MY AMANA WASHING MACHINE IS LEAKING WATER, SEEMS TO BE COMING FROM THE CENTER UNDER THE TUB.
    President:
  • 1,304 Answers
Take off the front panel, if you can see a distinct line around the entire inside it is leaking past the hub seal
you will need an expert for this repair
Posted on Oct 03, 2009
Testimonial: " Thanks for the help."
The tub on my washing machine model # AAV70000AWW seems to be off center water will not spin out
Possible that the drain pump is clogged with the valve not flushing out. Make sure there is a slight tilt to the drain side of the TUB, now if you can remove and clean the drain pump and outlet it might solve the issue.
Dec 31, 2012 | Amana Washing Machines
Amana dlw330ra, loud and leaking
HI,
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Aug 11, 2008 | Amana DLW330RA Top Load Washer
It is leaking on the bottom when I do laundry. The hoses are fine. The water seems to be around the edges on the bottom of the washing machine. The machine is only 5 1/2 years old.
if you look at the front inside panel and the side panels nd if you see like black spots half way up the panel you have bad tub seals and that's what it sounds like you have.the tubs have to be separated and the middle seal has to be changed out.you need special tools to do this job.might be better replacing the washer if it's the problem.fill it with water,run it and look at the tranny part coming out the middle of the tub on the bottom of the tub,let it agitate and put it in spin,if you see water leaking out the middle of the tub it's the tub seal
Jan 19, 2011 | Amana Washing Machines
Water is leaking out of washer; think it is during the water draining cycle
The AMANA washer has an outer tub and a water pump. Please check these to make sure you can see where the leak is coming from and replace. Also, if your machine has a dispensing system, check all hoses for THAT system. If upon fill up the out tyub HOLDS WATER and DOES NOT Leak, then the outer tub is okay. Carefullky look at the water pump on drain.
Nov 16, 2009 | Amana ALW780QA
Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Jul 02, 2009 | Maytag PAV2300 Top Load Washer
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
Water leak
POSSIBLE LEAKING PUMP OR TUB SEAL
Apr 16, 2009 | Washing Machines
Amana lw8203w leaking
Your LW8203W is at least 12 years old. It is leaking from the tub seal, Your machine needs to be rebuilt or replaced.
If you have it rebuilt I would also put in a new belt, pump, brake pads, upper tub bearing and the tub seal it needs.
Call and authorized Speed Queen or Amana dealership and ask for a price quote over the phone. Then price out a new machine.
Your choice.
Jul 05, 2008 | Washing Machines
Amana washing machine
prob faulty door seal or iff really bad hole in outer tub
Jul 02, 2008 | Amana Washing Machines
Washer leaking
You need to remove the front panel and look where the water is coming from. fill the washer on the small water level. then turn it to spin and watch for water.
If its the pump you can replace this, if its a tub seal, up under the tub thats a major job, get someone to give you a quote over the phone. You may want to replace the washing machine. based on age and $$$
May 25, 2008 | Amana ALW480DA Top Load Washer
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
