place power switch on Auto and light turns on but when paper is inserted nothing happens. There is a little white plastic switch that you can hear click when you put paper in and out. I assume that switch is dead which acitvates the unit. Can a switch be purchased. The unit is less than two years old.
  • Anonymous Mar 14, 2014
    how do I prevent the above problem
  • 4 Answers
I have the Infoguard SX-100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, the gears and fuse was ok, I think something on the circuit board was fried.
I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Posted on Mar 28, 2009
My red safety button wasn't catching on the metal part on the basket meant to hold it in a depressed state. The basket was bent out a little bit. I smooshed it in and now the red safety button catches on the metal thingy and it works!
Posted on Nov 21, 2008
There is a reset switch on the side - it is a slot with a red button. If you press this and it does not stay drpressed, the reset is shot and needs to be replaced
Posted on Mar 26, 2008
My royal sp12mx will work in reverse but nothing happens when i insert paper to shred. light is on
there is a very small lever between two cutters around the middle that activates a microswitch to turn it on when you offer paper to be cut
the problem will be in that area ( switch or lever broken) as it's purpose is to switch on the cutters
reverse is straight drive from the control switch
Aug 27, 2016 | Royal SP12MX 12 Sheets PP Security Plus...
Fellowes HD-10Cs won't shred. Power gets to machine because it will manually reverse when reverse button held. Can't get the sensor lights to work. Tried overide switch for sensor light. Held in...
Unplug from mains electricity.
use a cotton bud dipped in rubbing alcohol to clean the sensor
light(s) and heads
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
Jan 31, 2014 | Fellowes HD-10Cs Shredder
Laptop Acer Aspire 3354-1096 Power-up Problem
Do you have access to a multimeter to track the AC/DV current? If the power is getting to the laptop, correct DC/AMP voltage? AC jack been damaged, pulled, yanked...etc? Hard to say which component without checking with a multimeter? PSU?
Nov 25, 2012 | Computers & Internet
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
STAPLES TITANIUM CUTTER (SPL-TMC16A) CONTINUES TO RUN WITHOUT STOPPING AFTER PAPER HAS BEEN SHRED. THE FORWARD LIGHT FLASHES.
can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
Dec 16, 2010 | Office Equipment & Supplies
Sx 102m reverse works, and auto does not work
Did you try blowing out the sensor with canned air?
No spare parts are available.
Jun 21, 2009 | Cross Infoguard Shredder SX102M
Fellows S701CM shredder won't respond
unplug in and check the fuse in the back side of the shredder
good luck
Jan 24, 2009 | Fellowes 3011001 Shredder
HP Deskjet 1280
I have found you need to be very accurate with the placement of the of the paper guide box and ensure it is completely locked in to ensure the printer will turn on.
This is the manual feed box at rear of the printer.
Cheers
Yoga2
Jun 16, 2008 | HP DeskJet 1280 InkJet Printer
SX-102M Shredder
The "Head Assembly" IS the shredder. If that part is bad you have DEEEEP trouble. I can tell you though that the primary exchange gear is likely stripped. It is nylon and can't take much abuse. How do I know??? ... 'Cause I have one just like it!!! Let's trade. Maybe we can get one good one out of the two. In the future (as I have carefully explained too my daughter!!!) don't put more than 10 sheets in at a time!!!
By the way... the only part left after the "head assembly" is a waste basket..
Ramah G. Martin (the guy who fixes things)
Glenn@ramahg.com
Mar 31, 2008 | Cross Infoguard Shredder SX102M
Cross Infoguard Shredder SX102M Logo
799 people viewed this question
Top Cross Office Equipment & Supplies Experts
Computer Links
Ivan
Ivan
Level 1 Expert
gbob59
Are you a Cross Office Equipment and Supply Expert? Answer questions, earn points and help others
